Apple iPhone 8 Plus / 7 Plus Silicone Case - Black
Quicklinx: D422WS00 Mfr#: MQGW2ZM/A
Colours:
Designed by Apple to complement your iPhone, the form of the silicone case fits snugly over the volume buttons, side button, and curves of your device without adding bulk. A soft microfiber lining on the inside helps protect your iPhone. On the outside, the silky, soft-touch finish of the silicone exterior feels great in your hand. And you can keep it on all the time, even when you're charging iPhone wirelessly.
Apple - back cover for mobile phone
Back cover for mobile phone
Material
Silicone
Apple iPhone 7 Plus
Material
Silicone
Lining Material
Microfibre
Carrying Case
Protective cover
Recommended Use
For mobile phone
Cover Type
Back cover
Apple iPhone 7 Plus
