Apple Magic Keyboard iPad Pro 11 White
Quicklinx: GCX7WS00 Mfr#: MJQJ3B/A
Device Type: iPad Pro
Type: Keyboard
Device Screen Size: 11
Colour: White
£265.84 ex VAT
£319.00 inc VAT
The Magic Keyboard is an amazing companion for iPad Pro and iPad Air. It features an incredible typing experience, a trackpad that opens up new ways to work with iPadOS, a USB-C port for passthrough charging, and front and back protection. The Magic Keyboard has a floating cantilever design, allowing you to attach iPad Pro and iPad Air magnetically and to smoothly adjust it to the perfect viewing angle for you.
Apple Magic Keyboard - keyboard and folio case - with trackpad - QWERTY - UK - white Input Device
Keyboard and folio case
Backlit
Apple Smart connector
Built-in Devices
Trackpad
Localization and Layout
QWERTY UK
White
10.9-inch iPad Air (4th generation, 5th generation); 11-inch iPad Air (M2, M3); 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation, 4th generation)
Backlit
QWERTY UK
Region
United Kingdom
Keyboard Technology
Scissors
Built-in Devices
Trackpad
Carrying Case
Magnetic connection, adjustable viewing angles
USB-C
White
Apple 10.9-inch iPad Air (4th generation, 5th generation) , Apple 11-inch iPad Air (M2, M3) , Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation, 4th generation)
Type: Keyboard
Colour: White
Brand: Apple
