Apple MacBook Pro with Touch Bar Core i7 2.6GHz 16GB 512GB - Silver
Quicklinx: FJ85WS00 Mfr#: MVVL2B/A
  • Core i7
  • IEEE 802.11n
The thermal architecture in MacBook Pro has been completely redesigned, featuring larger impellers with improved fan blades for optimal airflow and more heat-dispersing fins for more effective cooling. The resulting gain in cooling capacity allows MacBook Pro to deliver up to 12 watts more maximum sustained power.
MacBook Pro has a big voice. The six-speaker sound system produces room-filling wide stereo sound like you've never heard from a notebook before. Dual force-canceling woofers dramatically reduce system vibration for a clearer, more natural sound and a half-octave lower range to the bass. And the studio-quality three-mic array rivals professional third-party microphones, for creating superclean podcasts or music recordings on the go.
  • Brilliant Retina display
    The best display ever in a notebook features increased contrast ratio, delivering deeper blacks and brighter whites. Content comes to life in photos, video, and games - with refined specular highlights, incredible detail in shadows, and vibrant, true-to-life colors.
  • Heads up - the camera's 720p HD
    Staying connected is more important than ever. That's why the MacBook Pro camera has 720p resolution and uses a lens with a wider aperture that lets in more light. Together with a larger image sensor that has more efficient pixels, the camera delivers two times better low-light performance.
  • Three studio-quality mics
    Thanks to mics with an up to 60 percent lower noise floor, MacBook Pro can capture even the subtlest sounds. And the three-mic array uses directional beamforming so your voice always comes through loud and clear.
  • Six-speaker sound system
    Four force-cancelling woofers reveal notes up to a half-octave deeper and fill the room with up to 80 percent more bass. And the high-performance tweeters project clearer, fuller vocals.
  • Pro power meets pro keyboard
    For the first time, Magic Keyboard brings a full-height function key row to MacBook Pro - with the tactile feel of mechanical keys that pros love. It includes new keyboard shortcuts for Spotlight, Dictation, and Do Not Disturb. And Touch ID has a new, tactile ring that guides your finger for a fast, easy, secure way to unlock your Mac.
  • Designed with the Earth in mind
    The MacBook Pro has been carefully designed with the environment in mind. The enclosure is now made with 100% recycled aluminum. And Apple uses recycled rare earth elements in all the magnets in the product.
Apple MacBook Pro with Touch Bar - 16" - Intel Core i7 - 16 GB RAM - 512 GB SSD - UK
Notebook
Operating System
macOS Big Sur 11.0
Intel Core i7 (9th Gen) - 2.6 GHz, up to 4.5 GHz / 12 MB Cache
16 GB DDR4 (provided memory is soldered)
Storage
512 GB SSD
Display
16" LED backlight 3072 x 1920 @ 60 Hz - 226 ppi
Graphics
AMD Radeon Pro 5300M / Intel UHD Graphics 630
Video Memory
4 GB GDDR6 SDRAM
Input Device
Force Touch trackpad, Touch Bar
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0
Up to 11 hours
Security
Apple T2 Security Chip, fingerprint reader
Silver
35.79 cm x 24.59 cm x 1.62 cm
2 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
0.82 W/kg (body)
Limited warranty - 1 year , Technical support - phone consulting - 90 days
Notebook
Operating System
Apple macOS Big Sur 11.0
Processor / Chipset
CPU
Intel Core i7 (9th Gen) 2.6 GHz
Max Turbo Speed
4.5 GHz
Number of Cores
6-core
Cache
L3 - 12 MB
64-bit Computing
Intel Turbo Boost Technology
RAM
16 GB (provided memory is soldered)
DDR4 SDRAM
Speed
2666 MHz
Storage
Main Storage
512 GB SSD soldered
Display
16" - IPS
LCD Backlight Technology
LED backlight
Resolution
3072 x 1920
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
226
Image Brightness
500 cd/m²
BFR/PVC-free, Mercury free, arsenic-free glass, beryllium free, Retina display, True Tone display, P3 Wide Color Gamut
Keyboard Name
Apple Magic Keyboard
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR6 SDRAM
Camera
Yes - 720p
Camera Features
FaceTime HD camera
Sound
Six speakers, three microphones
Dolby Atmos
Input
Keyboard, Force Touch trackpad, Touch Bar
Keyboard Backlight
Keyboard Layout
Pressure sensitivity, multi-touch touchpad, Multi-Touch Gesture Recognition, ambient light sensor, force click, Touch ID sensor
Communications
Wireless
Lithium polymer
100 Wh
Run Time
Up to 11 hours
Battery Run Time
Web browsing over Wi-Fi: up to 11 hours , Video playback: up to 11 hours , Standby time: up to 30 days
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
96 Watt
Connections & Expansion
Interfaces Details
4 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery) , Headphone output
Software
Software Included
Drivers & Utilities, Apple QuickTime, Apple iMovie, Apple Safari, Apple GarageBand, Photo Booth, Apple Time Machine, Apple FaceTime, Apple Preview, Mail, Maps, Photos, Reminders, App Store, Music, Contacts, Stocks, Notes, Calendar, Siri, Messages, Dictation, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers, News, Voice Memos, Podcasts, Home, Apple TV, Find My
Silver
Case Material
Aluminum
Security
USB-C power adapter
USB-C charge cable
SAR Value
0.82 W/kg (body)
0.82 W/kg (body)
Localization
2 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
10 °C
35 °C
0 - 90% (non-condensing)
