Discover the convenience and reliability of the Apple Lightning cable, a must-have accessory for your Apple devices. This cable features a male Apple Lightning connector on one end and a male 4-pin USB Type-A on the other, providing a seamless connection for both charging and data transfer. Its durable design ensures it can withstand daily use, making it an ideal choice for those who value functionality and durability. Whether you're at home, in the office, or on-the-go, this cable is designed to meet your needs and keep your devices connected and charged.
Efficient connectivity
The Apple Lightning cable ensures a reliable connection between your Apple devices and your computer or charger. With a male Apple Lightning connector on one end and a male 4-pin USB Type-A on the other, it offers seamless connectivity for charging and data transfer. -
Durable design
Designed for durability, this cable features robust connectors that resist wear and tear. The high-quality construction ensures it can withstand daily use, making it a dependable choice for your charging and data transfer needs.
- Apple Lightning cable - Lightning / USB - 1 m
- Cable
- Lightning cable - Lightning / USB
- Length
- 1 m
- Connector
- Lightning - male
- Connector (Second End)
- USB - male
- Cable Type
- Lightning cable
- Interface Supported
- Lightning / USB
- Length
- 1 m
- Connector
- Apple Lightning - male
- 4 pin USB Type A - male
