The Magic Trackpad is the first multi-touch trackpad designed to work with your Mac desktop computer. It uses the same multi-touch technology you love on the MacBook Pro. And it supports a full set of gestures, giving you a whole new way to control and interact with what's on your screen. Swiping through pages online feels just like flipping through pages in a book or magazine. And inertial scrolling makes moving up and down a page more natural than ever. Magic Trackpad connects to your Mac via Bluetooth wireless technology. Use it in place of a mouse or in conjunction with one.
More control at your fingertips
Magic Trackpad gives you a whole new way to control what's on your Mac desktop computer. When you perform gestures, you actually interact with what's on your screen. You feel closer to your content, and moving around feels completely natural. Swiping through pages on screen is just like flipping through pages in a magazine, and inertial scrolling senses the momentum in your fingers as you move up and down a page. -
More to touch, more to love
Your fingers will fall for the Magic Trackpad. It's made with smooth, wear-resistant glass that feels great to the touch. And it's nearly 80 percent larger than the built-in trackpad on the MacBook Pro, giving you plenty of room to perform gestures. Because the entire surface of Magic Trackpad is a button, you can click on objects just as you would using a traditional mouse. And Magic Trackpad sits at the same height and angle as the Apple wireless keyboard, so you can go from trackpad to keyboard in one seamless motion. -
Bluetooth technology
Magic Trackpad connects to your Mac via Bluetooth wireless technology. Use it in conjunction with the Apple wireless keyboard for a cable-free, uncluttered workspace. And if you feel like venturing away from your desk, Magic Trackpad maintains a reliable and secure connection up to 33 feet away from your Mac.
- Apple Magic Trackpad - trackpad - Bluetooth - black
- Trackpad
- Connectivity Technology
- Wireless, wired - Bluetooth
- Black
- 16 cm x 11.49 cm x 1.09 cm
- 230 g
- Multi-Touch
- Multi-gesture touch pad, Force Touch, rechargeable battery
- OS Required
- Apple MacOS 10.11 or later, Apple iPadOS 13.4 or later
- 1-year warranty
- Trackpad
- 16 cm
- 11.49 cm
- 1.09 cm
- 230 g
- Black
Input Device
- Wireless, wired
- Interface
- Bluetooth
- Multi-Touch
- Included Accessories
- USB-C to Lightning cable
- OS Required
- Limited warranty - 1 year
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
GRN2 048399 Condition: Customer return - item has been used and shows signs of use |
£54.88 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
