Apple Mac Pro Xeon W3530 2.8 GHz 3GB 1TB MacOS X 10.6
Quicklinx: 74T1WS00 Mfr#: MC560B/A
  • Xeon
  • ATI Radeon HD 5770
  • IEEE 802.11n
Whether you're editing feature films or scoring them, composing symphonies or visualizing mass spectrometry analyzes, Mac Pro makes it easier than ever to create your personal dream machine: a powerful system that not only meets your needs today but, thanks to an ingeniously designed enclosure, expands easily to meet tomorrow's challenges as well.
The easy-access interior of the Mac Pro feels like the well-organized workstation it is. No rat's nest of components here. You don't need to turn the system on its side or struggle to reach into awkward spaces to make changes. Just remove the side panel for instant access to everything. Slide out the processor tray to add memory. Slide out drive bays to add storage. Slide a simple bar to change up to four expansion cards at once. And with plenty of I/O ports both front and back, you'll have room for all your external devices.
When it's time to upgrade, a quick slide of the retention bar frees up the four expansion card slots for easy access. Thanks to a thumbscrew PCI bracket, you can swap out cards without any tools.
The Mac Pro comes with four drive bays for an enormous amount of internal storage. For faster access to your data, you can also configure your Mac Pro with up to four solid-state drives. The bays are direct-attach and cable free, so it's easy to add or remove drives. Just attach the drive carrier to a drive and slide the drive into place. There are no connectors or cables to contend with. Lock the drives with the side door latch, and you're done.
Install more memory in your Mac Pro in a snap. Literally. The easy-access interior lets you slide out the processor tray in one smooth motion, then simply snap new memory into place. You don't have to dig around inside the computer or wrestle with wires or cables.
The Mac Pro is built with a recyclable aluminum enclosure. Aluminum is very desirable to recyclers, which means the raw materials used in the Mac Pro can be reused in other products. Apple also simplified the internal design, replacing over 6 feet of cables with more material-efficient connectors that allow easy disassembly at end of life. In addition, one of the few remaining plastic assemblies in the Mac Pro is made from postconsumer recycled plastic.
  • Expansion made easy
  • Tool-less PCI
  • Slide-in storage
  • Snap-in memory
  • Front and back I/O
    There are plenty of places to connect external devices to your Mac Pro.
  • Powerfully efficient
    The Mac Pro meets the stringent low power requirements set by the EPA, giving it ENERGY STAR qualification.
  • Highly recyclable
Apple Mac Pro - tower - Xeon W3530 2.8 GHz - 3 GB - HDD 1 TB - QWERTY UK
Personal computer - tower
Intel Xeon W3530 / 2.8 GHz (3.06 GHz) (Quad-Core)
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology
Cache Memory
8 MB L3 Cache
Cache Per Processor
8 MB
RAM
3 GB (installed) / 16 GB (max) - DDR3 SDRAM - ECC
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
HDD 1 TB - SATA 3Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
PCIe 2.0 x16 - ATI Radeon HD 5770
Video Memory
1 GB GDDR5 SDRAM
Audio Output
Integrated
GigE, 802.11a, 802.11b/g/n, Bluetooth 2.1 EDR
Keyboard
QWERTY UK
OS Provided
Apple MacOS X Lion 10.7
Software Included
Apple QuickTime, Apple iTunes, Apple Mac OS X Mail, Apple iChat, Apple iCal, Apple DVD Player, Apple iLife, Apple Address Book, Apple Safari, Apple Dashboard, Apple Spotlight, Apple XCode Developer Tools, Front Row, Photo Booth, Apple Spaces, Apple Quick Look, Apple Time Machine
20.6 cm x 47.5 cm x 51.1 cm
18.1 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - parts and labour - 1 year , Technical support - phone consulting - 90 days
Personal computer
Product Form Factor
Tower
Processor / Chipset
CPU
Intel Xeon W3530
Clock Speed
2.8 GHz
Max Turbo Speed
3.06 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Cache Memory
Installed Size
L3 Cache - 8 MB
Cache Per Processor
8 MB
RAM
Installed Size
3 GB / 16 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1066 MHz
DIMM 240-pin
Configuration Features
3 x 1 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 3Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Channel Qty
4
Optical Storage
DVD±RW (±R DL) DVD-Writer
Read Speed
32x (CD) / 18x (DVD)
Write Speed
32x (CD) / 18x (DVD±R) / 8x (DVD±R DL)
CD / DVD Rewrite Speed
32x (CD) / 6x (DVD-RW) / 8x (DVD+RW)
Monitor
Monitor Type
None.
Graphics Controller
Plug-in card
Interface Type
PCIe 2.0 x16
Graphics Processor
ATI Radeon HD 5770
Video Memory
1 GB GDDR5 SDRAM
Video Interfaces
DVI, DisplayPort
Audio Output
Integrated
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Apple Keyboard with Numeric Keypad
USB
Localization & Layout
QWERTY UK
Built-in two USB 2.0 ports
Mouse
Wireless
Laser
Bluetooth
Multi-Touch
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 2.1 EDR
Bays
4 (total) / 3 (free) x internal 3.5" x 1/3H , 2 (total) / 1 (free) x external
Slots
4 (total) / 1 (free) x memory , 1 (total) / 0 (free) x PCIe 2.0 x16 - full-length , 1 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 2.0 x4 - full-length
2 x LAN (Gigabit Ethernet) , 4 x FireWire 800 (2 in front) , 5 x USB 2.0 (2 in front) , 1 x headphones (1 in front) , 1 x TOSLINK , 1 x TOSLINK , 1 x audio line-in , 1 x audio line-out , 1 x DVI-I (dual link) , 2 x Mini DisplayPort
USB extension cable
Power supply
Operating System / Software
OS Provided
Software
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
20.6 cm
47.5 cm
51.1 cm
18.1 kg
10 °C
35 °C
5 - 95%
