Apple iPhone X Silicone Case - (PRODUCT)RED
Quicklinx: D4VKWS00 Mfr#: MQT52ZM/A
Colours:
These Apple-designed cases fit snugly over the curves of your iPhone without adding bulk. They're made from specially tanned and finished European leather, so the outside feels soft to the touch and develops a natural patina over time. The machined aluminum buttons match the finish of your leather case, while a microfiber lining inside helps protect your iPhone. And you can keep it on all the time, even when you're charging wirelessly.
  • A case worthy of iPhone 5s
    iPhone 5s has a stunning exterior. So any case that dares to conceal it should be equally appealing. The Apple-designed leather cases more than meet the requirement. Made from premium leather, they look and feel luxurious. And because they're precision crafted for iPhone 5s, your phone still feels incredibly slim even with the case on.
  • Precision made, beautifully crafted
    The leather is deliberately shaped to cover the volume buttons, the on/off switch and the chamfered edge of iPhone 5s. Inside, a soft microfiber lining protects the exterior of your iPhone. Outside, you see color that's more than surface deep thanks to a dye that's infused into the leather.
Apple (PRODUCT) RED - back cover for mobile phone
Back cover for mobile phone
Material
Silicone
Red
iPhone X
Material
Silicone
Lining Material
Microfibre
Red
Carrying Case
Protective cover
Recommended Use
For mobile phone
Cover Type
Back cover
Apple iPhone X
