Apple Magic Keyboard for iPad Pro 12.9-inch
Quicklinx: GKPMWS00 Mfr#: MJQL3B/A
The Magic Keyboard is an amazing companion for iPad Pro and iPad Air. It features an incredible typing experience, a trackpad that opens up new ways to work with iPadOS, a USB-C port for passthrough charging, and front and back protection. The Magic Keyboard has a floating cantilever design, allowing you to attach iPad Pro and iPad Air magnetically and to smoothly adjust it to the perfect viewing angle for you.
  • Comfortable backlit keys and a scissor mechanism with 1mm travel for quiet, responsive typing.
  • Designed for Multi-Touch gestures and the cursor in iPadOS.
  • Smooth angle adjustability delivers the perfect viewing angle.
  • USB-C port for charging iPad Pro, freeing up the port on the iPad for other accessories.
  • Folds into a case to provide front and back protection for travelling with iPad Pro.
iPad Pro 12.9-inch (3rd, 4th, 5th or 6th generation) running iPadOS 14.5 or later.
iPad Models
  • iPad Pro 12.9-inch (6th generation)
  • iPad Pro 12.9-inch (5th generation)
  • iPad Pro 12.9-inch (4th generation)
  • iPad Pro 12.9-inch (3rd generation)
Apple Magic Keyboard - keyboard and folio case - with trackpad - QWERTY - UK - white Input Device
Keyboard and folio case
Backlit
Apple Smart connector
Built-in Devices
Trackpad
Localization and Layout
QWERTY UK
White
12.9-inch iPad Pro (3rd generation, 4th generation, 5th generation); 13-inch iPad Air (M2, M3)
Backlit
QWERTY UK
Region
United Kingdom
Keyboard Technology
Scissors
Built-in Devices
Trackpad
Carrying Case
Magnetic connection, adjustable viewing angles
USB-C
White
Apple 12.9-inch iPad Pro (3rd generation, 4th generation, 5th generation) , Apple 13-inch iPad Air (M2, M3)
