DYNAMIC ISLAND COMES TO IPHONE 15
Dynamic Island bubbles up alerts and Live Activities — so you don’t miss them while you’re doing something else. You can see who’s calling, check your flight status and so much more.
INNOVATIVE DESIGN
iPhone 15 features a durable colour-infused glass and aluminium design. It’s splash, water and dust resistant.1 The Ceramic Shield front is super-tough. And the 6.1" Super Retina XDR display2 is up to 2x brighter in the sun compared to iPhone 14.
48MP MAIN CAMERA WITH 2X TELEPHOTO
The 48MP Main camera shoots in super high resolution. So it’s easier than ever to take standout photos with amazing detail. The 2x optical-quality Telephoto lets you frame the perfect close-up.
NEXT-GENERATION PORTRAITS
Capture portraits with dramatically more detail and colour. Just tap to shift the focus between subjects — even after you take the shot.
POWERHOUSE A16 BIONIC CHIP
The superfast chip powers advanced features like computational photography, fluid Dynamic Island transitions and Voice Isolation for phone calls. And A16 Bionic is incredibly efficient to help deliver great all-day battery life.3
USB-C CONNECTIVITY
The USB-C connector lets you charge your Mac or iPad with the same cable you use to charge iPhone 15. You can even use iPhone 15 to charge Apple Watch or AirPods.
VITAL SAFETY FEATURES
With Crash Detection, iPhone can detect a serious car crash and call for help if you can’t.4
DESIGNED TO MAKE A DIFFERENCE
iPhone comes with privacy protections that help keep you in control of your data. It’s made from more recycled materials to minimise environmental impact. And it has built-in features that make iPhone more accessible to all.
COMES WITH APPLECARE WARRANTY
Every iPhone comes with a one-year limited warranty and up to 90 days of complimentary technical support. Get AppleCare+ or AppleCare+ with Theft and Loss to extend your coverage.
The Legal Bit
iPhone 15, iPhone 15 Plus, iPhone 15 Pro and iPhone 15 Pro Max are splash, water and dust resistant and were tested under controlled laboratory conditions with a rating of IP68 under IEC standard 60529 (maximum depth of 6 metres up to 30 minutes). Splash, water and dust resistance are not permanent conditions. Resistance might decrease as a result of normal wear. Do not attempt to charge a wet iPhone; refer to the user guide for cleaning and drying instructions. Liquid damage not covered under warranty.
The display has rounded corners. When measured as a standard rectangle, the screen is 6.12 inches (iPhone 15 Pro, iPhone 15) or 6.69 inches (iPhone 15 Pro Max, iPhone 15 Plus) diagonally. Actual viewable area is less.
Battery life varies by use and configuration; see apple.com/uk/batteries for more information.
iPhone 15 and iPhone 15 Pro can detect a serious car crash and call for help. Requires a mobile data connection or Wi-Fi calling.
Dynamic Island bubbles up alerts and Live Activities - so you don't miss them while you're doing something else. You can see who's calling, check your flight status and so much more. -
INNOVATIVE DESIGN
iPhone 15 features a durable colour-infused glass and aluminium design. It's splash, water and dust resistant. The Ceramic Shield front is super-tough. And the 6.1" Super Retina XDR display is up to 2x brighter in the sun compared to iPhone 14. -
The 48MP Main camera shoots in super high resolution. So it's easier than ever to take standout photos with amazing detail. The 2x optical-quality Telephoto lets you frame the perfect close-up. -
Capture portraits with dramatically more detail and colour. Just tap to shift the focus between subjects - even after you take the shot. -
The superfast chip powers advanced features like computational photography, fluid Dynamic Island transitions and Voice Isolation for phone calls. And A16 Bionic is incredibly efficient to help deliver great all-day battery life. -
USB-C CONNECTIVITY
The USB-C connector lets you charge your Mac or iPad with the same cable you use to charge iPhone 15. You can even use iPhone 15 to charge Apple Watch or AirPods. -
f you need emergency services and you don't have mobile service or Wi-Fi, you can use Emergency SOS via satellite.4 With Crash Detection, iPhone can detect a serious car crash and call for help if you can't.5 -
