5G goes Pro. A14 Bionic rockets past every other smartphone chip. The Pro camera system takes low-light photography to the next level — with an even bigger jump on iPhone 12 Pro Max. And Ceramic Shield delivers four times better drop performance. Let’s see what this thing can do.
Superfast wireless: hello 5G
5G transforms iPhone with accelerated wireless speeds and better performance on congested networks. Now you can download huge files on the go or stream high-quality HDR movies. Without. All. The. Lag. iPhone also has the most 5G bands of any smartphone so you get 5G in more places. And all that speed opens up amazing possibilities for the future of apps. -
A14 Bionic: generations ahead of any other smartphone chip
A14 Bionic is the first 5-nanometer chip in the industry, with advanced components literally atoms wide. Forty percent more transistors rev up speeds while increasing efficiency for great battery life. And a new ISP powers Dolby Vision recording - something no pro movie camera, let alone any other phone, can do. -
LiDAR technology: scans the surface of Mars and now your living room
NASA is using LiDAR technology for its next Mars landing. iPhone 12 Pro Max uses a LiDAR Scanner to measure how long it takes light to reflect back from objects. So it can create a depth map of whatever space you're in. Because it's ultra-fast and accurate, AR apps can now transform a room into a realistic rainforest or show you how a new sneaker will fit. -
Pro camera system: a new day for Night mode
Night mode comes to both the Wide and Ultra Wide cameras, and it's better than ever at capturing incredible low-light shots. LiDAR makes Night mode portraits possible. And the Wide camera lets in 27 percent more light, for greater detail and sharper focus day or night. -
Dolby Vision recording: 60 times more colors, infinitely more spectacular
iPhone 12 Pro Max jumps from 8- to 10-bit HDR recording, capturing 700 million colors for much more lifelike video. Then it goes one better, recording in Dolby Vision - the format used by film studios. You can even edit Dolby Vision video and use AirPlay to see every last bit of the difference on the big screen. -
TrueDepth camera: it's never too late to take another Night mode selfie
Night mode comes to the front camera, bringing all that low-light detail and natural color to your favorite subject. Deep Fusion, Smart HDR 3, and Dolby Vision recording are now on the TrueDepth camera, too. So you'll look your best in any light. -
Super Retina XDR display: an infinity pool of pixels
How do you make Apple's brightest display even better? Make it bigger. A new design with flat edges and the flexible custom OLED allowed Apple to push the screen's amazing color, brightness, and contrast right to the very edge. -
Privacy is built in
iPhone is designed to protect your information. Face ID data doesn't leave your iPhone and is never backed up to iCloud or anywhere else. iOS shows you an app's privacy practices before you download it. When you use Apple Pay, your card number isn't shared with merchants. And the list goes on.
- Apple iPhone 12 Pro Max - pacific blue - 5G smartphone - 128 GB - CDMA / GSM
- Product Type
- 5G smartphone
- Manufacturer Model Number
- A2411
- Display
- OLED display - 2778 x 1284 pixels - 6.7" - 458 ppi - Super Retina XDR Display - HDR - fingerprint-resistant oleophobic coating, Ceramic Shield
- Processor
- Apple A14 Bionic (6-core)
- Neural Processor Unit (NPU)
- Apple Next-generation Neural Engine
- Memory
- 128 GB
- Operating System
- iOS 14
- Main Camera
- 12 Megapixel - wide-angle lens - 5x optical zoom - 26 mm - f/1.6 - focus: automatic
