With an impressive run time of up to 10 hours, you can work unplugged the whole day with the Apple Macbook Air. Enjoy long standby time of up to 30 days, so even if you’re away on holiday, you can just pick up your Macbook from where you left off.
Offering 802.11ac wireless technology that’s three times faster than the Wi-Fi of the previous generation, you can work efficiently and productively no matter where you’re based. Simply connect your Macbook Air to an 802.11ac base station (such as AirPort Time Capsule or AirPort Extreme) to take advantage of speedier Wi-Fi.
Its fifth-generation Intel Core i5 processor and Intel HD Graphics 6000 equip you with all the power you need, whatever the task at hand. From web browsing to photo editing, you can complete tasks quickly in Full HD visual quality.
The Macbook Air 11 inch model comes complete with Apple’s iconic, sleek design. This notebook is also incredibly lightweight – at just a little over 1kg, it’s ideal for carrying with you to work on the move.
Long battery life
From your morning coffee till your evening commute, you can work unplugged. When it's time to kick back and relax, you can get long hours of iTunes movie playback. And with long standby time, you can go away for weeks and pick up right where you left off. -
Thin, light, powerful
Whatever the task, the fifth-generation Intel Core i5 processor with Intel HD graphics are up to it. From editing photos to browsing the web, everything happens ultrafast. And all that power is encased in an incredibly thin unibody design. -
802.11ac Wi-Fi support
With the latest 802.11ac technology, MacBook Air takes Wi-Fi speeds over the top. Connect to an 802.11ac base station - including AirPort Extreme or AirPort Time Capsule - and experience wireless performance up to 3x faster than the previous Wi-Fi generation. 802.11ac also delivers expanded range, so you can work more freely than ever. -
Fast all-flash storage
Flash storage in MacBook Air is up to 17x faster than a 5400-rpm notebook hard drive. So everything you do is snappy and responsive. MacBook Air even wakes up fast, thanks to flash storage and fifth-generation Intel Core processors.
- Apple MacBook Air - 11.6" - Intel Core i5 - 4 GB RAM - 128 GB SSD - UK
- Product Type
- Notebook
- Operating System
- macOS Sierra 10.12
- Processor
- Intel Core i5 (5th Gen) - 1.6 GHz, up to 2.7 GHz / 3 MB Cache
- Memory
- 4 GB LPDDR3
- Storage
- 128 GB SSD
- Display
- 11.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 6000
- Input Device
- Trackpad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac
- Battery
- Up to 10 hours
- 30 cm x 19.2 cm x 1.7 cm
- 1.08 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- Product Type
- Notebook
- Operating System
- Apple macOS Sierra 10.12
Processor / Chipset
- CPU
- Intel Core i5 (5th Gen) 1.6 GHz
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Integrated memory controller, Intel Turbo Boost Technology 2.0
- RAM
- 4 GB
- Max RAM Supported
- 8 GB
- Technology
- LPDDR3 SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 128 GB SSD
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Glossy
Audio & Video
- Graphics Processor
- Camera
- Sound
- Stereo speakers, two microphones
Input
- Keyboard, trackpad
- Keyboard Layout
- UK
- Multi-touch touchpad, ambient light sensor
Communications
- Wireless
- Technology
- Lithium polymer
- Capacity
- 38 Wh
- Run Time
- Up to 10 hours
- Battery Run Time
- Web browsing over Wi-Fi: up to 9 hours , Video playback: up to 10 hours , Standby time: up to 30 days
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- 2 x USB 3.0 , Headphone output , Thunderbolt 2
Software
- Software Included
- Drivers & Utilities, Apple QuickTime, Apple iTunes, Apple Mac OS X Mail, Apple Mac OS X Chess, Apple iPhoto, Apple iMovie, Apple DVD Player, Apple Safari, Apple GarageBand, Apple Dashboard, Apple Spotlight, Photo Booth, Apple Time Machine, Apple Mac App Store, Apple FaceTime, Apple Automator, Apple Launchpad, Apple Mission Control, Apple Preview, Apple Calculator, Apple Dictionary, Apple Image Capture, Apple Stickies, Apple TextEdit, Apple System Preferences, Maps, Reminders, Contacts, Notes, Calendar, Apple AirDrop, Notification Center, Messages, Dictation, iCloud, Game Center, Apple AirPlay, Apple Font Book, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers, Facebook, Twitter
- Case Material
- Aluminum
- Included Accessories
- Power adapter
- Localization
- 1.08 kg
Sustainability Information
- ENERGY STAR Certified
- 10 °C
- 35 °C
- 0 - 90% (non-condensing)
