Apple Mac Studio is a small computer that lets you do big things. It's built around the M2 Max chip. That means you'll have 12 CPU cores and 30 GPU cores speeding through your workflows. Doesn't matter if you're rendering, editing, or transcoding – Mac Studio doesn't waste your time. And it doesn't waste your space either. It's less than 10 cm tall and 20 cm wide. The clever thermal system makes it whisper quiet, too. You wouldn't know how much power is sitting on your desk.
Good to know
- With 32 GB unified memory you can jump between apps and multitask at full speed
- There's four Thunderbolt 4 ports and an HDMI port that let you connect 5 high-res displays
- You'll have plenty of space for you files on the super-fast 512 GB SSD
- Don't let internet slow you down – there's WiFi 6E and a 10 Gb Ethernet port
- The enclosure is made from 100% recycled aluminium, so it's kind to the environment, too
Legal
Configurable options are available. ¹Testing conducted by Apple in April and May 2023 using pre-production Mac Studio systems with Apple M2 Ultra, 24-core CPU, 76-core GPU and 192GB of RAM, and production 3.6GHz 10-core Intel Core i9-based 27-inch iMac systems with Radeon Pro 5700 XT graphics with 16GB of GDDR6 and 128GB of RAM. All systems configured with 8TB SSD. Open source project built with Xcode 14.3 with Apple Clang 14.0.3, Ninja 1.10.0.git and CMake 3.25.0. Mac Studio systems tested with an attached 5K display. Performance tests are conducted using specific computer systems and reflect the approximate performance of Mac Studio and iMac. ²Testing conducted by Apple in April and May 2023 using pre-production Mac Studio systems with Apple M2 Ultra, 24-core CPU, 76-core GPU and 192GB of RAM, and production 3.6GHz 10-core Intel Core i9-based 27-inch iMac systems with Radeon Pro 5700 XT graphics with 16GB of GDDR6 and 128GB of RAM. All systems configured with 8TB SSD. OTOY Octane X Prime 2022.1.1 tested using a scene with complex materials and 35 million triangles. Mac Studio systems tested with an attached 5K display. Performance tests are conducted using specific computer systems and reflect the approximate performance of Mac Studio and iMac. ³1GB = 1 billion bytes and 1TB = 1 trillion bytes; actual formatted capacity less. 4Wi-Fi 6E available in countries and regions where supported. 5Requires iCloud and internet connection.
- Apple Mac Studio - USFF M2 Max - 32 GB - SSD 512 GB
- Personal computer - USFF
- Localisation
- Processor
- Apple M2 Max (12-core)
- Processor Main Features
- Video decode engine, 2 video encode engines, 2 ProRes encode and decode engines
- Neural Processor Unit (NPU)
- 16-core Neural Engine
- RAM
- 32 GB
- Hard Drive
- SSD 512 GB
- Optical Storage
- No optical drive
- Card Reader
- Graphics Controller
- Apple M2 Max 30-core
- Supported Digital Video Standards
- H.264, HEVC, ProRes, ProRes RAW
- Networking
- 1GbE, 802.11a, 10GbE, 802.11b/g/n, Wi-Fi 5, 5GbE, 2.5GbE, Wi-Fi 6E, Bluetooth 5.3
- Power
- (50/60 Hz)
- OS Provided
- Apple macOS Ventura 13.0
- Software Included
- Apple iMovie, Apple Safari, Apple GarageBand, Photo Booth, Apple Time Machine, Apple FaceTime, Apple Preview, Mail, Maps, Photos, Reminders, App Store, Music, Contacts, Stocks, Notes, Calendar, Siri, Messages, Dictation, Apple Keynote, Apple Pages, Apple Numbers, News, Voice Memos, Podcasts, Home, Apple TV, Find My, Apple Books, Apple Shortcuts, Apple QuickTime Player, Apple Freeform
- Silver
- 19.7 cm x 19.7 cm x 9.5 cm
- 2.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- Personal computer
- Product Form Factor
- USFF
- Built-in Devices
- Speaker
- Silver
- Localisation
Processor / Chipset
- CPU
- Apple M2 Max
- Number of Cores
- 12-core
- CPU Qty
- 1
- Max CPU Qty
- 1
RAM
- Installed Size
- 32 GB
- Configuration Features
- Unified memory
Hard Drive
- SSD
- Capacity
- 1 x 512 GB
Optical Storage
- No optical drive
Card Reader
- Card reader
- Supported Flash Memory Cards
- SDXC UHS-II Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Bandwidth
- 400 GBps
- Video Interfaces
- HDMI, USB-C
- Max Monitors Supported
- 5
Multimedia Functionality
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, 10 Gigabit Ethernet, IEEE 802.11n, IEEE 802.11ac, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet, IEEE 802.11ax (Wi-Fi 6E), Bluetooth 5.3
- 4 x Thunderbolt 4/USB4/DisplayPort - Type C (4 rear) , 2 x USB - Type A (2 rear) , 1 x HDMI , 1 x LAN (10Gigabit Ethernet) - RJ-45 (1 rear) , 1 x headphones - mini-jack (1 rear) , 2 x USB-C - Type C (2 in front)
- BFR-free, PVC-free, Beryllium-free, Mercury-free
- Power supply
- Voltage Required
- AC 100-240 V (50/60 Hz)
- 370 Watt
Operating System / Software
- OS Provided
- Software
Sustainability Information
- ENERGY STAR Certified
- 19.7 cm
- 19.7 cm
- 9.5 cm
- 2.7 kg
- 10 °C
- 35 °C
- 5 - 90% (non-condensing)
