These Apple-designed cases fit snugly over the curves of your iPhone without adding bulk. They're made from specially tanned and finished European leather, so the outside feels soft to the touch and develops a natural patina over time. The machined aluminum buttons match the finish of your leather case, while a microfiber lining inside helps protect your iPhone. And you can keep it on all the time, even when you're charging wirelessly.
- Apple - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- Material
- Leather
- Midnight blue
- Material
- Leather
- Lining Material
- Microfibre
- Midnight blue
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Cover Type
- Back cover
