Apple iPhone 7 Plus 128GB (PRODUCT) RED
Quicklinx: D25VWS00 Mfr#: MPQW2B/A
iPhone 7 Plus dramatically improves the most important aspects of the iPhone experience. It introduces advanced camera systems. The best performance and battery life ever in an iPhone. Immersive stereo speakers. The brightest, most colorful iPhone display. Splash and water resistance. And it looks every bit as powerful as it is. This is iPhone 7 Plus.
iPhone is the most popular camera in the world. Now Apple has reengineered that beloved camera, adding optical image stabilization, an ƒ/1.8 aperture, and a six-element lens to make it even better for shooting photos and videos in low light. And with advanced features like wide color capture, your photos and Live Photos will look even more vibrant.
iPhone 7 Plus doesn't have just one entirely new camera system - it has two. The same 12 megapixel wide-angle camera that's on iPhone 7 works with a 12 megapixel telephoto camera that can get even closer. That means you can get higher-quality zoom from farther away. And with a depth-of-field effect, portrait shots will look better than ever. Say hello to the world's best photo op.
iPhone 7 Plus comes with EarPods that have a Lightning connector. The AirPods offer a game-changing listening experience. Designed with a huge amount of forward-thinking technology inside a tiny device, these wireless headphones combine crystal clear sound with a new sense of freedom. But if you still want to listen through your old headphones, you can plug them in using a 3.5 mm headphone jack adapter.
Videos shot in darker settings with iPhone 7 Plus will look remarkably better, enhanced by optical image stabilization and the ƒ/1.8 aperture. And the 12 megapixel camera captures high-resolution video up to 4K. So you can shoot epic movies of epic moments, even if they're happening in low light.
The FaceTime HD camera is not only higher resolution, but it also uses wide color capture. So now you can take sharper and more vibrant selfies. Worried about lighting? The Retina Flash matches the ambient light for a shot with natural-looking skin tones. Hello, gorgeous.
Why is the camera on iPhone 7 Plus so advanced? It has an improved Apple-designed image signal processor built into the A10 Fusion chip. When you take a photo or video, the ISP powers over 100 billion operations and even uses machine learning to make your images look amazing. Other improvements include faster focus and improved local tone mapping and white balance.
Almost everything you experience with your iPhone comes to life on its display. It's where you look at the photos, messages, news, and countless other things that make up your day. The iPhone 7 Plus display uses the same color space as the digital cinema industry, so what you see will be noticeably more brilliant and vibrant.
When you use 3D Touch, your iPhone responds with subtle taps. So not only will you see what a press can do - you'll feel it. The Retina HD display on iPhone 7 Plus deeply integrates 3D Touch throughout iOS. Now you can interact with Messages, Calendar, Mail, and other apps in a more powerful, more responsive way.
For the first time, iPhone comes with stereo speakers, delivering two times the audio output of iPhone 6s and increased dynamic range. So whether you're listening to music, watching videos, or making speakerphone calls, iPhone 7 Plus lets you crank it up. Way, way up.
With its entire enclosure reengineered, iPhone 7 Plus is the very first water-resistant iPhone. So now you're protected like never before against spills, splashes, and even dust.
iPhone 7 Plus features LTE Advanced, with speeds up to 450 Mbps for data downloads - over 50 percent faster than iPhone 6s and three times faster than iPhone 6.6 And thanks to even more LTE bands, you'll have the best worldwide roaming available in a smartphone. Happy travels.
  • Built to be water resistant
  • An advanced solid-state Home button
    The Home button on iPhone 7 Plus is an advanced solid-state button designed to be durable, responsive, and pressure sensitive. Working in tandem with the Taptic Engine, it gives you precise tactile feedback as you press. And it's even customizable. Welcome home.
  • Touch ID
    Using a highly advanced fingerprint sensor that's as fast as ever, Touch ID makes unlocking your iPhone easy and secure.
  • Apple Pay
    With iPhone, you can pay instantly and securely in stores, in apps, and on the web. And because your card details are never shared by Apple with merchants or stored on your device, using Apple Pay is the safer way to pay.
  • Optical image stabilization
    iPhone 7 Plus comes with optical image stabilization to reduce blur associated with motion and handshake. A sensor helps the lens counteract even the tiniest movement, allowing for up to 3x longer exposure compared to iPhone 6s.
  • ƒ/1.8 aperture
    A larger aperture allows up to 50 percent more light onto the camera sensor than iPhone 6s, further enhancing the camera's ability to take superb low-light photos. Teamed with the six-element lens, the camera will deliver brighter, more detailed shots.
