With the Lightning to USB 3 Camera Adapter, it's easy to transfer photos and videos from your high-resolution digital camera to your iPad. Add even greater capability and versatility to your iPad by powering the Lightning to USB 3 Camera Adapter with USB power adapter. Then you can connect USB peripherals like hubs, Ethernet adapters, audio/MIDI interfaces, and card readers for CompactFlash, SD, microSD and more. The Lightning to USB 3 Camera Adapter supports standard photo formats.
- Apple Lightning to USB 3 Camera Adapter - Lightning adapter - Lightning / USB
- Cable
- Connectors
- Lightning - male
- Connectors (Second End)
- USB - female , Lightning - female
- Cable Type
- Lightning adapter
- Interface Supported
- Lightning / USB
- Connectors
- Apple Lightning - male
- 4 pin USB Type A - female , Apple Lightning - female
