Apple iPhone SE 64GB (PRODUCT)RED
Quicklinx: GR10WS00 Mfr#: MMXH3B/A
Colours:
At the heart of iPhone SE, you'll find the same super powerful A15 Bionic chip that's in iPhone 13. A15 Bionic enhances nearly everything you do. Apps load in a flash and feel so fluid. A15 Bionic even powers advanced photography features that make each part of your photo - faces, places, everything - look fabulous.
A highly efficient chip, an enhanced battery, and iOS 15 work together to boost battery life. When you do need to charge, just place iPhone SE on a wireless charger. Or connect a 20W or higher adapter to fast charge from zero to up to 50 percent charge in 30 minutes flat.
From livestreaming to multiplayer gaming to video sharing, 5G really speeds things up. It even makes FaceTime in high definition and SharePlay feel smooth and seamless when you're on the go. When you don't need all that speed, iPhone SE shifts into Smart Data mode to preserve battery life.
  • 4.7-inch Retina
    HD display¹
  • Advanced single-camera system
    with 12MP Wide camera; Smart HDR 4, Photographic Styles, Portrait mode and 4K video up to 60 fps
  • 7MP FaceTime HD camera
    with Smart HDR 4, Photographic Styles, Portrait mode and 1080p video recording
  • A15 Bionic chip
    for lightning-fast performance
  • Up to 15 hours
    of video playback²
  • Durable design
    and IP67 water resistance4
  • Home button
    with Touch ID for secure authentication
  • iOS 15
    packs new features to do more with iPhone than ever before5
  • Legal
    ¹Display size is measured diagonally.²Battery life varies by use and configuration.See www.apple.com/uk/batteries for more information.³Data plan required.5G is available in selected markets and through selected network providers. Speeds vary based on site conditions and network.For details on 5G support, contact your provider and see apple.com/uk/iphone/cellular.4iPhone SE (3rd generation) has a rating of IP67 under IEC standard 60529 (maximum depth of 1metre up to 30minutes).Splash, water and dust resistance are not permanent conditions and resistance might decrease as a result of normal wear.Do not attempt to charge a wet iPhone; refer to the user guide for cleaning and drying instructions.Liquid damage not covered under warranty.5Some features may not be available in all countries or all areas.
Apple iPhone SE (3rd generation) - (PRODUCT) RED - red - 5G smartphone - 64 GB - GSM
5G smartphone
Manufacturer Model Number
A2783
Display
LCD display - 1334 x 750 pixels - 4.7" - 326 ppi - Retina HD display with IPS technology - fingerprint-resistant oleophobic coating
Apple A15 Bionic
Neural Processor Unit (NPU)
Apple Third-generation Neural Engine
64 GB
Operating System
iOS 15
Main Camera
12 Megapixel - f/1.8 - focus: automatic
Front Camera
7 Megapixel f/2.2
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
Wireless Interface
NFC, Bluetooth, Wi-Fi 6
Security Devices
Fingerprint reader
Connectors
Lightning
Wireless Charging Standards
Qi
Protection
Dustproof, water-resistant, splash-resistant
Red
67.3 mm x 7.3 mm x 138.4 mm
144 g
0.98 W/kg (head) , 0.99 W/kg (body)
1-year warranty
Smartphone
A2783
Touch
Protection
67.3 mm
7.3 mm
138.4 mm
144 g
Body Colour
Red
Body Material
Aluminium, glass
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
5G
Service Provider
Not specified
Operating System
iOS 15
Intelligent Assistant
Siri
Navigation
GPS, GLONASS, BeiDou, Galileo, QZSS
SIM Card Type
Nano SIM, Electronic SIM card (e-SIM)
SIM Card Qty
Dual-SIM
Payment Technology
Apple Pay
Input Device
Multi-touch
Communications
Data Transmission
EDGE, HSPA+, LTE, DC-HSDPA, LTE Advanced, VoLTE, FDD-LTE, TDD-LTE, VoWiFi, LAA, 5G NR FR1
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 30, Band 32, Band 34, Band 38, Band 39, Band 40, Band 41, Band 42, Band 46, Band 48, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 2300 WCS, FDD 1500 L, TDD 2000, TDD 2600, TDD 1900, TDD 2300, TDD 2500, TDD 3500, TDD 5150, TDD 3600, FDD 1700 - 2110 AWS-3
