Brand
Apple Lightning to USB Cable (1m)
Quicklinx: FJ82WS00 Mfr#: MXLY2ZM/A
Device Type: All
Type: Cable
Product Range: Apple
Product Model: Lightning Cable
More than 50 in stock
£17.41 ex VAT
£20.89 inc VAT
This USB 2.0 cable connects your iPhone, iPad, or iPod with Lightning connector to your computer's USB port for syncing and charging. Or you can connect to the Apple USB Power Adapter for convenient charging from a wall outlet.
Apple Lightning cable - Lightning / USB - 1 m
Cable
Length
1 m
Connector
Lightning - male
Connector (Second End)
USB - male
Apple Wireless Charging Case; 10.2-inch iPad; 10.5-inch iPad Air; 10.5-inch iPad Pro; 10.9-inch iPad Air; 11-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; AirPods; AirPods Max; AirPods Pro; iMac Pro; iPad mini 2; 4; 5; iPhone 11, 12, 13, 6s, 7, 8, SE, X, XR, XS, XS Max
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Length
1 m
Recommended Use
Mobile phone, tablet, digital player
Connector
Apple Lightning - male
4 pin USB Type A - male
Apple Wireless Charging Case , Apple 10.2-inch iPad (7th generation, 8th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 10.9-inch iPad Air (4th generation) , Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation) , Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple AirPods (1st generation, 2nd generation, 3rd generation) , Apple AirPods Max , Apple AirPods Pro , Apple iMac (Early 2019, Early 2021, Mid 2017, Mid 2020) , Apple iMac Pro (Late 2017) , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini (1st generation) , Apple iPad mini 2 (2nd generation) , Apple iPad mini 3 (3rd generation) , Apple iPad mini 4 (4th generation) , Apple iPad mini 5 (5th generation) , Apple iPad with Retina display (4th generation) , Apple iPhone 11, 11 Pro, 11 Pro Max, 12, 12 mini, 12 Pro, 12 Pro Max, 13, 13 mini, 13 Pro, 13 Pro Max, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, SE (2nd generation), X, XR, XS, XS Max , Apple iPod nano (7G) , Apple iPod touch (5G, 6G, 7G) , Apple Mac mini (Early 2020, Late 2018, Late 2020) , Apple Mac Pro (Late 2019) , Apple MacBook (Early 2015, Early 2016, Mid 2017) , Apple MacBook Air (Early 2020, Late 2018, Late 2020, Mid 2019) , Apple MacBook Pro (Early 2020, Late 2016, Late 2019, Late 2020, Late 2021, Mid 2017, Mid 2018, Mid 2019)
Device Type: All
Type: Cable
Brand: Apple
Stock Status: In stock