  • Quad-LED True Tone flash
    Four smart LEDs flash 50 percent brighter than iPhone 6s. The flash adjusts according to the color temperature of the environment, resulting in sharper, more brightly lit photos.
  • Now your movies are just like the movies
  • 4K video
    iPhone 7 Plus lets you shoot in 4K resolution - with over 8 million pixels. And you can edit your video in iMovie, then share it instantly.
  • Slo-mo video
    Make your favorite moments last even longer. iPhone 7 Plus offers slo-mo support in 1080p and 720p HD.
  • Time-lapse video
    Capture footage at dynamically selected intervals to create a time-lapse video that's quick and easy to share.
  • 7 megapixel front-facing camera: love your selfie
  • More brains behind the camera, smarter ISP
  • Photos for iOS: bringing all your memories into focus
    You've never experienced your photos quite like this. The Photos app offers tools that let you find, share, and remaster your photos in entirely new ways. And the Memories feature uses advanced search technology to sort your photos into albums and movies for you to enjoy - without putting in any work.
  • Zoom into the future
    Thanks to the dual-camera system and breakthrough ISP technology on iPhone 7 Plus, you can now get supersharp close-up photos and videos with optical zoom at 2x. And you can get even closer with improved digital zoom that lets you shoot at up to 10x for photos and 6x for video.
  • Depth-of-field effect
    Depth of field allows you to keep faces sharp while creating a blurred effect in the background. When you take a shot with iPhone 7 Plus, the dual-camera system uses both cameras and advanced machine learning to make your subject sharp while creating the same out-of-focus blur in the background - known as the bokeh effect - previously reserved for DSLR cameras. So no matter what's behind your subject, it's easy to create a great portrait.
  • EarPods with a Lightning connector
  • Retina HD Display: the brightest, most colorful iPhone display yet
  • More colors, more true to life
    With a wide color gamut, the Retina HD display is able to deliver cinema-standard colors - and the best color management in the smartphone industry. More shades of the color spectrum can be used to create an image, meaning that what you see on the screen is a truer representation of the world. So whether you're checking out photos of that perfect dress or Live Photos you took in the tropics, the colors will be so accurate, it will look like you're there.
  • 3D Touch: now even handier
  • A10 Fusion Chip: the most powerful chip ever in a smartphone
    iPhone 7 Plus is supercharged by the most powerful chip ever in a smartphone. It's not just faster than any previous iPhone - it's also more efficient. That's because the A10 Fusion chip uses an architecture that enables faster processing when you need it, and the ability to use even less power when you don't. And with the longest battery life ever in an iPhone, you can work at twice the speed of iPhone 6 and still enjoy more time between charges.
  • Faster and more efficient
    With the four-core design, the A10 Fusion chip's CPU has two high-performance cores and two high-efficiency cores. The high-performance cores can run at up to 2x the speed of iPhone 6, while the high-efficiency cores are capable of running at just one-fifth the power of the high-performance cores. That means you get the best performance and efficiency when you need it.
  • Wi-Fi and Cellular - faster LTE with the best worldwide roaming
  • Crystal clear VoLTE and Wi-Fi calls
    iPhone 7 Plus supports Voice over LTE - high-quality wideband calls that make your conversations sound as crisp and clear as if you were face to face. When you're unable to get cellular service, Wi-Fi calling provides an easy way to make and receive calls over a Wi-Fi connection.
  • Answer calls on apps like Facebook Messenger and more
    No matter where your call comes from, iPhone 7 Plus can answer it just like a regular call. You can even access your contacts and use call waiting.
