Connect your iPhone, iPad or iPod with Lightning connector to your USB-C– or Thunderbolt 3 (USB-C)–enabled Mac for syncing and charging.
You can also use this cable with your Apple 29W, 30W, 61W or 87W USB-C Power Adapter to charge your iOS device, and even take advantage of the fast-charging feature on iPhone 8, iPhone 8 Plus, iPhone X and selected iPad Pro models.
Compatible with the following computers:
12-inch MacBook, 13-inch MacBook Pro - Thunderbolt 3 (USB-C), 15-inch MacBook Pro - Thunderbolt 3 (USB-C), 21.5-inch iMac - Thunderbolt 3 (USB-C), 27-inch iMac - Thunderbolt 3 (USB-C); iMac Pro
- Apple Lightning cable - Lightning / USB - 1 m
- Cable
- Lightning cable - Lightning / USB
- Length
- 1 m
- White
- Connector
- Lightning - male
- Connector (Second End)
- 24 pin USB-C - male
- Cable Type
- Lightning cable
- Interface Supported
- Lightning / USB
- Length
- 1 m
- White
- Connector
- Apple Lightning - male