5G NR Band
N1, n2, n3, n5, n7, n8, n20, n28, n38, n41, n66, n77, n78, n79, n40, n25, n12, n48, n30
5G NR Frequency
FDD 2100, FDD 1900PCS, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, TDD TD 3700, TDD TD 3500, TDD TD 4500, TDD 2300, FDD 1900, n12, TDD 3500, FDD 2300
Wireless Interface
NFC, Bluetooth 5.0, IEEE 802.11ax
Phone Features
Sensors
Accelerometer, ambient light sensor, proximity sensor, 3-axis gyro sensor, digital compass, barometer
Security Devices
Fingerprint reader
Additional Features
MIMO technology, Apple TV support (2nd or later), AirPlay Mirroring, Express Transit cards with power reserve, 4K HDR AirPlay Mirroring, FaceTime HD (1080p)
Media Player
Supported Digital Audio Standards
Audible, MP3, FLAC, Apple Lossless, AC-3, AAC-LC, LPCM, HE-AAC, Audible AAX, Audible AAX+, protected AAC, EAC3, HE-AAC v2
Supported Digital Video Standards
M-JPEG, H.264, HEVC, MPEG-4 Part 2, HEIF
Video Enhancements
HDR10, Hybrid Log-Gamma (HLG)
Sound Enhancements
Dolby Digital Plus sound, Dolby Digital sound
Apple A15 Bionic
Artificial Intelligence Processor Family
Apple
Artificial Intelligence Processor Model
Internal Memory Capacity
64 GB
Front Camera
Sensor Resolution
7 Megapixel
Lens Aperture
F/2.2
HDR Mode
Auto HDR mode
Special Effects
Natural, Studio, Contour, Stage, Stage Mono, High-Key Mono
Camera Modes
Burst mode, Live Photos, Portrait mode with advanced bokeh and Depth Control, Portrait Lighting, wide colour capture for photos and Live Photos
Video Resolutions
1280 x 720 (720p), 1920 x 1080 (1080p) at 30 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps
Light Source
Retina Flash
Auto image stabilisation, Cinematic video stabilisation, QuickTake video, Deep Fusion
Main Camera
Sensor Resolution
12 Megapixel
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Aperture
F/1.8
Lens Construction
6-element
Focus Adjustment
Automatic
Digital Zoom
5x
Special Effects
Camera Modes
Burst mode, Panorama, Live Photos, Timelapse video, Portrait mode with advanced bokeh and Depth Control, Portrait Lighting, wide colour capture for photos and Live Photos
HDR Mode
Smart HDR
Light Source
True Tone LED flash
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, 3840 x 2160 (4K) at 24 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps
Sapphire crystal lens cover, Cinematic video stabilisation, Focus Pixels, Cinematic video stabilisation, Playback zoom, geotagging, Stereo Recording, Continuous autofocus video, 8MP still photos recording 4K video, Time-lapse video with stabilisation, Slow Sync, Advanced red-eye correction, Optical image stabilization for video, Extended dynamic range for video, HEIF image capture, Digital zoom up to 3x for video, QuickTake video, Deep Fusion, Photographic Styles
Display
LCD display
Diagonal Size
4.7"
Display Resolution
1334 x 750 pixels
Pixel Density
326 ppi
Max Brightness
625 cd/m²
Enhancement Technology
Dolby Vision
Contrast Ratio
1400:1
Protection
Fingerprint-resistant oleophobic coating
Display Languages
Danish, Hindi, Hebrew, Hungarian, Czech, Croatian, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Ukrainian, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Catalan, Japanese, Korean, Malay, UK English, US English, Australian English, French Canadian, Spanish (Latin American)
Display Zoom, Reachability (screen shifting), True Tone display, Wide colour display (P3), Dark mode, Haptic touch, Hybrid Log-Gamma (HLG)
Connector Type
Lightning
Lithium Ion
Wireless Charging
Qi
Run Time Details
Playback (audio): up to 50 hrs , Playback (video): up to 15 hrs , Playback (streamed video): up to 10 hrs
IEC 60529 IP67, HAC (Hearing Aid Compatible)
Lightning to USB-C cable
Limited warranty - 1 year , Technical support - consulting - 90 days
Max Depth of Water Resistance
1 m
35 °C
5 - 95% (non-condensing)
