Engineered exclusively for iPhone 7, the Smart Battery Case gives you even longer battery life while offering great protection. Inside, a soft microfiber lining helps protect your iPhone. And on the outside, the silky, soft-touch finish of the silicone exterior feels great in your hand. A soft elastomer hinge design makes it easy to put the case on and take it off.
Charge your iPhone and battery case simultaneously for increased talk time long hours, Internet use long hours on 4G LTE, and even longer audio and video playback. With the Smart Battery Case on, the intelligent battery status is displayed on the iPhone Lock screen and in Notification Center, so you know exactly how much charge you have left.
- Apple Smart - battery case - back cover for mobile phone
- Product Type
- Battery case back cover for mobile phone
- Material
- Silicone, elastomer
- White
- Material
- Lining Material
- Microfibre
- White
Carrying Case
- Battery case
- Recommended Use
- For mobile phone
- Cover Type
- Back cover
- Cover Features
- Soft-touch
