Apple Lightning to SD Card Camera Reader
Quicklinx: BW8YWS00 Mfr#: MJYT2ZM/A
Supported Formats: SD Memory Card
Interface: Lightning
44 in stock
£21.89 ex VAT
£26.26 inc VAT
With the Lightning to SD Card Camera Reader, it's easy to download photos and videos from your digital camera to your iPad or iPad mini so you can view them on the gorgeous iPad display and share them with family and friends.
After you insert the SD card into the reader, your iPad automatically opens the Photos app, which lets you choose which photos and videos to import, then organizes them into albums. When you sync iPad or iPad mini to your PC or Mac, the photos and videos on your iPad are added to your computer's photo library.
The Lightning to SD Card Camera Reader supports standard photo formats, including JPEG and RAW, along with SD and HD video formats, including H.264 and MPEG-4.
Apple Lightning to SD Card Camera Reader - card reader - Lightning
Card reader - external
Supported Memory Cards
SD Memory Card
Host Interface
Lightning
10.2-inch iPad; 12.9-inch iPad Pro; 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; iPad with Retina display; iPhone 11, 11 Pro, 11 Pro Max, 12, 12 mini, 12 Pro, 12 Pro Max, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, SE (2nd generation), X, XR, XS, XS Max
SD Memory Card
Host Interface
Lightning
Memory Card
(max)
Required Ports
1 x Apple Lightning
Apple 10.2-inch iPad (7th generation, 8th generation) , Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple 9.7-inch iPad Pro , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad with Retina display (4th generation) , Apple iPhone 11, 11 Pro, 11 Pro Max, 12, 12 mini, 12 Pro, 12 Pro Max, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, SE (2nd generation), X, XR, XS, XS Max
Brand: Apple
Stock Status: In stock
