Apple iPhone 15 Pro 1TB Blue Titanium
Quicklinx: HDSFWS00 Mfr#: MTVG3ZD/A
FORGED IN TITANIUM
iPhone 15 Pro Max has a strong and light aerospace-grade titanium design with a textured matt-glass back. It also features a super-tough Ceramic Shield front. And it’s splash, water and dust resistant.1
ADVANCED DISPLAY
The 6.1" Super Retina XDR display2 with ProMotion ramps up refresh rates to 120Hz when you need exceptional graphics performance. Dynamic Island bubbles up alerts and Live Activities. Plus, with Always-On display, your Lock Screen stays glanceable, so you don’t have to tap it to stay in the know.
GAME-CHANGING A17 PRO CHIP
A Pro-class GPU makes mobile games feel so immersive, with rich environments and realistic characters. A17 Pro is also incredibly efficient and helps to deliver amazing all-day battery life.3
POWERFUL PRO CAMERA SYSTEM
Get incredible framing flexibility with 7 pro lenses. Capture super high resolution photos with more colour and detail using the 48MP Main camera. And take sharp close-ups from far away with the 3x Telephoto camera on iPhone 15 Pro.
CUSTOMISABLE ACTION BUTTON
Action button is a fast track to your favourite feature. Just set the one you want, like Silent mode, Camera, Voice Memo, Shortcut and more. Then press and hold to launch the action.
PRO CONNECTIVITY
The new USB-C connector lets you charge your Mac or iPad with the same cable you use to charge iPhone 15 Pro. With USB 3, you get a huge leap in data transfer speeds.4 And you can download files up to 2x faster using Wi-Fi 6E.5
VITAL SAFETY FEATURES
With Crash Detection, iPhone can detect a serious car crash and call for help if you can’t.6
DESIGNED TO MAKE A DIFFERENCE
iPhone comes with privacy protections that help keep you in control of your data. It’s made from more recycled materials to minimise environmental impact. And it has built-in features that make iPhone more accessible to all.
COMES WITH APPLECARE WARRANTY
Every iPhone comes with a one-year limited warranty and up to 90 days of complimentary technical support. Get AppleCare+ or AppleCare+ with Theft and Loss to extend your coverage.
The Legal Bit
1 .iPhone 15, iPhone 15 Plus, iPhone 15 Pro and iPhone 15 Pro Max are splash, water and dust resistant and were tested under controlled laboratory conditions with a rating of IP68 under IEC standard 60529 (maximum depth of 6 metres up to 30 minutes). Splash, water and dust resistance are not permanent conditions. Resistance might decrease as a result of normal wear. Do not attempt to charge a wet iPhone; refer to the user guide for cleaning and drying instructions. Liquid damage not covered under warranty.
  1. The display has rounded corners. When measured as a standard rectangle, the screen is 6.12 inches (iPhone 15 Pro, iPhone 15) or 6.69 inches (iPhone 15 Pro Max, iPhone 15 Plus) diagonally. Actual viewable area is less.
  2. Battery life varies by use and configuration; see apple.com/uk/batteries for more information.
  3. USB 3 cable with 10Gb/s speed required for up to 20x faster transfers on iPhone 15 Pro models.
  4. Wi-Fi 6E available in countries and regions where supported.
  5. iPhone 15 and iPhone 15 Pro can detect a serious car crash and call for help. Requires a mobile data connection or Wi-Fi calling.
  • FORGED IN TITANIUM
    iPhone 15 Pro has a strong and light aerospace-grade titanium design with a textured matt-glass back. It also features a super-tough Ceramic Shield front. And it’s splash, water and dust resistant.¹+G289
  • ADVANCED DISPLAY
    The 6.1” Super Retina XDR display² with ProMotion ramps up refresh rates to 120Hz when you need exceptional graphics performance. Dynamic Island bubbles up alerts and Live Activities. Plus, with Always-On display, your Lock Screen stays glanceable, so you don’t have to tap it to stay in the know.
