Whether you're enjoying photos, shopping, or building a presentation, the vivid 9.7-inch Retina display has the detail and size to really bring them to life. The 64-bit A9 chip delivers performance that makes every app feel fast and fluid. Explore rich learning apps, play graphics-intensive games, or even use two apps at once. All while enjoying up to 10 hours of battery life. Taking photos and videos with iPad is a snap. Use the 8-megapixel camera to shoot detailed images or 1080p HD video and then edit them right on iPad with Photos, iMovie, or your favorite app from the App Store. Or use the front-facing FaceTime HD camera for video calls and gorgeous selfies. At just one pound and 7.5 mm thin, iPad is designed to go wherever you go. And it's as durable as it is portable, with an aluminum unibody construction that delivers a reassuringly solid feel.
iPad is designed to stay connected wherever you go. Fast 802.11ac Wi-Fi delivers up to 866-Mbps throughput. The Wi-Fi + Cellular model supports LTE networks worldwide for convenient connectivity.
Stunning Retina display
Whether you're enjoying photos, shopping, or building a presentation, the vivid Retina display has the detail and size to really bring them to life. -
Fast, fluid performance
The powerful chip delivers performance that makes every app feel fast and fluid. Explore rich learning apps, play graphics-intensive games, or even use two apps at once. -
Front and back cameras
Taking photos and videos with iPad is a snap. Use the 8-megapixel camera to shoot detailed images or video. Or use the front-facing camera for video calls and gorgeous selfies. -
Durable and portable
Light and thin, iPad is designed to go wherever you go. And it's as durable as it is portable, with an aluminum unibody construction that delivers a reassuringly solid feel.
- Apple 9.7-inch iPad Wi-Fi + Cellular - 6th generation - tablet - 32 GB - 9.7" - 3G, 4G
- Product Type
- Tablet
- Display
- 9.7" IPS TFT - LED backlight - 2048 x 1536 (264 ppi) - Multi-Touch
- Processor
- Apple A10 Fusion (Quad-Core) - 64-bit
- Storage
- 32 GB
- Cellular Technology
- 3G, 4G
- Cellular Protocols
- GSM, UMTS, EDGE, CDMA 2000 1X EV-DO Rev. A, HSPA, HSPA+, LTE, DC-HSDPA, CDMA 2000 1X EV-DO Rev. B
- Wireless Connectivity
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Rear Camera
- 8 Megapixel focus: automatic
- Front Camera
- 1.2 Megapixel
- Navigation System
- A-GPS/GLONASS
- Security Devices
- Fingerprint reader
- Battery Run Time
- Up to 10 hours
- 16.95 cm x 0.75 cm x 24 cm
- 478 g
- Space grey
- Localisation
- English / United Kingdom
- Specific Absorption Rate (SAR)
- 0.99 W/kg (body)
- 1-year warranty
- Product Type
- Tablet
- Operating System
- Apple iPadOS 14
Display
- Resolution
- Touchscreen
- Multi-Touch
- Anti-fingerprint, Retina display, Apple Pencil support
- Processor
- Apple A10 Fusion
- Number of Cores
- Quad-Core
- 64-bit Computing
- Storage
- 32 GB
Communications
- 3G, 4G
- Band
- GSM 850/900/1800/1900 / UMTS 850/900/1700/1900/2100 / CDMA 2000 X1 800/1900 / LTE 700 / 700 APT/700b/700c/700 de/800 DD/800/850/900/1800/1900/TD 1900/2100/TD 2300/TD 2500/2600/TD 2600/AWS
Rear Camera
- Sensor Resolution
- 8 Megapixel
- Focus Adjustment
- Automatic
- Lens Aperture
- F/2.4
- HDR Mode
- Auto HDR mode
- Face Detection
- Body and face detection
- Cinematic video stabilisation, Live Photo, Hybrid IR filter, Exposure control, geotagging
Front Camera
- Sensor Resolution
- 1.2 Megapixel
- Lens Aperture
- F/2.2
- FaceTime HD camera
Navigation System
- Receiver
- A-GPS/GLONASS
Multimedia
- Supported Digital Audio Standards
- WAV, AAC, AIFF, Audible, MP3, Apple Lossless, AC-3, HE-AAC, Audible AAX, Audible AAX+, protected AAC, EAC3, MP3 VBR
- Supported Digital Video Standards
- MPEG-4 SP (up to 640x480), Motion JPEG (up to 1280x720), H.264 High Profile Level 4.2 (up to 4K)
- Audio
- Stereo speakers
Input Device
- Security Devices
Software
- Preloaded Software
- Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, Files, FaceTime, Photo Booth, Safari, Photos, App Store, Maps, News, Find My iPhone, Stocks, Siri, Books, Reminders, Music, Find My Friends, Voice Memos, iTunes Store, Podcasts, Apple TV App, Home, Measure
System Requirements for PC Connection
- OS Required
- Microsoft Windows 7 or later, Apple MacOS X 10.10.5 or later
Expansion and Connectivity
- 1 x headphones mini jack (3.5mm) , 1 x Lightning
- Technology
- Lithium polymer
- Capacity
- 32.4 Wh
- Run Time
- Up to 10 hours
- Run Time Details
- Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Audio playback: up to 10 hour(s) , Web browsing over cellular data network: up to 9 hour(s)
- Space grey
- Sensors
- Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass, barometer
- Charging via USB, VoiceOver screen reader, AirPlay, Dictation, AssistiveTouch, MIMO technology, iBeacon microlocation, Apple M10 motion coprocessor
- Included Accessories
- Power adapter, Apple SIM
- Cables Included
- Lightning to USB cable
- 0.99 W/kg (body)
- Localisation
- 16.95 cm
- 0.75 cm
- 24 cm
- 478 g
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- 0 °C
- 35 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 45 °C
- Max Altitude Operating
- 3 km