- Second Camera
- 12 Megapixel - ultra wide-angle lens 13 mm - f/2.4
- Third Camera
- 12 Megapixel - telephoto lens 65 mm - f/2.2
- Front Camera
- 12 Megapixel ƒ/2.2
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
- Wireless Interface
- NFC, Bluetooth, Wi-Fi 6, UWB
- Security Devices
- Face recognition
- Connectors
- Lightning
- Wireless Charging Standards
- Qi
- Protection
- Dustproof, splashproof, waterproof
- Pacific blue
- 78.1 mm x 7.4 mm x 160.8 mm
- 226 g
- Repairability Index
- 6.9 (out of 10)
- Specific Absorption Rate (SAR)
- 0.99 W/kg (head) , 0.99 W/kg (body) , 3.85 W/kg (limb)
- 1-year warranty
- Product Type
- Smartphone
- A2411
- Form Factor
- Touch
- Protection
- 78.1 mm
- 7.4 mm
- 160.8 mm
- 226 g
- Body Colour
- Pacific blue
- Body Material
- Surgical-grade stainless steel, textured matt glass
Cellular
- Technology
- CDMA2000 1X / GSM / WCDMA (UMTS)
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- iOS 14
- Intelligent Assistant
- Siri
- Navigation
- GPS, GLONASS, BeiDou, Galileo, QZSS
- SIM Card Type
- Nano SIM, Electronic SIM card (e-SIM)
- SIM Card Qty
- Dual-SIM
- Payment Technology
- Apple Pay
- Input Device
- Multi-touch, capacitive
Communications
- Data Transmission
- EDGE, EV-DO, HSPA+, DC-HSDPA, VoLTE, FDD-LTE, TDD-LTE, VoWiFi, Gigabit LTE, LAA, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM, 800 CDMA2000 1X, 1900 CDMA2000 1X
- 3G UMTS Band
- Band 1, Band 5, Band 8, Band 10, Band 25
- 3G UMTS Frequency
- 2100, 850, 900, 1700 EAWS, 1900
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 30, Band 32, Band 34, Band 38, Band 39, Band 40, Band 41, Band 42, Band 46, Band 48, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, FDD 2300 WCS, FDD 1500 L, TDD 2000, TDD 2600, TDD 1900, TDD 2300, TDD 2500, TDD 3500, TDD 5150, TDD 3600, FDD 1700 - 2110 AWS-3
- 5G NR Band
- N1, n2, n3, n5, n7, n8, n20, n28, n38, n41, n66, n77, n78, n79, n40, n25, n12
- 5G NR Frequency
- FDD 2100, FDD 1900PCS, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, TDD TD 3700, TDD TD 3500, TDD TD 4500, TDD 2300, FDD 1900, n12
- NFC, Bluetooth 5.0, IEEE 802.11ax, Ultra-Wideband (UWB)
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, 3-axis gyro sensor, digital compass, barometer, LiDAR scanner
- Security Devices
- Face recognition
- Security Technology
- Face ID
- Additional Features
- AirDrop function, Audio zoom function, MIMO technology, Wi-Fi Calling, iBeacon microlocation, QuickType keyboard, Night Shift, Apple TV support (2nd or later), Raise to wake, Express Transit cards with power reserve, 4K HDR AirPlay Mirroring, FaceTime HD (1080p), RTT/TTY compatible
Media Player
- Supported Digital Audio Standards
- Audible, MP3, FLAC, Apple Lossless, AC-3, AAC-LC, LPCM, HE-AAC, Audible AAX, Audible AAX+, protected AAC, EAC3, HE-AAC v2
- Supported Digital Video Standards
- M-JPEG, H.264, HEVC, MPEG-4 Part 2, HEIF
- Sound Enhancements
- Dolby Digital Plus sound, Dolby Atmos sound technology, Dolby Digital sound
- Apple A14 Bionic
- Processor Core Qty
- 6-core
- Artificial Intelligence Processor Family
- Apple
- Artificial Intelligence Processor Model
- Next-generation Neural Engine
- Internal Memory Capacity
- 128 GB
Front Camera
- Sensor Resolution
- 12 Megapixel
- Lens Aperture
- ƒ/2.2
- HDR Mode
- Smart HDR 3
- Special Effects
- Natural, Studio, Contour, Stage, Stage Mono, High-Key Mono
- Face Detection
- Face recognition
- Camera Modes
- Burst mode, Live Photos, Portrait mode with advanced bokeh and Depth Control, Portrait Lighting, wide colour capture for photos and Live Photos, Time Lapse (Night mode), Smart HDR 3 with Scene Detection
