This form of the silicone case fits snugly over the volume buttons, side button, and curves of your device without adding bulk. A soft microfiber lining on the inside helps protect your iPhone. On the outside, the silky, soft-touch finish of the silicone exterior feels great in your hand. And you can keep it on all the time, even when you're charging wirelessly.
Like every Apple-designed case, it undergoes thousands of hours of testing throughout the design and manufacturing process. So not only does it look great, it's built to protect your iPhone from scratches and drops.
- Apple - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- Material
- Silicone
- Pomegranate
- Designed For
- iPhone 11 Pro
- Material
- Silicone
- Lining Material
- Microfibre
- Pomegranate
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- Scratch-resistant, drop-resistant
- Cover Type
- Back cover
- Designed For
- Apple iPhone 11 Pro