iPhone comes with privacy protections that help keep you in control of your data. It's made from more recycled materials to minimise environmental impact. And it has built-in features that make iPhone more accessible to all. -
- Apple iPhone 15 - blue - 5G smartphone - 128 GB - GSM
- Product Type
- 5G smartphone
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/2247679
- Manufacturer Model Number
- A3090
- Display
- OLED display - 2556 x 1179 pixels - 6.1" - 460 ppi - Super Retina XDR Display - HDR - fingerprint-resistant oleophobic coating, Ceramic Shield
- Processor
- Apple A16 Bionic (6-core)
- Neural Processor Unit (NPU)
- Apple 16-core Neural Engine
- Memory
- 128 GB
- Operating System
- iOS 17
- Main Camera
- 48 Megapixel - 2x optical zoom - 26 mm - f/1.6 - focus: automatic
- Second Camera
- 12 Megapixel - ultra wide-angle lens 13 mm - f/2.4
- Front Camera
- 12 Megapixel f/1.9 - automatic
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
- Wireless Interface
- NFC, Wi-Fi 6, UWB, Bluetooth
- Security Devices
- Face recognition
- Connectors
- USB-C
- Wireless Charging Standards
- Qi
- Protection
- Water-resistant, splash-resistant, dust-resistant
- Blue
- 71.6 mm x 7.8 mm x 147.6 mm
- 171 g
- Repairability Index
- 7.5 (out of 10)
- Carbon Footprint
- 56 kg carbon emissions
- Rare Earth Materials
- 100% recycled rare earth elements
- Specific Absorption Rate (SAR)
- 0.98 W/kg (head) , 0.98 W/kg (body) , 2.98 W/kg (limb)
- Product Type
- Smartphone
- A3090
- Form Factor
- Touch
- Protection
- 71.6 mm
- 7.8 mm
- 147.6 mm
- 171 g
- Body Colour
- Blue
- Body Material
- Glass, aerospace-grade aluminium
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- iOS 17
- Intelligent Assistant
- Siri
- Navigation
- GPS, GLONASS, BeiDou, Galileo, QZSS
- SIM Card Type
- Nano SIM, Electronic SIM card (e-SIM)
- SIM Card Qty
- Dual-SIM
- Payment Technology
- Apple Pay
- Input Device
- Multi-touch
Communications
- Data Transmission
- EDGE, HSPA+, DC-HSDPA, VoLTE, FDD-LTE, Gigabit LTE, LAA, 5G NR FR1, TD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 5, Band 8, Band 10
- 3G UMTS Frequency
- 2100, 1900, 850, 900, 1700 EAWS
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 30, Band 32, Band 34, Band 38, Band 39, Band 40, Band 41, Band 42, Band 46, Band 48, Band 66, Band 53
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 2300 WCS, FDD 1500 L, TDD 2000, TDD 2600, TDD 1900, TDD 2300, TDD 2500, TDD 3500, TDD 5150, TDD 3600, FDD 1700 - 2110 AWS-3, Band 53
- 5G NR Band
- N1, n2, n3, n5, n7, n8, n20, n28, n38, n41, n66, n70, n77, n78, n79, n40, n25, n12, n48, n26, n30, n53
- 5G NR Frequency
- FDD 2100, FDD 1900PCS, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, FDD AWS-4, TDD TD 3700, TDD TD 3500, TDD TD 4500, TDD 2300, FDD 1900, n12, TDD 3500, FDD 850, FDD 2300, n53
- NFC, IEEE 802.11ax, Ultra-Wideband (UWB), Bluetooth 5.3
Phone Features
- Sensors
- Accelerometer, proximity sensor, digital compass, barometer, magnetometer, dual ambient light sensor, gyroscope with high dynamic range
- Security Devices
- Face recognition
- Security Technology
- Face ID
- Additional Features
- MIMO technology, Wi-Fi Calling, iBeacon microlocation, QuickType keyboard, Apple TV support (2nd or later), AirPlay 2 wireless streaming, FaceTime audio, Apple MagSafe, Express Transit cards with power reserve, 4K HDR AirPlay Mirroring, FaceTime HD (1080p), RTT/TTY compatible, Voice isolation, Zoom with rear-facing camera, Wide Spectrum microphone mode, SharePlay, Screen sharing, Portrait mode in FaceTime video, Dual eSIM support, FaceTime call with SharePlay, Crash Detection, magnet array, alignment magnet, accessory identification NFC, Emergency SOS via satellite, StandBy, second-generation Ultra Wideband chip
Media Player
- Supported Digital Audio Standards
- AAC, MP3, FLAC, Apple Lossless, Dolby Atmos, Dolby Digital, Dolby Digital Plus
- Supported Digital Video Standards
- H.264, HEVC, ProRes
- Video Enhancements
- HDR with Dolby Vision, HDR10, Hybrid Log-Gamma (HLG)
- Sound Enhancements
- Dolby Digital Plus sound, Dolby Atmos sound technology, Dolby Digital sound, Spatial audio
- Apple A16 Bionic
- Processor Core Qty
- 6-core
- Artificial Intelligence Processor Family
- Apple
- Artificial Intelligence Processor Model
- 16-core Neural Engine
- Internal Memory Capacity
- 128 GB
Front Camera
- Sensor Resolution
- 12 Megapixel
- Lens Aperture
- F/1.9
