The M3 chip brings even greater capabilities to the super-portable 15-inch MacBook Air. With up to 18 hours of battery life(1) and a spacious Liquid Retina display, you can take it anywhere and blaze through work and play.
- LEAN. MEAN. M3 MACHINE — The blazing-fast MacBook Air with the M3 chip is a super-portable laptop that sails through work and play.
- BUILT FOR APPLE INTELLIGENCE: Apple Intelligence helps you write, express yourself and get things done effortlessly. It draws on your personal context while setting a brand-new standard for privacy in AI. Coming in beta in US English later this year(1).
- PORTABLE DESIGN — Lightweight and just over 11 millimetres thin, so you can take MacBook Air anywhere you go.
- GET MORE DONE FASTER—The powerful 8-core CPU and 10-core GPU of the Apple M3 chip keep things running smoothly.
- UP TO 18 HOURS OF BATTERY LIFE(2) — Amazing, all-day battery life so you can leave the power adapter at home.
- MORE ROOM FOR WHAT YOU LOVE — The 15.3-inch Liquid Retina display(3) supports one billion colours.
- LOOK SHARP, SOUND GREAT — Everything looks and sounds amazing with a 1080p HD camera, three mics, and six speakers with Spatial Audio.
- APPS FLY WITH APPLE SILICON — All your favourites, from Microsoft 365 to Adobe Creative Cloud, run lightning fast in macOS.(4)
- GET CONNECTED — MacBook Air features two Thunderbolt ports, a headphone jack, Wi-Fi 6E,(5) Bluetooth 5.3 and a MagSafe charging port. And connect up to two external displays with the laptop lid closed.
- IF YOU LOVE IPHONE, YOU’LL LOVE MAC — MacBook Air works like magic with your other Apple devices.(6) Start an email on your iPhone and finish it on your Mac. Send text messages from your Mac. And much more.
Configurable options are available.
(1)Apple Intelligence will be available in beta on Mac with M1 and later, with Siri and device language set to US English, as part of macOS Sequoia later this year.
(2)Battery life varies by use and configuration. See apple.com/uk/batteries for more information.
(3)The display on the 15-inch MacBook Air has rounded corners at the top. When measured as a standard rectangular shape, the screen is 15.3 inches diagonally (actual viewable area is less).
(4)Apps are available on the App Store.
(5)Wi-Fi 6E available in countries and regions where supported.
(6)Requires iCloud and internet connection.
The blazing-fast MacBook Air with the M3 chip is a super-portable laptop that sails through work and play. -
PORTABLE DESIGN
Lightweight and just over 11 millimetres thin, so you can take MacBook Air anywhere you go. -
The powerful 8-core CPU and up to 10-core GPU of the Apple M3 chip keep things running smoothly. -
Amazing, all-day battery life so you can leave the power adapter at home. -
The 15.3-inch Liquid Retina display supports one billion colours. -
Everything looks and sounds amazing with a 1080p HD camera, three mics, and four speakers with Spatial Audio. -
All your favourites, from Microsoft 365 to Adobe Creative Cloud, run lightning fast in macOS. -
GET CONNECTED
MacBook Air features two Thunderbolt ports, a headphone jack, Wi-Fi 6E,4 Bluetooth 5.3 and a MagSafe charging port. And connect up to two external displays with the laptop lid closed. -
IF YOU LOVE IPHONE, YOU'LL LOVE MAC
MacBook Air works like magic with your other Apple devices.5 Start an email on your iPhone and finish it on your Mac. Send text messages from your Mac. And much more.
- Apple MacBook Air - 15.3" - Apple M3 - 8 GB RAM - 512 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Apple macOS Sonoma 14.0
- Processor
- Apple M3
- Neural Processor Unit (NPU)
- 16-core Neural Engine
- Memory
- 8 GB (unified memory)
- Storage
- 512 GB SSD
- Display
- 15.3" 2880 x 1864 / WQXGA+ - 224 ppi
- Graphics
- Apple M3 10-core
- Input Device
- Force Touch trackpad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3
- Battery
- Up to 18 hours
- Ambient light sensor
- Security
- Fingerprint reader
- Space grey
- 34.04 cm x 23.76 cm x 1.15 cm
- 1.51 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Carbon Footprint
- 167 kg carbon emissions
- Rare Earth Materials
- 99% recycled rare earth elements
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- Product Type
- Notebook
- Operating System
Processor / Chipset
- CPU
- Apple M3
- Number of Cores
- 8-core
- RAM
Storage
- Main Storage
- 512 GB SSD soldered
Display
- 15.3" - IPS
- Resolution
- 2880 x 1864 (WQXGA+)
- Widescreen
- Pixel Density (ppi)
- 224
- Image Brightness
- 500 cd/m²
- Colour Support
- 1 billion colours
- BFR/PVC-free, Mercury free, Zoom, arsenic-free glass, HDR10 compatible, HLG gamma, Liquid Retina display, P3 Wide Color Gamut, True Tone technology, Dolby Vision, HDR compliance
- Keyboard Name
- Apple Magic Keyboard with Touch ID
Audio & Video
- Graphics Processor
- Apple M3 10-core
- Max Monitors Supported
- 2 external monitor(s)
- Video System Features
- Hardware-accelerated H.264, HEVC, ProRes and ProRes RAW, video decode engine, ProRes encode and decode engine, video encode engine, AV1 decode
- Camera
- Yes - 1080p
- Camera Features
- FaceTime HD camera, advanced image signal processor (ISP)
- Sound
- Six speakers, 3-microphone array
- Dolby Digital Plus, Dolby Atmos, Dolby Digital
- Audio Features
- Output: Spatial Audio support; Input: voice isolation mode, wide spectrum microphone mode, enhanced voice clarity
Input
- Keyboard, Force Touch trackpad
- Keyboard Layout
- UK
- Pressure sensitivity, multi-touch touchpad, Multi-Touch Gesture Recognition, force click, Touch ID sensor
Communications
- Wireless
- Technology
- Lithium polymer
- Capacity
- 66.5 Wh
- Run Time
- Up to 18 hours
- Battery Run Time
- Web browsing over Wi-Fi: up to 15 hour(s) , Video playback: up to 18 hour(s)
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 35 Watt
Connections & Expansion
- Interfaces Details
- 2 x USB4/Thunderbolt 3/DisplayPort (charging) , Headphone output
Software
- Software Included
- Apple iMovie, Apple Safari, Apple GarageBand, Photo Booth, Apple Time Machine, Apple FaceTime, Apple Preview, Mail, Maps, Photos, Reminders, App Store, Music, Contacts, Stocks, Notes, Calendar, Siri, Messages, Dictation, Apple Keynote, Apple Pages, Apple Numbers, News, Voice Memos, Podcasts, Home, Apple TV, Find My, Apple Books, Apple Shortcuts, Apple QuickTime Player, Apple Freeform
- Space grey
- Case Material
- Aluminum
- Integrated Options
- Security
- VoiceOver screen reader, Voice Control, Switch Control, 100 GB/s memory bandwidth, Live Captions, reduce motion, increase contrast
- Included Accessories
- USB-C dual port compact power adapter, USB-C to MagSafe 3 charge cable (2m)
- Localization
- 1.51 kg
Sustainability Information
- ENERGY STAR Certified
- Carbon Footprint
- Product Recycled Content
- 50 % - recycled materials
- 10 °C
- 35 °C
- 0 - 90% (non-condensing)
