Redesigned and rechargeable, Magic Trackpad 2 includes a built-in battery and brings Force Touch to the desktop for the first time. Four force sensors underneath the trackpad surface allow you to click anywhere, and detect subtle differences in the amount of pressure you apply, bringing increased functionality to your fingertips and enabling a deeper connection to your content. Magic Trackpad 2 also features an edge-to-edge glass surface area. This design, along with a lower profile, makes scrolling and swiping through your favorite content more productive and comfortable than ever. Magic Trackpad 2 pairs automatically with your Mac, so you can get to work right away. And the battery will power your Magic Trackpad 2 for about a month or more before needing a recharge.
                More control at your fingertipsMagic Trackpad gives you a whole new way to control what's on your Mac desktop computer. When you perform gestures, you actually interact with what's on your screen. You feel closer to your content, and moving around feels completely natural. Swiping through pages on screen is just like flipping through pages in a magazine, and inertial scrolling senses the momentum in your fingers as you move up and down a page.
                More to touch, more to loveYour fingers will fall for the Magic Trackpad. It's made with smooth, wear-resistant glass that feels great to the touch. And it's nearly 80 percent larger than the built-in trackpad on the MacBook Pro, giving you plenty of room to perform gestures. Because the entire surface of Magic Trackpad is a button, you can click on objects just as you would using a traditional mouse. And Magic Trackpad sits at the same height and angle as the Apple wireless keyboard, so you can go from trackpad to keyboard in one seamless motion.
                Bluetooth technologyMagic Trackpad connects to your Mac via Bluetooth wireless technology. Use it in conjunction with the Apple wireless keyboard for a cable-free, uncluttered workspace. And if you feel like venturing away from your desk, Magic Trackpad maintains a reliable and secure connection up to 33 feet away from your Mac.
- Apple Magic Trackpad 2 - trackpad - Bluetooth 4.0 - space grey
- Trackpad
- Connectivity Technology
- Wired, wireless - Bluetooth 4.0
- Space grey
- 16 cm x 11.49 cm x 1.09 cm
- 231 g
- Multi-Touch
- Force Touch, four sensors
- OS Required
- Apple MacOS X 10.11 or later
- Trackpad
- 16 cm
- 11.49 cm
- 1.09 cm
- 231 g
- Space grey
Input Device
- Wired, wireless
- Interface
- Bluetooth 4.0
- Multi-Touch
- Included Accessories
- Lightning to USB cable
- OS Required