Apple iPhone 7 Plus - (PRODUCT) RED - matte red - 4G smartphone - 128 GB - GSM
4G smartphone
Manufacturer Model Number
A1784
Display
LCD display - 1920 x 1080 pixels - 5.5" - 401 ppi - Retina HD display with IPS technology - fingerprint-resistant oleophobic coating
Apple A10 Fusion - 64-bit - with M10 motion
128 GB
Operating System
iOS 10
Main Camera
12 Megapixel - BSI - wide-angle lens - 2x optical zoom - f/1.8 - focus: automatic
Second Camera
12 Megapixel - telephoto lens - f/2.8 - capture depth information
Front Camera
7 Megapixel - BSI f/2.2
Service Provider
Not specified
SIM Card
Single-SIM - nano SIM
Wireless Interface
NFC, Wi-Fi 5, Bluetooth
Security Devices
Fingerprint reader
Messaging Services
SMS, MMS
Connectors
Lightning
Talk Time
Up to 1260 minutes
Standby Time
Up to 384 hours
Protection
Dustproof, splashproof, waterproof
Matte red
77.9 mm x 7.3 mm x 158.2 mm
188 g
Repairability Index
6.4 (out of 10)
1.24 W/kg (head) , 1 W/kg (body)
1-year warranty
Smartphone
A1784
Touch
Protection
77.9 mm
7.3 mm
158.2 mm
188 g
Body Colour
Matte red
Body Material
7000 Series aluminium
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
iOS 10
Intelligent Assistant
Siri
Navigation
A-GPS, GLONASS
SIM Card Type
Nano SIM
SIM Card Qty
Single-SIM
Payment Technology
Apple Pay
Input Device
3D Touch, capacitive
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSUPA, HSPA+, LTE, DC-HSDPA, LTE Advanced, VoLTE, FDD-LTE, TDD-LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 27, Band 28, Band 29, Band 30, Band 38, Band 39, Band 40, Band 41
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 800 SMR, FDD 700 APT, FDD 700d, FDD 2300 WCS, TDD 2600, TDD 1900, TDD 2300, TDD 2500
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.2
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Accelerometer, ambient light sensor, proximity sensor, 3-axis gyro sensor, digital compass, barometer
Security Devices
Fingerprint reader
Additional Features
Multitasking, FaceTime, AirPlay wireless streaming, AirPrint wireless printing, iCloud Photo Sharing, AirDrop function, Apple TV support (2nd, 3rd), MIMO technology, Wi-Fi Calling, iBeacon microlocation, CarPlay function, Family Sharing feature, QuickType keyboard, Handoff, iCloud Keychain, Spotlight Search, Notification Center, M10 motion coprocessor, HomeKit, Night Shift
Media Player
Supported Digital Audio Standards
WAV, AAC, AIFF, PCM, Audible, MP3, Apple Lossless, AAC-LC, HE-AAC, Audible AAX, Audible AAX+, protected AAC
Supported Digital Video Standards
AVI, MOV, M-JPEG, MPEG-4, H.264, M4V
Apple A10 Fusion - with M10 motion
64-bit Architecture
Internal Memory Capacity
128 GB
Front Camera
Sensor Resolution
7 Megapixel
Sensor Type
BSI
Lens Aperture
F/2.2
HDR Mode
Auto HDR mode
Face Detection
Body and face detection
Camera Modes
Burst mode, Timer mode
Video Resolutions
1920 x 1080 (1080p)
Light Source
Retina Flash
Exposure control, Auto image stabilisation
Main Camera
Sensor Resolution
12 Megapixel
Sensor Type
BSI
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Type
Wide-angle lens
Lens Aperture
F/1.8
Lens Construction
6-element
Focus Adjustment
Automatic
Optical Zoom
2x
Digital Zoom
10x
Special Effects
Depth of field
Camera Modes
Burst mode, Panorama, Time-lapse mode, Timer mode
Face Detection
HDR Mode
Auto HDR mode
Light Source
Quad LED flash
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps
Sapphire crystal lens cover, Focus Pixels, Hybrid IR filter, Exposure control, noise reduction, geotagging
Second Camera
Sensor Resolution
12 Megapixel
Lens Type
Telephoto lens
Lens Aperture
F/2.8
Functions
Capture depth information
Display
LCD display
Diagonal Size
5.5"
Display Resolution
1920 x 1080 pixels
Display Format
Full HD
Pixel Density
401 ppi
Max Brightness
625 cd/m²
Contrast Ratio
1300:1
Protection
Fingerprint-resistant oleophobic coating
Display Languages
Danish, Hindi, Hebrew, Hungarian, Czech, Croatian, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Ukrainian, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Catalan, Japanese, Korean, Malay, UK English, US English
Dual-domain pixels, Display Zoom, Reachability (screen shifting)
Connector Type
Lightning
Lithium Ion
Talk Time
1260 minutes
Standby Time
384 hours
Run Time Details
Talk (3G): up to 1260 min , Standby: up to 384 hrs , Active online usage (3G): up to 13 hrs , Active online usage (LTE): up to 13 hrs , Active online usage (Wi-Fi): up to 15 hrs , Playback (wireless video): up to 14 hrs , Playback (wireless audio): up to 60 hrs
IEC 60529 IP67, HAC (Hearing Aid Compatible)
USB cable, power adapter, Apple EarPods with Lightning Connector
Limited warranty - 1 year , Technical support - consulting - 90 days
Sustainability Information
Repairability Index
6.4 (out of 10)
35 °C
5 - 95% (non-condensing)
