The Apple-designed silicone case protects the back of your iPad Pro and fits snugly over the buttons without adding bulk. The soft microfiber lining helps protect your iPad Pro, while the silky, soft-touch silicone exterior feels great in your hand.
- Apple - back cover for tablet
- Product Type
- Back cover for tablet
- Screen Size Compatibility
- 12.9"
- Material
- Silicone
- White
- Designed For
- 12.9-inch iPad Pro (1st generation, 2nd generation)
- Material
- Silicone
- Lining Material
- Microfibre
- White
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- 12.9"
- Cover Type
- Back cover
- Designed For
- Apple 12.9-inch iPad Pro (1st generation, 2nd generation)