- Focus Adjustment
- Automatic
- HDR Mode
- Smart HDR 5
- Special Effects
- Photographic Styles
- Face Detection
- Face recognition
- Camera Modes
- Burst mode, night mode, portrait mode, Live Photos, Portrait Lighting, wide colour capture for photos and Live Photos, Time Lapse (Night mode)
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, 3840 x 2160 (4K) at 24 fps, 1920 x 1080 (1080p) at 25 fps, 3840 x 2160 (4K) at 25 fps
- Light Source
- Retina Flash
- Auto image stabilisation, Animoji, Memoji, TrueDepth camera, Cinematic video stabilisation, QuickTake video, Time-lapse video with stabilisation, Lens correction, Deep Fusion, Dolby Vision HDR video recording up to 4K at 60 fps, Autofocus with Focus Pixels, Photonic Engine, Cinematic mode up to 4K HDR at 30 fps
Main Camera
- Sensor Resolution
- 48 Megapixel
- Optical Image Stabiliser
- Sensor-shift OIS (Optical Image Stabilisation)
- Lens Aperture
- F/1.6
- Min Focal Length
- 26 mm
- Pixel Size
- 2 µm
- Focus Adjustment
- Automatic
- Optical Zoom
- 2x
- Digital Zoom
- 10x
- Special Effects
- Camera Modes
- Burst mode, slow motion video, Panorama, Time-lapse mode, night mode, Live Photos, Portrait Lighting, wide colour capture for photos and Live Photos, Cinema mode, Macro video, Time Lapse (Night mode)
- Face Detection
- Face recognition
- HDR Mode
- Smart HDR 5
- Light Source
- True Tone LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, 3840 x 2160 (4K) at 24 fps, 1920 x 1080 (1080p) at 25 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, 3840 x 2160 (4K) at 25 fps
- Sapphire crystal lens cover, Cinematic video stabilisation, Cinematic video stabilisation, Playback zoom, geotagging, Stereo Recording, Continuous autofocus video, 8MP still photos recording 4K video, Time-lapse video with stabilisation, Advanced red-eye correction, Panorama (up to 63MP), HEIF image capture, Audio zoom, 100% Focus Pixels, Digital zoom up to 3x for video, QuickTake video, HEVC (High Efficiency Video coding), Deep Fusion, Sensor-shift optical image stabilisation for video, Digital zoom up to 6x for video, Dolby Vision HDR video recording up to 4K at 60 fps, 2x optical zoom out, Cinematic mode up to 4K HDR at 30 fps, Action mode up to 2.8K at 60 fps, Photonic Engine, 4x optical zoom range, 2x optical zoom in
Second Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.4
- Min Focal Length
- 13 mm
- Field of View (FoV)
- 120 degree(s)
- Lens correction, 100% Focus Pixels, Quad Pixel sensor
Display
- OLED display
- Technology
- Diagonal Size
- 6.1"
- Display Resolution
- Pixel Density
- 460 ppi
- Max Brightness
- 1000 cd/m²
- HDR
- HDR Technology
- HDR10
- Enhancement Technology
- Dolby Vision
- Contrast Ratio
- 2000000:1
- Protection
- Fingerprint-resistant oleophobic coating, Ceramic Shield
- Display Languages
- Danish, Hindi, Hebrew, Hungarian, Czech, Croatian, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Ukrainian, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Catalan, Japanese, Korean, Malay, UK English, US English, Australian English, French Canadian, Spanish (Latin American), Chinese (Traditional, Hong Kong), Spanish (Mexican)
- True Tone display, Wide colour display (P3), All Screen Display, Haptic touch, Hybrid Log-Gamma (HLG), Dynamic Island, 1600 nits max brightness (HDR), 2000 nits max brightness (outdoor)
- Connector Type
- USB Type-C - 24 pin USB-C
- Technology
- Lithium Ion
- Fast Charging Technology
- Apple MagSafe wireless charging
- Wireless Charging
- Qi
- Battery Endurance per Cycle
- 34 hrs
- Battery Endurance in Cycles
- 1000
- Run Time Details
- Playback (video): up to 20 hrs , Playback (streamed video): up to 16 hrs , Playback (audio): up to 80 hrs
- Ingress Protection Rating
- IP68
- Repeated Free Fall Reliability Class
- Class C
- IEC 60529 IP68, BFR-free, PVC-free, Beryllium-free, Mercury-free, HEARING AID M3/T4, Arsenic-free
- Included Accessories
- USB-C to USB-C cable (1 m)
Sustainability Information
- 7.5 (out of 10)
- Repairability Class
- Class C
- EPEAT Compliant
- EPEAT Level
- EPEAT Gold
- Carbon Footprint
- Product Recycled Content
- 23 % - recycled or renewable content
- Packaging Recycled Content
- 99 % - recycled fibre
- Max Depth of Water Resistance
- 6 m
- 0 °C
- 35 °C
- 5 - 95% (non-condensing)
Apple AirTag | In Stock | £25.00 |
Apple AirTag 4-Pack | In Stock | £99.17 |