  • GAME-CHANGING A17 PRO CHIP
    A Pro-class GPU makes mobile games feel so immersive, with rich environments and realistic characters. A17 Pro is also incredibly efficient and helps to deliver amazing all-day battery life.³
  • POWERFUL PRO CAMERA SYSTEM
  • CUSTOMISABLE ACTION BUTTON
  • PRO CONNECTIVITY
  • VITAL SAFETY FEATURES
    If you need emergency services and you don’t have mobile service or Wi-Fi, you can use Emergency SOS via satellite.6 With Crash Detection, iPhone can detect a serious car crash and call for help if you can’t.7
  • DESIGNED TO MAKE A DIFFERENCE
  • COMES WITH APPLECARE WARRANTY
  • Legal
    ¹iPhone 15, iPhone 15 Plus, iPhone 15 Pro and iPhone 15 Pro Max are splash, water and dust resistant and were tested under controlled laboratory conditions with a rating of IP68 under IEC standard 60529 (maximum depth of 6 metres up to 30 minutes). Splash, water and dust resistance are not permanent conditions. Resistance might decrease as a result of normal wear. Do not attempt to charge a wet iPhone; refer to the user guide for cleaning and drying instructions. Liquid damage not covered under warranty.²The display has rounded corners. When measured as a standard rectangle, the screen is 6.12 inches (iPhone 15 Pro, iPhone 15) or 6.69 inches (iPhone 15 Pro Max, iPhone 15 Plus) diagonally. Actual viewable area is less.³Battery life varies by use and configuration; see apple.com/uk/batteries for more information.4USB 3 cable with 10Gb/s speed required for up to 20x faster transfers on iPhone 15 Pro models.5Wi-Fi 6E available in countries and regions where supported.6Service is included for free for two years with the activation of any iPhone 15 model. Connection and response times vary based on location, site conditions and other factors. See support.apple.com/kb/HT213885 for more information.7iPhone 15 and iPhone 15 Pro can detect a serious car crash and call for help. Requires a mobile data connection or Wi-Fi calling.
Apple iPhone 15 Pro - blue titanium - 5G smartphone - 1 TB - GSM
5G smartphone
Manufacturer Model Number
A3102
Display
OLED display - 2556 x 1179 pixels - 6.1" - 460 ppi - (120 Hz) - Super Retina XDR Display with ProMotion - HDR - fingerprint-resistant oleophobic coating, Ceramic Shield
Apple A17 Pro (6-core)
Neural Processor Unit (NPU)
Apple 16-core Neural Engine
1 TB
Operating System
iOS 17
Main Camera
48 Megapixel - 3x optical zoom - 24 mm - f/1.78 - focus: automatic
Second Camera
12 Megapixel - ultra wide-angle lens 13 mm - f/2.2
Third Camera
12 Megapixel - telephoto lens - 3x optical zoom - 77 mm - f/2.8
Front Camera
12 Megapixel f/1.9 - automatic
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
Wireless Interface
NFC, Wi-Fi 6, UWB, Wi-Fi 6E, Bluetooth
Security Devices
Face recognition
Connectors
USB-C
Wireless Charging Standards
Qi
Protection
Dustproof, splashproof, waterproof
Blue titanium
70.6 mm x 8.25 mm x 146.6 mm
187 g
Repairability Index
7.6 (out of 10)
Carbon Footprint
107 kg carbon emissions
0.98 W/kg (head) , 0.96 W/kg (body) , 2.99 W/kg (limb)
Smartphone
A3102
Touch
Protection
70.6 mm
8.25 mm
146.6 mm
187 g
Body Colour
Blue titanium
Body Material
Textured matt glass, aerospace-grade titanium
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
5G
Service Provider
Not specified
Operating System
iOS 17
Intelligent Assistant
Siri
Navigation
GPS, GLONASS, BeiDou, Galileo, QZSS, NavIC
SIM Card Type
Nano SIM, Electronic SIM card (e-SIM)
SIM Card Qty
Dual-SIM
