The Magic Keyboard is an amazing companion for your device. It features a great typing experience. The Magic Keyboard has a floating cantilever design, allowing you to attach your device magnetically and to smoothly adjust it to the perfect viewing angle for you.
- Apple Magic Keyboard - keyboard and folio case - with trackpad - QWERTY - UK Input Device
- Keyboard and folio case
- Backlit
- Interface
- Apple Smart connector
- Connectivity Technology
- Wired
- Built-in Devices
- Trackpad
- Localization and Layout
- QWERTY UK
- 1-year warranty
- Designed For
- Apple 10.9-inch iPad Air (4th gen, 5th gen), 11-inch iPad Air (M2), 11-inch iPad Pro (1st gen, 2nd gen, 3rd gen, 4th gen)
- Backlit
- Interface
- QWERTY UK
- Region
- United Kingdom
- Keyboard Technology
- Scissors
- Built-in Devices
- Trackpad
Carrying Case
- Magnetic connection, adjustable viewing angles
- USB-C
- Limited warranty - 1 year
- Designed For
