Apple Mac Pro 3.7GHz Quad-Core Intel Xeon E5 12GB RAM  256GB SSD FirePro 300  OS X 10.9 Mavericks
Quicklinx: 95VGWS00 Mfr#: ME253B/A
  • Xeon
  • Bluetooth 4.0
  • IEEE 802.11n
OS X Mavericks
The Mac Pro runs on Apple's intuitive Mavericks operating system. Simple to navigate yet capable of professional-level computing, it provides an expressive platform for you work and play the way you want. There are over 200 new features and updates compared to the previous generation OS, including improved software and device integration, new apps and enhancements for users with multiple displays.
Unparalleled power
With four cores, eight threads and an impressive 3.7 GHz clock speed, the quad-core Intel® Xeon® runs the most demanding professional-level creative software without issue.
Supporting the processor is 12 GB of DDR3 RAM. Enough for effortless everyday performance, it ensures instant multitasking and work-flow regardless of your project size. You're set for the future too, as there's space for a vast 64 GB should you need more.
Bespoke graphics
The Mac Pro features two bespoke AMD FirePro D300 graphics cards for impressive video, photo and graphics handling.
Featuring 2 GB of GDDR5 of RAM, 1,280 stream processors and a 256-bit memory bus along with support for 4K video quality across multiple monitors, you can enjoy your media and software at its very best.
Solid-state storage
Files storage is provided by a 256 GB solid-state drive. With far-faster data transfer rates than traditional hard drives, an SSD is the ultimate storage option for high-performance computing.
When it comes to backing up, four USB 3.0 ports make light work of backing up even the biggest project files to external media.
Unique design
Completely designed from the ground up, the Mac Pro's internal components are contained in a compact yet durable cylindrical aluminium case. With easily accessible ports, effective cooling and plenty of room for expansion thanks to six Thunderbolt 2 ports, you won't find yourself missing the regular desktop format.
Getting online is simple with twin gigabit Ethernet ports and built-in WiFi while Bluetooth 4.0 provides a quick and stable cable-free connection to mice, keyboards and anything else you use on a daily basis.
Connecting multiple monitors and screens is easy too, and can be done using either the 4K compatible HDMI port or via Thunderbolt.
OVERVIEW
  • Type: Mac Pro
  • Operating system: OS X Mavericks
  • Processor: Intel® Xeon® Processor E5-1620 v2 (3.7 GHz, 3.9 GHz with TurboBoost, 10 MB cache)
  • RAM: 12 GB DDR3
  • Graphics card: Dual AMD FirePro D300 (2 GB GDDR5)
  • Storage: 256 GB SSD
  • Wireless: 802.11 ac
  • Ethernet: Dual Gigabit Ethernet (10/100/1000)
  • Bluetooth: Bluetooth 4.0
  • USB: USB 3.0 x 4
  • Video interface: HDMI x 1, Thunderbolt x6
  • Optical drive: No
  • Speakers: Integrated speaker
  • Stunning design
    Mac Pro is the professional desktop computer reinvented from the inside out. Arranging the most advanced technologies available around a unified thermal core allowed to make this the most powerful and expandable Mac ever, yet also unbelievably compact and quiet.
  • Dual workstation-class GPUs
    Mac Pro comes standard with dual AMD FirePro workstation-class GPUs, each with up to 6 GB of dedicated VRAM and 2048 stream processors, providing up to 264 GB/s of memory bandwidth and up to 3.5 teraflops. That's enough power to edit full-resolution 4K video while simultaneously rendering effects in the background - and still connect up to three 4K displays.
  • Faster PCIe-based flash storage
    Next-generation PCIe-based flash storage is up to 2.4 times faster than SATA-based solid-state drives and up to 10 times faster than a 7200-rpm SATA hard drive. So booting up, launching apps. even opening massive files happens in, well, a flash.
  • Thunderbolt 2
    Build your dream workstation - without being limited to the space inside the enclosure. Thunderbolt 2 delivers throughput of up to 20 Gb/s tc each external device. And since each Thunderbolt e port allows you to daisy-chain up to six peripherals, you can connect massive amounts of storage, add a PCI Express expansion chassis, and work with the latest 4K displays.
Apple Mac Pro - tower - Xeon E5 3.7 GHz - 12 GB - SSD 256 GB
Personal computer - tower
Intel Xeon E5 / 3.7 GHz (3.9 GHz) (Quad-Core)
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology
Cache Memory
10 MB L3 Cache
Cache Per Processor
10 MB
RAM
12 GB (installed) / 64 GB (max) - DDR3 SDRAM - ECC
Hard Drive
SSD 256 GB - PCI Express
Optical Storage
No optical drive
Multi-GPU Configuration
Dual GPU
Graphics Controller
AMD FirePro D300
Video Memory
4 GB GDDR5 SDRAM
Audio Output
Integrated
GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
OS Provided
Apple macOS Sierra 10.12
Software Included
Apple QuickTime, Apple iTunes, Apple Mac OS X Mail, Apple Mac OS X Chess, Apple iMovie, Apple DVD Player, Apple Safari, Apple GarageBand, Apple Dashboard, Photo Booth, Apple Time Machine, Apple Mac App Store, Apple FaceTime, Apple Automator, Apple Launchpad, Apple Mission Control, Apple Preview, Apple Calculator, Apple Dictionary, Apple Image Capture, Apple Stickies, Apple TextEdit, Apple System Preferences, Maps, Reminders, Contacts, Notes, Calendar, Apple AirDrop, Notification Center, Messages, Dictation, iCloud, Game Center, Apple AirPlay, Apple Font Book, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers
16.7 cm x 16.7 cm x 25.1 cm
5 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - parts and labour - 1 year , Technical support - phone consulting - 90 days
Personal computer
Product Form Factor
Tower
Built-in Devices
Speaker
Processor / Chipset
CPU
Intel Xeon E5
Clock Speed
3.7 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
L3 Cache - 10 MB
Cache Per Processor
10 MB
RAM
Installed Size
12 GB / 64 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1866 MHz
Configuration Features
3 x 4 GB
Hard Drive
SSD
1 x 256 GB
Interface Type
PCI Express
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Dual GPU
Graphics Processor
AMD FirePro D300
Video Memory
4 GB GDDR5 SDRAM
Video Interfaces
HDMI
Audio Output
Integrated
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
Slots
4 (total) / 1 (free) x memory
6 x Thunderbolt 2 , 4 x USB 3.0 , 2 x LAN (Gigabit Ethernet) , 1 x SPDIF output/headphones , 1 x HDMI , 1 x headphones/microphone - mini-jack
Power supply
Operating System / Software
OS Provided
Software
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
16.7 cm
16.7 cm
25.1 cm
5 kg
10 °C
35 °C
5 - 95% (non-condensing)
95VG C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