Payment Technology
Apple Pay
Input Device
Multi-touch
Communications
Data Transmission
EDGE, HSPA+, DC-HSDPA, VoLTE, FDD-LTE, Gigabit LTE, LAA, 5G NR FR1, TD-LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 2, Band 5, Band 8, Band 10
3G UMTS Frequency
2100, 1900, 850, 900, 1700 EAWS
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 30, Band 32, Band 34, Band 38, Band 39, Band 40, Band 41, Band 42, Band 46, Band 48, Band 66, Band 53
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 2300 WCS, FDD 1500 L, TDD 2000, TDD 2600, TDD 1900, TDD 2300, TDD 2500, TDD 3500, TDD 5150, TDD 3600, FDD 1700 - 2110 AWS-3, Band 53
5G NR Band
N1, n2, n3, n5, n7, n8, n20, n28, n38, n41, n66, n70, n77, n78, n79, n40, n25, n12, n48, n26, n30, n53
5G NR Frequency
FDD 2100, FDD 1900PCS, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, FDD AWS-4, TDD TD 3700, TDD TD 3500, TDD TD 4500, TDD 2300, FDD 1900, n12, TDD 3500, FDD 850, FDD 2300, n53
Wireless Interface
NFC, IEEE 802.11ax, Ultra-Wideband (UWB), Wi-Fi 6E, Bluetooth 5.3
Phone Features
Sensors
Proximity sensor, digital compass, barometer, magnetometer, LiDAR scanner, dual ambient light sensor, gyroscope with large dynamic range, high-g accelerometer
Security Devices
Face recognition
Security Technology
Face ID
Additional Features
MIMO technology, Wi-Fi Calling, iBeacon microlocation, QuickType keyboard, Apple TV support (2nd or later), Fast Charging, FaceTime audio, Apple MagSafe, Express Transit cards with power reserve, 4K HDR AirPlay Mirroring, FaceTime HD (1080p), RTT/TTY compatible, Voice isolation, Wide Spectrum microphone mode, Screen sharing, Portrait mode in FaceTime video, Optical zoom with rear-facing camera, DisplayPort over USB Type-C, FaceTime call with SharePlay, Crash Detection, magnet array, alignment magnet, accessory identification NFC, Emergency SOS via satellite, thread networking technology, action button, Dual active eSIM support, StandBy, hardware-accelerated ray tracing, MetalFX Upscaling, second-generation Ultra Wideband chip
Media Player
Supported Digital Audio Standards
AAC, MP3, FLAC, Apple Lossless, Dolby Atmos, Dolby Digital, Dolby Digital Plus
Supported Digital Video Standards
H.264, HEVC, ProRes
Video Enhancements
HDR with Dolby Vision, HDR10, Hybrid Log-Gamma (HLG)
Sound Enhancements
Dolby Digital Plus sound, Dolby Atmos sound technology, Dolby Digital sound, Spatial audio
Apple A17 Pro
Processor Core Qty
6-core
Artificial Intelligence Processor Family
Apple
Artificial Intelligence Processor Model
Internal Memory Capacity
1 TB
Front Camera
Sensor Resolution
12 Megapixel
Lens Aperture
F/1.9
Focus Adjustment
Automatic
HDR Mode
Smart HDR 5
Special Effects
Photographic Styles
Face Detection
Face recognition
Camera Modes
Burst mode, slow motion video, Time-lapse mode, night mode, portrait mode, Live Photos, Portrait Lighting, wide colour capture for photos and Live Photos, Time Lapse (Night mode), Apple ProRAW, log video recording
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, 3840 x 2160 (4K) at 24 fps, 1920 x 1080 (1080p) at 25 fps, 3840 x 2160 (4K) at 25 fps
Light Source
Retina Flash
Auto image stabilisation, Animoji, Memoji, TrueDepth camera, Cinematic video stabilisation, QuickTake video, Time-lapse video with stabilisation, Lens correction, Deep Fusion, Dolby Vision HDR video recording up to 4K at 60 fps, Autofocus with Focus Pixels, Photonic Engine, Cinematic mode up to 4K HDR at 30 fps, ProRes video recording up to 4K at 60 fps, Academy Colour Encoding System
