Apple MacBook Pro 13" with Retina Display Dual-Core i5 8GB 512GB SSD
Quicklinx: 9N87WS00 Mfr#: MGX92B/A
  • Core i5
  • Bluetooth 4.0
  • IEEE 802.11n
A groundbreaking Retina display. All-flash architecture. Fourth-generation Intel processors. Remarkably thin and light design. Together, these features take the notebook to a place it's never been. And they'll do the same for everything you create with it.
  • Multi-pixel view
    When you pack so many pixels into a display - the results are positively stunning. The pixel density is so high, your eyes can't discern individual pixels. Images take on a new level of realism. A spectacular resolution on MacBook Pro let you see more of your high-resolution images with pixel-for-pixel accuracy. And text is so sharp, you'll feel like you're reading email, web pages, and documents on a printed page. The Retina display reduces glare while maintaining incredible color and quality. Its high contrast ratio results in blacker blacks and whiter whites. And everything in between is rich and vibrant. IPS technology gives you a wide, 178-degree view of everything on the screen, so you'll see the difference at practically any angle. And you're going to love what you see.
  • Fourth-generation dual-core Intel Core processor
    With a fourth-generation dual-core Intel Core processor, the MacBook Pro with Retina display lets you take your most performance-hungry apps on the road. That means wherever you can take your camera, you can take your entire digital photo studio. Hyper-Threading technology, which enhances performance by letting each core handle multiple tasks simultaneously, is included in every model. And with speeds up to 3.0GHz, shared L3 cache up to 4MB, and Turbo Boost speeds up to 3.5GHz, these processors are ready for just about anything.
  • Iris graphics
    The MacBook Pro with Retina display features Intel Iris Graphics to handle both everyday tasks and graphics-intensive creative apps. Scroll through large photo albums with ease. Play games with amazing detail. Even connect an external display or two.
  • Ultrafast all-flesh storage
    You'll notice a difference in whatever you do - starting up takes seconds, apps launch quickly, even navigating the desktop feels incredibly fluid and responsive. It's all thanks to PCle-based flash storage with incredibly fast read and write performance. So you can import huge photo libraries in no time flat.
  • Wi-Fi - the definition of fast
    Meet the ultimate mobile creative studio. With an emphasis on mobile. Equipped with 802.11ac Wi-Fi and Bluetooth 4.0 wireless technology, you're free to unplug and still stay connected - to your network, to your wireless peripherals, and to the world. With AirPlay and Apple TV, you can wirelessly play video, show off photos, and enjoy music from your MacBook Pro on your widescreen TV. And when your MacBook Pro connects to an 802.11ac Wi-Fi base station, such as AirPort Extreme or AirPort Time Capsule, your wireless performance is up to 3x faster.
  • Thunderbolt 2
    Fast and versatile, Thunderbolt 2 provides up to 20Gb/s of bandwidth to each external device. So you're more than ready for the next generation of high-performance peripherals and displays. You can connect massive amounts of storage and add a PCI expansion chassis. And since each Thunderbolt 2 port allows you to daisy-chain up to six peripherals, you can go all out by plugging in up to 12 external devices via Thunderbolt alone.
  • Audio and visual
    You haven't heard it all until you've heard the speakers inside MacBook Pro. For something so thin and light, the sound is huge. And with a wide dynamic range, optimal balance, and a crisp, expressive quality, these speakers might sound too good to be true. That's because the design was labored painstakingly to maximize the quality of every decibel you hear. Dual built-in microphones are great for when you want to be heard. If you're making a FaceTime call, for example, the mics reduce background noise from behind the notebook. And when you use Dictation, they create an adaptive audio beam that intelligently adjusts to detect your voice - instead of the noise around you.
  • FaceTime HD camera
    Centered just above the widescreen Retina display on MacBook Pro is an advanced FaceTime HD camera, with an image sensor that produces accurate colors and reduced image noise even in low light. The sophisticated image processor produces sharper images and reduced motion blur. And the face detection feature automatically adjusts exposure and white balance to complement your face and skin tone, so you always look your best - no matter what lighting is behind you.
  • Multi-touch trackpad and backlit keyboard
    In OS X, Multi-touch is an essential part of how you interact with your Mac. Using realistic, intuitive gestures, you can switch between apps, navigate your content, and get the most out of your desktop space. MacBook Pro features a Multi-touch trackpad with a large, all-glass button surface. So you can tap, pinch, swipe, and click away comfortably. Thin and light, MacBook Pro is designed to go anywhere - including places with less-than-stellar lighting. A built-in sensor detects changes in ambient light and adjusts the keyboard and display brightness automatically. So you're never left in the dark.
Apple MacBook Pro with Retina display - 13.3" - Intel Core i5 - 8 GB RAM - 512 GB SSD - UK
Notebook
Operating System
macOS Sierra 10.12
Intel Core i5 (4th Gen) - 2.8 GHz, up to 3.3 GHz / 3 MB Cache
8 GB DDR3L (provided memory is soldered)
Storage
512 GB SSD
Display
13.3" LED backlight 2560 x 1600 / WQXGA
Graphics
Intel Iris Graphics
Input Device
Trackpad
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac
Up to 9 hours
31.4 cm x 21.9 cm x 1.8 cm
1.57 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year , Technical support - phone consulting - 90 days
Notebook
Operating System
Apple macOS Sierra 10.12
Processor / Chipset
CPU
Intel Core i5 (4th Gen) 2.8 GHz
Max Turbo Speed
3.3 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Integrated memory controller, Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
DDR3L SDRAM
Speed
1600 MHz
Storage
Main Storage
512 GB SSD
Display
13.3" - IPS
LCD Backlight Technology
LED backlight
Resolution
2560 x 1600 (WQXGA)
Widescreen
Audio & Video
Graphics Processor
Intel Iris Graphics
Camera
Video Resolutions
1280 x 720
Sound
Stereo speakers, two microphones
Input
Keyboard, trackpad
Keyboard Backlight
Keyboard Layout
Multi-touch touchpad, ambient light sensor
Communications
Wireless
Lithium polymer
71.8 Wh
Run Time
Up to 9 hours
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
60 Watt
Connections & Expansion
2 x USB 3.0 , 2 x Thunderbolt 2 , HDMI , Headphone output
Memory Card Reader
Yes (SDXC Card)
Software
Software Included
Drivers & Utilities, Apple QuickTime, Apple iTunes, Apple Mac OS X Mail, Apple Mac OS X Chess, Apple iPhoto, Apple iMovie, Apple DVD Player, Apple Safari, Apple GarageBand, Apple Dashboard, Apple Spotlight, Photo Booth, Apple Time Machine, Apple Mac App Store, Apple FaceTime, Apple Automator, Apple Launchpad, Apple Mission Control, Apple Preview, Apple Calculator, Apple Dictionary, Apple Image Capture, Apple Stickies, Apple TextEdit, Apple System Preferences, Maps, Reminders, Contacts, Notes, Calendar, Apple AirDrop, Notification Center, Messages, Dictation, iCloud, Game Center, Apple AirPlay, Apple Font Book, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers, Facebook, Twitter
Case Material
Aluminum
Power adapter
Localization
1.57 kg
Sustainability Information
ENERGY STAR Certified
10 °C
35 °C
0 - 90% (non-condensing)
