Apple Magic Mouse
Quicklinx: HYRPWS00 Mfr#: MXK53Z/A
Wired / Wireless: Wireless
Colour: White
31 In Stock
£58.33 ex VAT
£69.99 inc VAT
Magic Mouse is wireless and rechargeable, with an optimised foot design that lets it glide smoothly across your desk. The Multi-Touch surface allows you to perform simple gestures such as swiping between web pages and scrolling through documents.
The rechargeable battery will power your Magic Mouse for about a month or more between charges. It’s ready to go right out of the box and pairs automatically with your Mac.
It features a USB-C port and includes a woven USB-C Charge Cable that lets you pair and charge by connecting to a USB-C port on your Mac, so you can charge all of your favourite devices with just a single cable.
  • Magic is in the multi-touch
    The Magic Mouse redefines what a mouse should do. In addition to its smooth, seamless top-shell design that acts as one button or two, Magic Mouse features a multi-touch surface with gesture support. Scroll vertically, horizontally, and diagonally - a full 360 degrees - simply by touching anywhere on the top surface. With a greater surface area for scrolling, you can get around a long timeline in iMovie, through a lengthy web page in Safari, or around a set of images in iPhoto more efficiently. You can also swipe through pages in Safari or photos in iPhoto with two fingers. It's the most advanced Apple mouse ever made.
  • One or two, left or right
    The seamless, one-button design of Magic Mouse makes it simple to use right out of the box. But if you want the functionality of a two-button mouse, that's easy, too. Just change the configuration in system preferences. And the ambidextrous construction means Magic Mouse is great for lefties or righties.
  • Laser tracking engine
    Magic Mouse features a laser tracking engine that's far more sensitive and responsive on more surfaces than traditional optical technology. That means it can track with precision on nearly every surface with no mousepad required.
  • Bluetooth technology
    Magic Mouse works wirelessly with your Bluetooth-enabled Mac. When you combine it with the Apple wireless keyboard, the result is an untethered and uncluttered workspace. Once you pair Magic Mouse with your Mac, you can enjoy a secure and reliable connection from up to 33 feet away.
Apple Magic Mouse - mouse - Bluetooth - white
Mouse
Wireless - Bluetooth
White
5.71 cm x 11.35 cm x 2.16 cm
99 g
Multi-Touch
Rechargeable battery, gesture function, scrolling
Apple macOS 15.1 or later, Apple iPadOS 18.1 or later
1-year warranty
Mouse
5.71 cm
11.35 cm
2.16 cm
99 g
White
Input Device
Wireless
Bluetooth
Multi-Touch
Additional Ports
1 x USB-C - 24 pin USB-C
USB-C cable
Run Time (Up To)
1 month
Limited warranty - 1 year
Colour: White
Brand: Apple
