Any way you look at it, iPad mini is just incredible. And the stunning Retina display is only the beginning. With A7 chip, advanced wireless, and powerful apps - all beautifully integrated with iOS 7 - iPad mini with Retina display lets you do more than you ever imagined. Feature for feature, it's identical to iPad Air in every way. Except for its super-portable, hold-it-in-one-hand, still-just-right mini size.
Now iPad mini looks even more brilliant in your hand. The Retina display has over 3.1 million pixels - a million more than an HDTV. That's a 2048-by-1536 resolution, four times the resolution of the previous-generation iPad mini. In fact, the pixels are so close together, your eyes can't distinguish them. So photos and videos show incredible detail and text is razor sharp. Because the best pixels are the ones you never see.
7.9-inch Retina display
Now iPad mini looks even more brilliant in your hand. The Retina display has over 3.1 million pixels - a million more than an HDTV. That's a 2048-by-1536 resolution, four times the resolution of the previous-generation iPad mini. In fact, the pixels are so close together, your eyes can't distinguish them. So photos and videos show incredible detail and text is razor sharp. Because the best pixels are the ones you never see. -
Thin and light design
Apple packed so many incredible features inside iPad mini. It has a stunning Retina display, the incredibly powerful A7 chip, advanced wireless technologies, and more. Yet it's still thin and light. It's just 0.29 inch thin and weighs less than three-quarters of a pound. So while you can do even more, you won't feel like you're holding any more. -
Incredible performance
The Apple-designed A7 chip brings 64-bit desktop-class architecture to iPad. That means up to 4x the CPU speed and up to 8x the graphics performance for everything you do. And still long hours of battery life to study, play, build, and create whatever you want, all you want. -
A7 chip
The A7 chip takes iPad to heights of power and speed. Thanks to the A7 chip, apps run faster. Games are more responsive. And everything you do with iPad mini feels quicker, because it is quicker. Up to four times as quick, in fact. But that's just the beginning. And the A7 chip features 64-bit architecture, opening the door for even more robust and powerful apps. Which means even more possibilities for what you can do with iPad mini. -
M7 motion processor
iPad mini was designed to be on the move. That's why the M7 coprocessor makes so much sense. It measures motion from your iPad mini by pulling data from the accelerometer, gyroscope, and compass. So your apps can give you a better experience based on the movement of your iPad mini. It's a task that would normally fall to the A7 chip. But M7 is more efficient at it, which saves on power. -
Same great battery life
iPad mini is powerful, but not power hungry. Even though it's up to four times as fast as the previous-generation iPad mini, it still gives you the same incredible long-hour battery life. That's because the A7 chip isn't just more powerful, it's also more efficient. So no matter where you go with iPad mini, you'll have the battery power to go even further. -
More LTE bands
iPad mini with Wi-Fi + Cellular lets you connect to the Internet even if you're away from a Wi-Fi signal. iPad mini supports even more LTE bands to connect to more cellular data networks around the world. Now you can get online at really fast speeds - faster than broadband in some cases - in more places. And plans are flexible, so you don't have to sign a contract. Some plans even let you share data across multiple devices.
- Apple iPad mini 2 Wi-Fi + Cellular - 2nd generation - tablet - 16 GB - 7.9" - 3G, 4G
- Product Type
- Tablet
- Display
- 7.9" IPS TFT - LED backlight - 2048 x 1536 (326 ppi) - Multi-Touch
- Processor
- Apple A7 - 64-bit
- Storage
- 16 GB
- Cellular Technology
- 3G, 4G
- Cellular Protocols
- GSM, UMTS, EDGE, CDMA 2000 1X EV-DO Rev. A, HSPA, HSPA+, LTE, DC-HSDPA, CDMA 2000 1X EV-DO Rev. B
- Wireless Connectivity
- 802.11a/b/g/n, Bluetooth 4.0
- Rear Camera
- 5 Megapixel focus: automatic
- Front Camera
- 1.2 Megapixel
- Navigation System
- A-GPS
- Battery Run Time
- Up to 10 hours
- 13.47 cm x 0.75 cm x 20 cm
- 341 g
- Space grey
- Localisation
- English / United Kingdom
- SAR
- 1 W/kg (body)
- 1-year warranty
- Product Type
- Tablet
- Operating System
- Apple iOS 7
Display
- Resolution
- Touchscreen
- Multi-Touch
- Anti-fingerprint, Retina display
- Processor
- Apple A7
- 64-bit Computing
- Storage
- 16 GB
Communications
- 3G, 4G
- Band
- GSM 850/900/1800/1900 / UMTS 850/900/1900/2100 / CDMA 2000 X1 800/1900 / LTE 700b/700c/800/800 DD/850/900/1800/1900/2100/2600 / AWS 1700/2100
Rear Camera
- Sensor Resolution
- 5 Megapixel
- Focus Adjustment
- Automatic
- Geotagging
Front Camera
- Sensor Resolution
- 1.2 Megapixel
- FaceTime HD camera
Navigation System
- Receiver
- A-GPS
Multimedia
- Supported Digital Audio Standards
- WAV, AAC, AIFF, Audible, MP3, Apple Lossless, protected AAC
- Supported Digital Video Standards
- MPEG-4 SP (up to 640x480), Motion JPEG (up to 1280x720), H.264 High Profile Level 4.2 (up to 1080p)
- Audio
- Two microphones, speaker
Software
- Preloaded Software
- Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, FaceTime, Photo Booth, Safari, Videos, Photos, App Store, Maps, Game Center, iBooks, Newsstand, Siri, iCloud, Reminders, Music, iTunes Store
System Requirements for PC Connection
- OS Required
- Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP Professional SP3 or later, Microsoft Windows XP Home Edition SP3 or later, Apple MacOS X 10.6.8 or later, Windows 8
Expansion and Connectivity
- Expansion Slots
- 1 x Nano-SIM card
- 1 x headphones , 1 x Lightning
- Technology
- Lithium polymer
- Capacity
- 23.8 Wh
- Run Time
- Up to 10 hours
- Run Time Details
- Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Audio playback: up to 10 hour(s) , Web browsing over cellular data network: up to 9 hour(s)
- Space grey
- Sensors
- Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass
- Charging via USB, aluminum enclosure, VoiceOver screen reader, AirPrint, AirPlay, parental controls, Dictation, AssistiveTouch, MIMO technology, AirDrop, Apple M7 motion coprocessor
- Included Accessories
- Power adapter
- Cables Included
- Lightning to USB cable
- SAR Value
- 1 W/kg (body)
- Localisation
- 13.47 cm
- 0.75 cm
- 20 cm
- 341 g
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- 0 °C
- 35 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 45 °C
