And then there was Pro.
A transformative triple-camera system that adds tons of capability without complexity. An unprecedented leap in battery life. And a mind-blowing chip that elevates machine learning and pushes the boundaries of what a smartphone can do. Welcome to the first iPhone powerful enough to be called Pro.
Pro camera system
Capture up to four times more scene. Get beautiful images in drastically lower light. Shoot the high-quality video in a smartphone - then edit with the same tools you love for photos. You've never shot with anything like it. -
4K video
iPhone 11 Pro lets you capture videos that are beautifully true to life, with greater detail and smoother motion. Epic processing power means it can shoot 4K video with extended dynamic range and cinematic video stabilization - all at 60 fps. You get more creative control, too, with four times more scene and powerful editing tools to play with. -
Ultra Wide
When you just can't squeeze everything into the frame, zoom out. Because the Ultra Wide camera captures four times more scene than ever. It's like stepping back - way back - without taking a step. Bring on those mountain ranges, soaring cathedrals, and iconic skylines. -
Night mode
From dimly lit restaurants to moonlit beaches, the Night mode uses intelligent software and A13 Bionic to deliver low-light shots never before possible on iPhone. And it all happens automatically. You can also experiment with manual controls to dial in even more detail and less noise. -
Portrait mode
With three cameras working together, you can fit more in your portraits than ever. iOS 13 adds the High-Key Light Mono effect for studio-style monochromes. And Portrait Lighting lets you control the intensity of light to flatter your subject - just like you would in a studio. How beautiful is that? -
Smart HDR
Next-generation Smart HDR uses advanced algorithms to finesse highlight and shadow detail in your image. And now it leverages machine learning to recognize faces in your shot and intelligently relight them. That means iPhone 11 Pro Max can automatically fine-tune detail in both the subject and the background. Even some DSLR cameras can't do that. -
Be ready when your photo op turns into a video op
Say you're taking photos and you see something you've got to catch on video. With QuickTake, there's no need to switch modes. Just leave your finger on the shutter to start recording. Want to keep the recording going? Swipe right. To take burst photos, swipe left. -
Super Retina XDR
The Super Retina XDR display boasts not one but two peaks of brightness and understands when to use them. It hits up to 800 nits when you're out in the sun - great for shooting and making selects on the go - and up to 1200 nits when you're viewing extreme dynamic range content. It's like having a Pro Display XDR on your iPhone. -
Privacy is built in
Everything about iPhone is engineered to protect your privacy. Face ID data doesn't leave your iPhone and is never backed up to iCloud or anywhere else. Maps tells you where you're going without telling anyone where you are. Every iMessage you send is encrypted end-to-end. And the list goes on. -
Excellent trade-in value
iPhone 11 Pro Max is designed to last, so it holds its value longer. Should you ever decide to part with it, you can use that value toward your next iPhone.
- Apple iPhone 11 Pro Max - gold - 4G smartphone - 256 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- A2218
- Display
- OLED display - 2688 x 1242 pixels - 6.5" - 458 ppi - Super Retina XDR Display - HDR - fingerprint-resistant oleophobic coating
- Processor
- Apple A13 Bionic (6-core) - 64-bit
- Neural Processor Unit (NPU)
- Apple Third-generation Neural Engine
- Memory
- 256 GB
- Operating System
- iOS 13
- Main Camera
- 12 Megapixel - wide-angle lens - 2x optical zoom - 26 mm - f/1.8 - focus: automatic
- Second Camera
- 12 Megapixel - ultra wide-angle lens 26 mm - f/2.4
- Third Camera
- 12 Megapixel - telephoto lens 52 mm - f/2.0 - capture depth information
- Front Camera
- 12 Megapixel f/2.2
- Service Provider
- Not specified
- SIM Card
- Dual-SIM - nano SIM, Electronic SIM card (e-SIM)
- Wireless Interface
- NFC, Bluetooth, Wi-Fi 6
- Security Devices
- Face recognition
- Messaging Services
- SMS, MMS
- Connectors
- Lightning
- Wireless Charging Standards
- Qi
- Protection
- Dustproof, splashproof, waterproof, spill-resistant
- Gold
- 77.8 mm x 8.1 mm x 158 mm
- 226 g
- Specific Absorption Rate (SAR)
- 0.95 W/kg (head) , 0.99 W/kg (body)
- 1-year warranty
- Product Type
- Smartphone
- A2218
- Form Factor
- Touch
- Protection
- 77.8 mm
- 8.1 mm
- 158 mm
- 226 g
- Body Colour
- Gold
- Body Material
- Surgical-grade stainless steel, textured matt glass
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- iOS 13
- Intelligent Assistant
- Siri
- Navigation
- GPS, GLONASS
- SIM Card Type
- Nano SIM, Electronic SIM card (e-SIM)
- SIM Card Qty
- Dual-SIM
- Payment Technology
- Apple Pay
- Input Device
- Touch screen, capacitive
