Apple Lightning to USB Camera Adapter
PRICE DROP!
Clearance
Last Few Remaining
Price Drop
Quicklinx: 8Q3NWS00 Mfr#: MD821ZM/A
£21.54 ex VAT
£25.84 inc VAT
With the Lightning to USB Camera Adapter, it's easy to download photos and videos from your digital camera to your iPad with Retina display or iPad mini, so you can view them on the gorgeous iPad display and share them with family and friends.
After you connect the Lightning to USB Camera Adapter, your iPad automatically opens the photos app, which lets you choose which photos and videos to import, then organizes them into albums. When you sync iPad to your PC or Mac, the photos and videos on your iPad are added to your computer's photo library.
The Lightning to USB Camera Adapter supports standard photo formats, including JPEG and RAW, along with SD and HD video formats, including H.264 and MPEG-4.
Apple Lightning to USB Camera Adapter - Lightning adapter
Cable
Lightning adapter - Lightning / USB
Connector
Lightning - male
Connector (Second End)
USB - female
10.2-inch iPad; 10.5-inch iPad Air; 10.5-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; 5; iPad with Retina display; iPhone 11, 12, 5, 5c, 5s, 6, 6s, 7, 8, SE, X, XR, XS, XS Max; iPod touch
Cable Type
Lightning adapter
Interface Supported
Lightning / USB
Connector
Apple Lightning - male
4 pin USB Type A - female
Apple 10.2-inch iPad (7th generation, 8th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad mini 5 , Apple iPad with Retina display (4th generation) , Apple iPhone 11, 11 Pro, 11 Pro Max, 12, 12 mini, 12 Pro, 12 Pro Max, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, SE (2nd generation), X, XR, XS, XS Max , Apple iPod touch (6G, 7G)
Brand: Apple
Stock Status: In stock
