Powered by a 3rd generation IntelĀ® i5 processor and A 500GB hard drive and 4GB of RAM provide the storage and speed you need for expansive computing, no matter the task.
Feature-rich, it hosts full screen apps, auto saving, built-in sharing, a games centre, calendars and contacts, notifications, Photo Booth, heightened security and built-in social networking.
With the iCloud you can share files seamlessly between your Apple devices. Enjoy easy, real-time transferring of you mail, calendars, contacts, notes and more, so you can access them wherever you are - it's automatic too, so you don't have do a thing.
Precision graphics
The new integrated Intel HD Graphics 4000 processor improves performance by up to 60% over previous models, delivering a smooth, rich graphics experience that makes the most of media, photos and general browsing alike.
Combined with the 13.3-inch LED wide-screen display you can enjoy work and play with the crisp, vivid visuals you expect from a Macbook Pro.
iCloud
iCloud letsyou store and access content and media from any other Apple device you choose, including the iPhone and iPad.
Plus, if you take a picture with your iPhone, iCloud will add it to all your other devices - ideal for organising work and pleasure.
Thunderbolt
Also featured is Apple's innovative Thunderbolt port that offers data transfer speeds over 20 times faster than USB 2.0 and 12 times faster than FireWire 800. It also delivers smooth video and eight-channel audio and easily hooks up with HDMI-compatible devices via an adapter.
Connected
When you're not making the most of the graphics for work, you can use the Macbook Pro to chat via the internet using the integrated webcam or simply surf your favourite sites quickly and easily with the slick Safari web browser.
Plus, integrated WiFi connectivity means all you need is a wireless hotspot and the web is yours to enjoy.
The multi-touch trackpad provides accurate cursor control and supports Apple's gesture control, a useful addition that will have you swiping, pinching and tapping your way around your files and favourite programs in no time at all.
In addition to all this, the Apple MacBook Pro MD101B/A 13" Laptop offers a remarkable battery life of up to 7 hours as well as a whole host of other great Mac features
It makes quicker work of everything
When your goal is to build the high-performance notebook of the future, you begin at its foundation. For this MacBook Pro, that foundation was flash. Because when you build a notebook around an all-flash architecture, not only is everything more durable, reliable, and battery efficient - everything is fast. Really, really fast. -
Matching power for power
A long battery life is impressive for any notebook. But for a high-performance notebook with an ultra-high-resolution display, top-of-the-line processors and graphics, and a superslim design, it's absolutely remarkable. The built-in battery gives you up to 1000 full charge and discharge cycles. Which means you can put your MacBook Pro to sleep, and it'll come back on instantly - after a day, a week, or even a month. -
Advanced speaker design
You haven't heard it all until you've heard the speakers inside the MacBook Pro. For something so thin and light, the sound is huge. And with a wide dynamic range, optimal balance, and a crisp, expressive quality, these speakers might sound too good to be true. That's because they labored painstakingly over the design to maximize the quality of every decibel you hear. -
They'll hear you loud and clear
Dual built-in microphones are great for when you want to be heard. If you're making a FaceTime call, for example, the microphones reduce background noise from behind the notebook. And when you use dictation, they create an adaptive audio beam that intelligently adjusts to detect your voice - instead of the noise around you. -
A brighter way to work
Thin and light, this notebook is designed to go anywhere - including places with less-than-stellar lighting. A built-in sensor detects changes in ambient light and adjusts the keyboard brightness automatically. So you're never left in the dark.
- Apple MacBook Pro - 13.3" - Core i5 - OS X 10.8 Mountain Lion - 4 GB RAM - 500 GB HDD
- System Type
- Notebook
- Operating System
- Processor
- Intel Core i5 2.5 GHz ( 3.1 GHz ) / 3 MB Cache
- Memory
- 4 GB DDR3
- Storage
- 500 GB HDD / 5400 rpm
- Optical Drive
- DVD-Writer DL
- Display
- 13.3" LED backlight 1280 x 800 / WXGA
- Graphics
- Intel HD Graphics 4000
- Networking
- 802.11n, Bluetooth 4.0 , Gigabit Ethernet
- Battery
- Up to 7 hours
- 32.5 cm x 22.7 cm x 2.41 cm
- 2.06 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified , EPEAT Gold
- 1 year warranty
- System Type
- Notebook
- Operating System
- Apple OS X 10.9 Mountain Lion
- 1 year warranty
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0
- RAM
- 4 GB ( 2 x 2 GB )
- Max RAM Supported
- 8 GB
- Technology
- DDR3 SDRAM
- Speed
- 1600 MHz / PC3-12800
- Form Factor
- SO DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Hard Drive
- Interface
- Serial ATA-300
- Optical Drive
- DVD±RW (±R DL) - fixed
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1280 x 800 ( WXGA )
- Widescreen
- Image Aspect Ratio
- 16:10
- Glossy
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Dynamic Video Memory Technology 5.0
- Camera
- Integrated webcam
- Capture Resolutions
- 1280 x 720
- Sound
- Stereo speakers, subwoofer , microphone
Input
- Trackpad, backlit keyboard
- Keyboard Layout
- English
- Multi-touch touchpad, ambient light sensor
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Technology
- Lithium polymer
- Capacity
- 63.5 Wh
- Run Time
- Up to 7 hours
AC Adapter
- Input
- AC 120/230 V ( 50/60 Hz )
- Output
- 60 Watt
Connections & Expansion
- LAN , FireWire 800 , 2 x USB 3.0 , Thunderbolt , Headphone/microphone combo jack
- Memory Card Reader
- Yes ( SD Card, SDHC Memory Card, SDXC Memory Card )
Software
- Software Included
- Drivers & Utilities, Apple QuickTime, Apple iTunes, Apple Mac OS X Mail, Apple iCal, Apple iLife, Apple Address Book, Apple Safari, Apple Spotlight, Photo Booth, Apple Quick Look, Apple Time Machine, Apple Mac App Store, Apple FaceTime, Apple Launchpad, Apple Mission Control, Apple AirDrop, Apple Resume, Apple Auto Save, Apple Versions
- Case Material
- Aluminum
- Included Accessories
- Cleaning cloth
- Localization
- 32.5 cm
- 22.7 cm
- 2.41 cm
- 2.06 kg
- EPEAT Compliant
- EPEAT Gold
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- 10 °C
- 35 °C
- 0 - 90% (non-condensing)