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, 3840 x 2160 (4K) at 24 fps
- Light Source
- Retina Flash
- Auto image stabilisation, Animoji, Memoji, TrueDepth camera, Cinematic video stabilisation, Extended dynamic range for video at 30 fps, QuickTake video, Time-lapse video with stabilisation, Lens correction, Deep Fusion, HDR video recording with Dolby Vision up to 30 fps
Main Camera
- Sensor Resolution
- 12 Megapixel
- Optical Image Stabiliser
- Sensor-shift OIS (Optical Image Stabilisation)
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.6
- Lens Construction
- 7-element
- Min Focal Length
- 26 mm
- Pixel Size
- 1.7 µm
- Focus Adjustment
- Automatic
- Optical Zoom
- 5x
- Digital Zoom
- 12x
- Special Effects
- Camera Modes
- Burst mode, Panorama, night mode, low-light shots, Live Photos, Portrait mode with advanced bokeh and Depth Control, Portrait Lighting, wide colour capture for photos and Live Photos, Time Lapse (Night mode), Apple ProRAW
- Face Detection
- Face recognition
- HDR Mode
- Smart HDR 3
- Light Source
- True Tone LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, 3840 x 2160 (4K) at 24 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps
- Sapphire crystal lens cover, Cinematic video stabilisation, Cinematic video stabilisation, Playback zoom, geotagging, Stereo Recording, Continuous autofocus video, 8MP still photos recording 4K video, Time-lapse video with stabilisation, Slow Sync, Advanced red-eye correction, HEIF image capture, Audio zoom, 100% Focus Pixels, QuickTake video, Extended dynamic range for video at 60 fps, Deep Fusion, Dolby Vision HDR video recording up to 60 fps, Smart HDR 3 with Scene Detection, Sensor-shift optical image stabilisation for video, Digital zoom up to 7x for video
Second Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.4
- Min Focal Length
- 13 mm
- Lens Element Qty
- 5-element
- Field of View (FoV)
- 120 degree(s)
- 5-piece lens, Lens correction
Third Camera
- Sensor Resolution
- 12 Megapixel
- Optical Image Stabiliser (OIS)
- Lens Type
- Telephoto lens
- Lens Aperture
- F/2.2
- Min Focal Length
- 65 mm
- 6-piece lens, Focus Pixels
Display
- OLED display
- Technology
- Diagonal Size
- 6.7"
- Display Resolution
- Pixel Density
- 458 ppi
- Max Brightness
- 800 cd/m²
- HDR
- HDR Technology
- HDR10
- Enhancement Technology
- Dolby Vision
- Contrast Ratio
- 2000000:1
- Protection
- Fingerprint-resistant oleophobic coating, Ceramic Shield
- Display Languages
- Danish, Hindi, Hebrew, Hungarian, Czech, Croatian, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Ukrainian, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Catalan, Japanese, Korean, Malay, UK English, US English, Australian English, French Canadian, Spanish (Latin American), Chinese (Traditional, Hong Kong), Spanish (Mexican)
- True Tone display, Wide colour display (P3), Haptic touch, Hybrid Log-Gamma (HLG), 1200 nits max brightness (HDR)
- Connector Type
- Lightning
- Technology
- Lithium Ion
- Fast Charging Technology
- Apple fast charging technology, Apple MagSafe wireless charging
- Wireless Charging
- Qi
- Run Time Details
- Playback (video): up to 20 hrs , Playback (streamed video): up to 12 hrs , Playback (audio): up to 80 hrs
- IEC 60529 IP68, HAC (Hearing Aid Compatible)
- Included Accessories
- Lightning to USB-C cable
- Limited warranty - 1 year , Technical support - consulting - 90 days
Sustainability Information
- 6.9 (out of 10)
- Max Depth of Water Resistance
- 6 m
- 0 °C
- 35 °C
- 5 - 95% (non-condensing)
Apple EarPods with Lightning Connector | In Stock | £16.87 |
Apple AirPods with Charging Case - 2nd Gen | In Stock | £90.84 |
Apple AirTag | In Stock | £25.00 |