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, DC-HSDPA, LTE Advanced, VoLTE, FDD-LTE, TDD-LTE, VoWiFi, Gigabit LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 11, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 21, Band 25, Band 26, Band 28, Band 29, Band 30, Band 32, Band 34, Band 38, Band 39, Band 40, Band 41, Band 42, Band 46, Band 48, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 1500, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1500 upper, FDD 1900+, FDD 850+, FDD 700 APT, FDD 700d, FDD 2300 WCS, FDD 1500 L, TDD 2000, TDD 2600, TDD 1900, TDD 2300, TDD 2500, TDD 3500, TDD 5150, TDD 3600, FDD 1700 - 2110 AWS-3
- NFC, Bluetooth 5.0, IEEE 802.11ax
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, 3-axis gyro sensor, digital compass, barometer
- Security Devices
- Face recognition
- Security Technology
- Face ID
- Additional Features
- TTY compatible, FaceTime, AirDrop function, Audio zoom function, MIMO technology, Wi-Fi Calling, iBeacon microlocation, QuickType keyboard, Night Shift, Apple TV support (2nd or later), AirPlay Mirroring, FaceTime audio, U1 chip
Media Player
- Supported Digital Audio Standards
- Audible, MP3, FLAC, Apple Lossless, AC-3, AAC-LC, LPCM, HE-AAC, Audible AAX, Audible AAX+, protected AAC, EAC3, HE-AAC v2
- Supported Digital Video Standards
- M-JPEG, H.264, HEVC, MPEG-4 Part 2, HEIF
- Sound Enhancements
- Dolby Digital Plus sound, Dolby Atmos sound technology, Dolby Digital sound
- Apple A13 Bionic
- Processor Core Qty
- 6-core
- 64-bit Architecture
- Artificial Intelligence Processor Family
- Apple
- Artificial Intelligence Processor Model
- Third-generation Neural Engine
- Internal Memory Capacity
- 256 GB
Front Camera
- Sensor Resolution
- 12 Megapixel
- Lens Aperture
- F/2.2
- HDR Mode
- Smart HDR
- Special Effects
- Natural, High Key, Studio, Contour, Stage, Stage Mono
- Face Detection
- Face recognition
- Camera Modes
- Burst mode, Live Photos, Portrait mode with advanced bokeh and Depth Control, Portrait Lighting, wide colour capture for photos and Live Photos
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, 3840 x 2160 (4K) at 24 fps
- Light Source
- Retina Flash
- Auto image stabilisation, Animoji, Memoji, TrueDepth camera, Cinematic video stabilisation, Extended dynamic range for video at 30 fps
Main Camera
- Sensor Resolution
- 12 Megapixel
- Optical Image Stabiliser
- Dual OIS (Optical Image Stabilisation)
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.8
- Lens Construction
- 6-element
- Min Focal Length
- 26 mm
- Focus Adjustment
- Automatic
- Optical Zoom
- 2x
- Digital Zoom
- 10x
- Special Effects
- Camera Modes
- Burst mode, Panorama, night mode, low-light shots, Live Photos, Portrait mode with advanced bokeh and Depth Control, Portrait Lighting, wide colour capture for photos and Live Photos
- Face Detection
- Face detection
- HDR Mode
- Smart HDR
- Light Source
- True Tone LED flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, 3840 x 2160 (4K) at 24 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps
- Cinematic video stabilisation, Zero Shutter Lag, Cinematic video stabilisation, Playback zoom, geotagging, Stereo Recording, Continuous autofocus video, 8MP still photos recording 4K video, Time-lapse video with stabilisation, Slow Sync, Advanced red-eye correction, Optical image stabilization for video, Extended dynamic range for video, HEIF image capture, Audio zoom, 100% Focus Pixels
Second Camera
- Sensor Resolution
- 12 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.4
- Min Focal Length
- 26 mm
- Lens Element Qty
- 5-element
- Field of View (FoV)
- 120 degree(s)
- 5-piece lens
Third Camera
- Sensor Resolution
- 12 Megapixel
- Optical Image Stabiliser (OIS)
- Lens Type
- Telephoto lens
- Lens Aperture
- F/2.0
- Min Focal Length
- 52 mm
- Functions
- Capture depth information
- Optical image stabilisation for video, 6-piece lens
Display
- OLED display
- Technology
- Diagonal Size
- 6.5"
- Display Resolution
- Pixel Density
- 458 ppi
- Max Brightness
- 1200 cd/m²
- HDR
- HDR Technology
- HDR10
- Enhancement Technology
- Dolby Vision
- Contrast Ratio
- 2000000:1
- Protection
- Fingerprint-resistant oleophobic coating
- Display Languages
- Danish, Hindi, Hebrew, Hungarian, Czech, Croatian, Indonesian, Thai, Slovak, Chinese (traditional), Chinese (simplified), Vietnamese, Ukrainian, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Catalan, Japanese, Korean, Malay, UK English, US English, Australian English, French Canadian, Spanish (Latin American)
- True Tone display, Wide colour display (P3), Dark mode, Haptic touch
- Connector Type
- Lightning
- Technology
- Lithium Ion
- Fast Charging Technology
- Apple fast charging technology
- Wireless Charging
- Qi
- Run Time Details
- Playback (video): up to 20 hrs , Playback (wireless video): up to 12 hrs , Playback (audio): up to 80 hrs
- IEC 60529 IP68, HAC (Hearing Aid Compatible)
- Included Accessories
- Apple EarPods with Lightning Connector, 18W USB-C power adapter, Lightning to USB-C cable
- Limited warranty - 1 year , Technical support - consulting - 90 days
- Max Depth of Water Resistance
- 4 m
- 0 °C
- 35 °C
- 5 - 95% (non-condensing)
