Apple iPhone 8 Plus / 7 Plus Leather Case - Saddle Brown
Quicklinx: D4GGWS00 Mfr#: MQHK2ZM/A
Device Type: iPhone
Type: Case
Device Screen Size: 5.5"
Colour: Saddle brown
£45.34 ex VAT
£54.40 inc VAT
These Apple-designed cases fit snugly over the curves of your iPhone without adding bulk. They're made from specially tanned and finished European leather, so the outside feels soft to the touch and develops a natural patina over time. The machined aluminum buttons match the finish of your leather case, while a microfiber lining inside helps protect your iPhone. And you can keep it on all the time, even when you're charging iPhone 8 Plus wirelessly.
Apple - back cover for mobile phone
Back cover for mobile phone
Material
Leather
Saddle brown
iPhone 7 Plus, 8 Plus
Material
Leather
Lining Material
Microfibre
Saddle brown
Carrying Case
Protective cover
Recommended Use
For mobile phone
Cover Type
Back cover
Apple iPhone 7 Plus, 8 Plus
Apple iPhone 8 Plus / 7 Plus Leather Case - Saddle Brown Bundle deal on Apple iPhone 8 Plus / 7 Plus Leather Case - Saddle Brown
£145.10
Device Type: iPhone
Type: Case
Brand: Apple
Price Range Ex VAT: 0 - 50
