Apple Magic Keyboard for iPad Pro 12.9-inch
Quicklinx: GKPMWS00 Mfr#: MJQL3B/A
Recommended Use: Leisure
Type: Keyboard
Wired / Wireless: Wired
Colour: White
Compatibility: Apple iOS
Hurry, only 1 left in stock!
£315.84 ex VAT
£379.00 inc VAT
Express delivery Order within the next 17 hours for delivery tomorrow
The Magic Keyboard is an amazing companion for iPad Pro and iPad Air. It features an incredible typing experience, a trackpad that opens up new ways to work with iPadOS, a USB-C port for passthrough charging, and front and back protection. The Magic Keyboard has a floating cantilever design, allowing you to attach iPad Pro and iPad Air magnetically and to smoothly adjust it to the perfect viewing angle for you.
  • Comfortable backlit keys and a scissor mechanism with 1mm travel for quiet, responsive typing.
  • Designed for Multi-Touch gestures and the cursor in iPadOS.
  • Smooth angle adjustability delivers the perfect viewing angle.
  • USB-C port for charging iPad Pro, freeing up the port on the iPad for other accessories.
  • Folds into a case to provide front and back protection for travelling with iPad Pro.
iPad Pro 12.9-inch (3rd, 4th, 5th or 6th generation) running iPadOS 14.5 or later.
iPad Models
  • iPad Pro 12.9-inch (6th generation)
  • iPad Pro 12.9-inch (5th generation)
  • iPad Pro 12.9-inch (4th generation)
  • iPad Pro 12.9-inch (3rd generation)
Apple Magic Keyboard - keyboard and folio case - with trackpad - QWERTY - UK - white Input Device
Keyboard and folio case
Backlit
Apple Smart connector
Wired
Built-in Devices
Trackpad
Localization and Layout
QWERTY UK
White
12.9-inch iPad Pro (3rd generation, 4th generation, 5th generation)
Backlit
QWERTY UK
Region
United Kingdom
Keyboard Technology
Scissors
Built-in Devices
Trackpad
Carrying Case
Magnetic connection, adjustable viewing angles
USB-C
White
Apple 12.9-inch iPad Pro (3rd generation, 4th generation, 5th generation)
Type: Keyboard
Colour: White
Brand: Apple
