iPad Pro is more than the next generation of iPad - it's an uncompromising vision of personal computing for the modern world. It puts incredible power that leaps past most portable PCs at your fingertips. It makes even complex work as natural as touching or swiping. iPad Pro is more capable, versatile, and portable than anything that's come before. In a word, super.
Retina Display: an awesome display of progress
The key to the iPad experience is the display. It's how you interact using multi-touch, and how you view content in spectacular detail. -
Four speaker audio: no matter how you turn it, you'll want to turn it up
With a high-fidelity speaker in each corner, iPad Pro creates a rich, wide, and detailed soundstage. It automatically adjusts the orientation of the high frequencies to the topmost speakers, no matter how you're holding it. So whether you're playing a game or watching a movie, you - and your ears - will be completely immersed. -
A9X chip: faster than a speeding laptop
The 64-bit A9X chip gives iPad Pro the power to easily take on tasks once reserved for workstations and PCs. Not to mention tasks you'd never consider doing on a PC. Despite this barrier-breaking performance, the A9X chip's efficient architecture enables up to 10 hours of battery life. -
Quicker work
With up to 1.8 times the CPU performance of iPad Air 2, the A9X chip delivers incredible responsiveness. Even complex actions like editing 4K video happen immediately and with unparalleled smoothness. -
More beautiful play
iPad Pro offers up to double the graphics performance of iPad Air 2. That means it can render incredibly detailed visuals, fluid animations, and effects so real, you'll lose yourself in your favorite apps and games. -
A game changer
Metal optimizes CPU and graphics like nothing else. So developers can design even more highly immersive console-style games and blazing-fast apps. -
iSight and FaceTime HD cameras: capture every detail in greater detail
iPad Pro has remarkable cameras on both the front and the back. It's also the first iPad with True Tone flash, so skin tones look great regardless of lighting. Things are sharper on the other side of iPad Pro, too. The front-facing FaceTime HD camera's sensor makes video calls more lifelike. -
Design: incredible power has never been so easy to handle
Even though iPad Pro can handle tasks usually reserved for PCs, it's lighter than any PC could hope to be. And thanks to the aluminum unibody, it feels reassuringly solid in the hand. -
Fast wireless connectivity
iPad Pro can connect to the fastest Wi-Fi networks so you can surf the web, stream movies and share documents from virtually anywhere. -
Touch ID: the password is you
iPad Pro uses Touch ID technology to turn your fingerprint into an unforgettable password. So you can unlock your device with just a touch. You can also make secure purchases in iTunes, iBooks, and the App Store. And with Apple Pay, you can make purchases within your apps easily and securely.
- Apple 9.7-inch iPad Pro Wi-Fi - 1st generation - tablet - 128 GB - 9.7"
- Product Type
- Tablet
- Display
- 9.7" IPS TFT - LED backlight - 2048 x 1536 (264 ppi) - Multi-Touch
- Processor
- Apple A9X - 64-bit
- Storage
- 128 GB
- Wireless Connectivity
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Rear Camera
- 12 Megapixel focus: automatic
- Front Camera
- 5 Megapixel
- Security Devices
- Fingerprint reader
- Battery Run Time
- Up to 10 hours
- 16.95 cm x 0.61 cm x 24 cm
- 437 g
- Space grey
- Localisation
- English / United Kingdom
- Specific Absorption Rate (SAR)
- 0.72 W/kg (body)
- 1-year warranty
- Product Type
- Tablet
- Operating System
- Apple iOS 9
Display
- Resolution
- Touchscreen
- Multi-Touch
- Anti-glare, anti-fingerprint, Retina display, fully laminated display, True Tone display, Wide colour display
- Processor
- Apple A9X
- 64-bit Computing
- Storage
- 128 GB
Communications
Rear Camera
- Sensor Resolution
- 12 Megapixel
- Focus Adjustment
- Automatic
- HDR Mode
- Auto HDR mode
- Face Detection
- Face detection
- Sapphire crystal lens cover, Cinematic video stabilisation, Focus Pixels, Cinematic video stabilisation, Live Photo, Hybrid IR filter, Improved noise reduction, Exposure control, geotagging
Front Camera
- Sensor Resolution
- 5 Megapixel
- FaceTime HD camera
Multimedia
- Supported Digital Audio Standards
- WAV, AAC, AIFF, Audible, MP3, Apple Lossless, HE-AAC, protected AAC
- Supported Digital Video Standards
- MPEG-4 SP (up to 640x480), Motion JPEG (up to 1280x720), H.264 High Profile Level 5.0 (up to 1080p)
- Audio
- Two microphones, four speakers
Input Device
- Security Devices
Software
- Preloaded Software
- Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, FaceTime, Photo Booth, Safari, Videos, Photos, App Store, Maps, Game Center, iBooks, News, Find My iPhone, Siri, Reminders, Music, Find My Friends, Control Center, iTunes Store, Podcasts, iCloud Drive, Notification Center, Spotlight Search
System Requirements for PC Connection
- OS Required
- Microsoft Windows 7 or later, Apple OS X 10.8.5 Mountain Lion or later
Expansion and Connectivity
- 1 x headphones , 1 x Lightning , 1 x Smart Connector
- Technology
- Lithium polymer
- Capacity
- 27.5 Wh
- Run Time
- Up to 10 hours
- Run Time Details
- Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Audio playback: up to 10 hour(s)
- Space grey
- Sensors
- Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass, barometer
- Charging via USB, VoiceOver screen reader, AirPrint, AirPlay, parental controls, Dictation, AssistiveTouch, MIMO technology, AirDrop, iBeacon microlocation, Apple M9 motion coprocessor, Family Sharing, Night Shift, CarPlay
- Included Accessories
- Power adapter
- Cables Included
- Lightning to USB cable
- 0.72 W/kg (body)
- Localisation
- 16.95 cm
- 0.61 cm
- 24 cm
- 437 g
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- 0 °C
- 35 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 45 °C
