Apple iPad Pro Silicone Case White
Quicklinx: BRK6WS00 Mfr#: MK0E2ZM/A
The Apple-designed silicone case protects the back of your iPad Pro and fits snugly over the buttons without adding bulk. The soft microfiber lining helps protect your iPad Pro, while the silky, soft-touch silicone exterior feels great in your hand.
Apple - back cover for tablet
Back cover for tablet
Screen Size Compatibility
12.9"
Material
Silicone
White
12.9-inch iPad Pro (1st generation, 2nd generation)
Material
Silicone
Lining Material
Microfibre
White
Carrying Case
Protective cover
Recommended Use
For tablet
12.9"
Cover Type
Back cover
Apple 12.9-inch iPad Pro (1st generation, 2nd generation)
