The Magic Keyboard combines a sleek design with a built-in rechargeable battery and enhanced key features. With an improved scissor mechanism beneath each key for increased stability, as well as optimized key travel and a lower profile, the Magic Keyboard provides a remarkably comfortable and precise typing experience. It pairs automatically with your Mac, so you can get to work right away. And the battery is incredibly long-lasting - it will power your keyboard for about a month or more between charges.
Wireless connectivity
Experience the freedom of wireless connectivity with Bluetooth technology, allowing for a clean, cable-free workspace and the flexibility to position the keyboard anywhere within range. -
Rechargeable convenience
With its built-in rechargeable battery, this keyboard offers the convenience of USB charging, eliminating the need for disposable batteries and ensuring it's always ready when you are. -
Designed for Mac
Optimized for Mac compatibility, this keyboard seamlessly integrates with your Mac setup, offering immediate connectivity and a layout familiar to Mac users. -
Enhanced typing experience
The scissors mechanism beneath each key allows for increased stability, while the optimized key travel and low profile provide a comfortable and precise typing experience.
- Apple Magic Keyboard - keyboard - QWERTY - UK
- Keyboard
- Interface
- Bluetooth
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Multimedia
- 27.9 cm x 11.49 cm x 1.09 cm
- 231 g
- Keyboard
- Interface
- Bluetooth
Input Device
- Hot Keys Function
- Multimedia
- QWERTY UK
- Region
- United Kingdom
- Keyboard Technology
- Scissors
- 27.9 cm
- 11.49 cm
- 1.09 cm
- 231 g
- Included Accessories
- Lightning to USB cable
- OS Required
- Apple MacOS X 10.11 or later
- Rechargeable
