This USB 2.0 cable connects your iPhone, iPad, or iPod with Lightning connector to your computer's USB port for syncing and charging. Or you can connect to the Apple USB Power Adapter for convenient charging from a wall outlet.
  • Versatile connectivity
    Designed to meet the needs of various devices, this Apple Lightning cable offers a seamless connection between your cellular phone, digital player, and tablet to USB-equipped devices. Its dual-interface support ensures compatibility with Lightning and USB ports, making it a flexible solution for charging and data transfer.
  • Durable design
    Crafted with a focus on longevity, the cable features robust male connectors on both ends. The Apple Lightning connector and the 4-pin USB Type-A connector are engineered to withstand frequent plugging and unplugging, ensuring a reliable connection every time.
Apple Lightning cable - Lightning / USB - 1 m
Cable
Length
1 m
Connector
Lightning - male
Connector (Second End)
USB - male
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Length
1 m
Recommended Use
Mobile phone, tablet, digital player
Connector
Apple Lightning - male
4 pin USB Type A - male
