Apple iPad Pro 10.5" 512GB Space Grey WiFi/Cellular
CONTACT OUR IT SPECIALISTS TO ENQUIRE ABOUT EDUCATION PRICING!
Quicklinx: D8F7WS00 Mfr#: MPME2B/A#BTBM
No matter the task, the iPad Pro is up to it - and then some. It offers far more power than most PC laptops, yet is delightfully simple to use. The redesigned Retina display is as stunning to look at as it is to touch. And it all comes together with iOS, the world's most advanced mobile operating system. iPad Pro. Everything you want modern computing to be. Now even, well, better.
If you’re someplace where there is no Wi-Fi, iPad with Wi-Fi + Cellular models let you stay connected to fast cellular data networks practically anywhere you go. So you can continue to browse the web, send and receive mail, get directions, and more. To use a cellular network, simply insert an activated carrier SIM card, or purchase a cellular data plan using Apple SIM right on your iPad with no long-term commitment.
Apple 10.5-inch iPad Pro Wi-Fi + Cellular - 1st generation - tablet - 512 GB - 10.5" - 3G, 4G
Tablet
Display
10.5" IPS TFT - LED backlight - 2224 x 1668 (264 ppi) - Multi-Touch
Apple A10X Fusion (6-core) - 64-bit
Storage
512 GB
Cellular Technology
3G, 4G
Cellular Protocols
GSM, UMTS, EDGE, CDMA 2000 1X EV-DO Rev. A, HSPA, HSPA+, LTE, DC-HSDPA, CDMA 2000 1X EV-DO Rev. B, LTE Advanced
Wireless Connectivity
802.11a/b/g/n/ac, Bluetooth 4.2
Rear Camera
12 Megapixel focus: automatic
Front Camera
7 Megapixel
Navigation System
A-GPS/GLONASS
Security Devices
Fingerprint reader
Battery Run Time
Up to 10 hours
17.41 cm x 0.61 cm x 25.06 cm
477 g
Space grey
English / United Kingdom
0.93 W/kg (body)
1-year warranty
Tablet
Operating System
Apple iOS 12
Display
Resolution
Touchscreen
Multi-Touch
Anti-glare, anti-reflective, anti-fingerprint, Retina display, fully laminated display, True Tone display, Wide colour display, ProMotion technology
Apple A10X Fusion
Number of Cores
6-core
64-bit Computing
Storage
512 GB
Communications
Cellular Technology
3G, 4G
Cellular Protocols
Band
GSM 850/900/1800/1900 / UMTS 850/900/1700/1900/2100 / CDMA 2000 X1 800/1900 / LTE 700/700 APT/700b/700c/700 de/800/ 800 DD/850/900/1500/1800/1900/TD 1900/2100/2300/TD 2300/TD 2500/2600/TD 2600/AWS
Rear Camera
Sensor Resolution
12 Megapixel
Camera Zoom
5x digital zoom
Focus Adjustment
Automatic
Lens Aperture
F/1.8
HDR Mode
Auto HDR mode
Face Detection
Body and face detection
Sapphire crystal lens cover, Focus Pixels, Cinematic video stabilisation, Live Photo, Playback zoom, Hybrid IR filter, Exposure control, noise reduction, geotagging
Front Camera
Sensor Resolution
7 Megapixel
Lens Aperture
F/2.2
FaceTime HD camera
Navigation System
Receiver
A-GPS/GLONASS
Multimedia
Supported Digital Audio Standards
WAV, AAC, AIFF, Audible, MP3, Apple Lossless, AC-3, HE-AAC, Audible AAX, Audible AAX+, protected AAC, EAC3, MP3 VBR
Supported Digital Video Standards
MPEG-4 SP (up to 640x480), Motion JPEG (up to 1280x720), H.264 High Profile Level 4.2 (up to 4K)
Audio
Two microphones, four speakers
Input Device
Security Devices
Fingerprint reader
Software
Preloaded Software
Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, Files, FaceTime, Photo Booth, Safari, Photos, App Store, Maps, News, Find My iPhone, Stocks, Siri, Books, Reminders, Music, Find My Friends, Voice Memos, iTunes Store, Podcasts, Apple TV App, Home, Measure
System Requirements for PC Connection
Microsoft Windows 7 or later, Apple MacOS X 10.9.5 or later
Expansion and Connectivity
1 x headphones mini jack (3.5mm) , 1 x Lightning , 1 x Smart Connector
Lithium polymer
30.4 Wh
Run Time
Up to 10 hours
Run Time Details
Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Audio playback: up to 10 hour(s) , Web browsing over cellular data network: up to 9 hour(s)
Space grey
Sensors
Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass, barometer
Charging via USB, VoiceOver screen reader, AirPrint, AirPlay, parental controls, Dictation, AssistiveTouch, MIMO technology, AirDrop, iBeacon microlocation, Family Sharing, Night Shift, Apple M10 motion coprocessor
Power adapter
Lightning to USB cable
0.93 W/kg (body)
17.41 cm
0.61 cm
25.06 cm
477 g
Limited warranty - 1 year , Technical support - phone consulting - 90 days
35 °C
5 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
45 °C
Max Altitude Operating
3 km