Main Camera
Sensor Resolution
48 Megapixel
Optical Image Stabiliser
Sensor-shift OIS second-generation (Optical Image Stabilisation)
Lens Aperture
F/1.78
Min Focal Length
24 mm
Focus Adjustment
Automatic
Optical Zoom
3x
Digital Zoom
15x
Special Effects
Photographic Styles
Camera Modes
Burst mode, slow motion video, Panorama, Time-lapse mode, night mode, portrait mode, Live Photos, Portrait Lighting, wide colour capture for photos and Live Photos, Cinema mode, Macro video, Macro mode, Time Lapse (Night mode), Apple ProRAW, Night mode portraits, spatial video, log video recording
Face Detection
Face recognition
HDR Mode
Smart HDR 5
Light Source
Adaptive True Tone LED flash
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, 3840 x 2160 (4K) at 24 fps, 1920 x 1080 (1080p) at 25 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, 3840 x 2160 (4K) at 25 fps
Sapphire crystal lens cover, Cinematic video stabilisation, Cinematic video stabilisation, Playback zoom, geotagging, Stereo Recording, Continuous autofocus video, 8MP still photos recording 4K video, Time-lapse video with stabilisation, Advanced red-eye correction, Panorama (up to 63MP), HEIF image capture, Audio zoom, 100% Focus Pixels, QuickTake video, HEVC (High Efficiency Video coding), Deep Fusion, Dolby Vision HDR video recording up to 4K at 60 fps, 6x optical zoom range, 2x optical zoom out, 3x optical zoom in, Cinematic mode up to 4K HDR at 30 fps, Action mode up to 2.8K at 60 fps, Photonic Engine, customisable default lens, ProRes video recording up to 4K at 60 fps with external recording, Academy Colour Encoding System
Second Camera
Sensor Resolution
12 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Min Focal Length
13 mm
Field of View (FoV)
120 degree(s)
Pixel Size
1.4 µm
Lens correction, 100% Focus Pixels, Quad Pixel sensor
Third Camera
Sensor Resolution
12 Megapixel
Optical Zoom
3x
Lens Type
Telephoto lens
Lens Aperture
F/2.8
Min Focal Length
77 mm
Display
OLED display
Diagonal Size
6.1"
Display Resolution
2556 x 1179 pixels
Pixel Density
460 ppi
Max Brightness
2000 cd/m²
HDR
HDR Technology
HDR10
Enhancement Technology
Dolby Vision
Refresh Rate
120 Hz
Contrast Ratio
2000000:1
Protection
Fingerprint-resistant oleophobic coating, Ceramic Shield
Display Languages
Danish, Hindi, Hebrew, Hungarian, Czech, Croatian, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Ukrainian, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Catalan, Japanese, Korean, Malay, UK English, US English, Australian English, French Canadian, Spanish (Latin American), Chinese (Traditional, Hong Kong), Spanish (Mexican)
Always-on display, True Tone display, Wide colour display (P3), Haptic touch, Hybrid Log-Gamma (HLG), Dynamic Island, 1600 nits max brightness (HDR), 2000 nits max brightness (outdoor)
Connector Type
USB Type-C - 24 pin USB-C
Lithium Ion
Fast Charging Technology
Apple MagSafe wireless charging
Wireless Charging
Qi
Run Time Details
Playback (video): up to 23 hrs , Playback (streamed video): up to 20 hrs , Playback (audio): up to 75 hrs
IEC 60529 IP68, BFR-free, PVC-free, Beryllium-free, Mercury-free, HEARING AID M3/T4, Arsenic-free
USB-C to USB-C cable (1 m)
Sustainability Information
Repairability Index
7.6 (out of 10)
EPEAT Compliant
EPEAT Level
EPEAT Gold
Carbon Footprint
Product Recycled Content
20 % - recycled or renewable content
Max Depth of Water Resistance
6 m
35 °C
5 - 95% (non-condensing)
