Apple MacBook Pro Intel Core i7 15.4" 4GB 500 DVDRW Mac OS X Snow Leopard
Quicklinx: 6P7HWS00 Mfr#: MC373B/A
  • Core i7
  • IEEE 802.11n
  • NVIDIA GeForce GT 330M / Intel HD Graphics
MacBook Pro is machined from a single piece of aluminum, an engineering breakthrough that replaced many parts with just one. It's called the unibody. And the first time you pick up a MacBook Pro you'll notice the difference it makes. The entire enclosure is thinner and lighter than other notebooks. It looks polished and refined. And it feels strong and durable - perfect for life inside (and outside) your briefcase or backpack.
  • Strength, lightness, beauty - seamlessly integrated
  • FaceTime HD camera
    The FaceTime HD camera built into the MacBook Pro display is even thinner than the camera inside iPhone 4.
  • A display full of bright ideas
    LED backlight technology for the MacBook Pro makes the display instantly bright and allows it to be incredibly thin. They used edge-to-edge glass not just because it looks beautiful, but because it lends structure to the display. And at the top of the screen they hid the built-in FaceTime HD camera. So you see your friends and family in big, beautiful widescreen - and as little of the camera as possible.
  • Multi-touch trackpad - it just feels right
    The multi-touch trackpad has no button because it is the button. That means there's more room to track and more room to click - left, right, center, and everywhere in between. The result is a trackpad that just makes sense to you - and your fingers.
  • Easy access to connections and ports
    The connections and ports on MacBook Pro - Gigabit Ethernet, USB, and audio in/out - are all smartly integrated on the same side of the notebook. So your cables stay neatly organized, and connecting and disconnecting your devices is easy and convenient.
  • Designed to make an impact
    Complete control over how the MacBook Pro is designed, how it's manufactured, and how it's packaged gives Apple an environmental edge. LED backlight technology preserves energy. Glass and aluminum are highly recyclable. MacBook Pro is free of most harmful toxins.
Apple MacBook Pro 15.4" - Core i7 - MacOS X 10.6 - 4 GB RAM - 500 GB HDD
System Type
Notebook
Operating System
MacOS X 10.6
Intel Core i7 2.66 GHz / 4 MB Cache
4 GB DDR3
Storage
500 GB HDD / 5400 rpm
Optical Drive
DVD-Writer DL
Display
15.4" LED backlight 1440 x 900 / WXGA+
Graphics
NVIDIA GeForce GT 330M / Intel HD Graphics - 512 MB GDDR3
802.11 a/b/g/n, Bluetooth 2.1 EDR , Gigabit Ethernet
Up to 9 hours
36.4 cm x 24.9 cm x 2.4 cm
2.5 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified , EPEAT Gold
1 year warranty
System Type
Notebook
Operating System
Apple MacOS X 10.6
1 year warranty
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
L3 - 4 MB
64-bit Computing
Front Side Bus
1066 MHz
RAM
4 GB ( 2 x 2 GB )
Max RAM Supported
8 GB
DDR3 SDRAM
Speed
1066 MHz / PC3-8500
SO DIMM 204-pin
Slots Qty
2
Empty Slots
0
Storage
Hard Drive
Serial ATA-150
Optical Drive
DVD±RW (±R DL) - fixed
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 4x (DVD±R DL)
CD / DVD Rewrite Speed
10x (CD) / 4x (DVD±RW)
Display
15.4"
LCD Backlight Technology
LED backlight
Resolution
1440 x 900 ( WXGA+ )
Widescreen
Ambient light sensor, glossy
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
NVIDIA GeForce GT 330M / Intel HD Graphics - 512 MB GDDR3 SDRAM
Camera
Integrated webcam
Sound
Stereo speakers , microphone
Input
Trackpad, backlit keyboard
Multi-touch touchpad
Communications
Wireless
Network Interface
Gigabit Ethernet
Lithium polymer
77.5 Wh
Run Time
Up to 9 hours
AC Adapter
Input
AC 120/230 V ( 50/60 Hz )
Connections & Expansion
LAN , FireWire 800 , 2 x USB 2.0 , Mini DisplayPort , Microphone input , Headphone/SPDIF combo jack
Memory Card Reader
Yes ( SD Card )
Software
Software Included
Drivers & Utilities, Apple QuickTime, Apple iTunes, Apple Mac OS X Mail, Apple iChat, Apple iCal, Apple DVD Player, Apple iLife, Apple Address Book, Apple Safari, Apple Dashboard, Apple Spotlight, Apple XCode Developer Tools, Front Row, Photo Booth, Apple Spaces, Apple Quick Look, Apple Time Machine
Security lock slot (cable lock sold separately), aluminum enclosure
Cleaning cloth
Localization
36.4 cm
24.9 cm
2.4 cm
2.5 kg
EPEAT Compliant
EPEAT Gold
Limited warranty - 1 year , Technical support - phone consulting - 90 days
10 °C
35 °C
0 - 90%
