Apple Mac Pro Intel Xeon E5 16GB 256GB OS X Mavericks 10.9
Quicklinx: 949PWS00 Mfr#: MD878B/A
Processor Type: Xeon
Operating System: Apple macOS Catalina 10.15
Installed Memory: 16GB, 16GB
Hard Drive Capacity: 256GB
Storage Type: SSD
  • Xeon
  • Bluetooth 4.0
  • IEEE 802.11n
£2,499.17 ex VAT
£2,999.00 inc VAT
Mac Pro is the professional desktop computer reinvented from the inside out. Arranging the most advanced technologies available around a unified thermal core allowed to make this the most powerful and expandable Mac ever, yet also unbelievably compact and quiet.
Mac Pro comes standard with dual AMD FirePro workstation-class GPUs, each with up to 6 GB of dedicated VRAM and 2048 stream processors, providing up to 264 GB/s of memory bandwidth and up to 3.5 teraflops. That's enough power to edit full-resolution 4K video while simultaneously rendering effects in the background - and still connect up to three 4K displays.
  • Stunning design
  • Dual workstation-class GPUs
  • Faster PCIe-based flash storage
    Next-generation PCIe-based flash storage is up to 2.4 times faster than SATA-based solid-state drives and up to 10 times faster than a 7200-rpm SATA hard drive. So booting up, launching apps. even opening massive files happens in, well, a flash.
  • Thunderbolt 2
    Build your dream workstation - without being limited to the space inside the enclosure. Thunderbolt 2 delivers throughput of up to 20 Gb/s tc each external device. And since each Thunderbolt e port allows you to daisy-chain up to six peripherals, you can connect massive amounts of storage, add a PCI Express expansion chassis, and work with the latest 4K displays.
Apple Mac Pro - tower - Xeon E5 3.5 GHz - 16 GB - 256 GB - UK
Personal computer - tower
1 x Intel Xeon E5 / 3.5 GHz (3.9 GHz) (6-core)
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology
Cache Memory
12 MB L3 Cache
Cache Per Processor
12 MB
RAM
16 GB (installed) / 64 GB (max) DDR3 SDRAM - ECC
Hard Drive
1 x SSD 256 GB - PCI Express
Optical Storage
No optical drive
Multi-GPU Configuration
Dual GPU
Graphics Controller
AMD FirePro D500
Video Memory
6 GB GDDR5 SDRAM
Audio Output
Integrated
GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, 802.11ac
Keyboard
OS Provided
16.7 cm x 16.7 cm x 25.1 cm
5 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - parts and labour - 1 year , Technical support - phone consulting - 90 days
Personal computer
Product Form Factor
Tower
Built-in Devices
Speaker
Processor / Chipset
CPU
Max Turbo Speed
3.9 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
L3 Cache - 12 MB
Cache Per Processor
12 MB
RAM
Installed Size
16 GB / 64 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1866 MHz
Configuration Features
4 x 4 GB
Hard Drive
SSD
1 x 256 GB
Interface Type
PCI Express
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Dual GPU
Graphics Processor
AMD FirePro D500
Video Memory
6 GB GDDR5 SDRAM
Video Interfaces
HDMI
Audio Output
Integrated
Keyboard
Localization & Layout
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
6 x Thunderbolt 2 , 4 x USB 3.0 , 2 x LAN (Gigabit Ethernet) , 1 x SPDIF output/headphones , 1 x HDMI , 1 x headphones/microphone
Power supply
Nominal Voltage
Operating System / Software
OS Provided
Software
Apple QuickTime, Apple iTunes, Apple Mac OS X Mail, Apple Mac OS X Chess, Apple iMovie, Apple DVD Player, Apple Safari, Apple GarageBand, Apple Dashboard, Photo Booth, Apple Time Machine, Apple Mac App Store, Apple FaceTime, Apple Automator, Apple Launchpad, Apple Mission Control, Apple Preview, Apple Calculator, Apple Dictionary, Apple Image Capture, Apple Stickies, Apple TextEdit, Apple System Preferences, Maps, Reminders, Contacts, Notes, Calendar, Apple AirDrop, Notification Center, Messages, Dictation, iCloud, Game Center, Apple AirPlay, Apple Font Book, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
16.7 cm
16.7 cm
25.1 cm
5 kg
10 °C
35 °C
5 - 95% (non-condensing)
Apple Mac Pro Intel Xeon E5 16GB 256GB OS X Mavericks 10.9 Bundle deal on Apple Mac Pro Intel Xeon E5 16GB 256GB OS X Mavericks 10.9
£2,598.34
949P C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
949P C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.34
949P C2G 5m Select High Speed HDMI with Ethernet In Stock £21.17
949P C2G 10m Select High Speed HDMI with Ethernet In Stock £40.63
949P C2G 15m Select High Speed HDMI with Ethernet In Stock £55.03
Storage Type: SSD
Processor Model: E5
Type: Personal computer
Case Style: Tower
Display: no
Optical Storage: None
Brand: Apple
Price Range Ex VAT: 1500+
