The Magic Keyboard is an amazing companion for iPad Pro and iPad Air. It features an incredible typing experience, a trackpad that opens up new ways to work with iPadOS, a USB-C port for passthrough charging, and front and back protection. The Magic Keyboard has a floating cantilever design, allowing you to attach iPad Pro and iPad Air magnetically and to smoothly adjust it to the perfect viewing angle for you.
- Comfortable backlit keys and a scissor mechanism with 1mm travel for quiet, responsive typing.
 - Designed for Multi-Touch gestures and the cursor in iPadOS.
 - Smooth angle adjustability delivers the perfect viewing angle.
 - USB-C port for charging iPad Pro, freeing up the port on the iPad for other accessories.
 - Folds into a case to provide front and back protection for travelling with iPad Pro.
iPad Pro 12.9-inch (3rd, 4th, 5th or 6th generation) running iPadOS 14.5 or later.
iPad Models
- iPad Pro 12.9-inch (6th generation)
 - iPad Pro 12.9-inch (5th generation)
 - iPad Pro 12.9-inch (4th generation)
 - iPad Pro 12.9-inch (3rd generation)
 - Apple Magic Keyboard - keyboard and folio case - with trackpad - QWERTY - UK - white Input Device
 - Keyboard and folio case
- Backlit
- Interface
 - Apple Smart connector
- Connectivity Technology
 - Wired
- Built-in Devices
 - Trackpad
- Localization and Layout
 - QWERTY UK
 - White
- Designed For
 - 12.9-inch iPad Pro (3rd generation, 4th generation, 5th generation); 13-inch iPad Air (M2, M3)
- Backlit
- Interface
 - QWERTY UK
- Region
 - United Kingdom
- Keyboard Technology
 - Scissors
- Built-in Devices
 - Trackpad
Carrying Case
 - Magnetic connection, adjustable viewing angles
 - USB-C
 - White
- Designed For
 - Apple 12.9-inch iPad Pro (3rd generation, 4th generation, 5th generation) , Apple 13-inch iPad Air (M2, M3)
