iPad mini with Retina display is amazing to hold. And behold. Every photo is incredibly detailed and vibrant, and every line of text is remarkably crisp and clear. With higher resolution than an HDTV, it's stunning - on a whole new scale.
iPad mini keeps you connected faster than ever. In more locations than ever. Using two antennas instead of one and MIMO technology, iPad mini delivers twice the Wi-Fi performance of its predecessor.
Any way you look at it, iPad mini is just incredible. And the stunning Retina display is only the beginning. With an A7 chip, advanced wireless, and powerful apps - all beautifully integrated with iOS 7 - iPad mini with Retina display lets you do more than you ever imagined.
Now iPad mini looks even more brilliant in your hand. The Retina display has over 3.1 million pixels - a million more than an HDTV. That's a 2048-by-1536 resolution, four times the resolution of the previous-generation iPad mini. In fact, the pixels are so close together, your eyes can't distinguish them. So photos and videos show incredible detail and text is razor sharp. Because the best pixels are the ones you never see.
Apple packed so many incredible features inside iPad mini. It has a stunning Retina display, the incredibly powerful A7 chip, advanced wireless technologies, and more. Yet it's still thin and light (and mini). So while you can do even more, you won't feel like you're holding any more.
Advanced wireless
iPad mini keeps you connected faster than ever. In more locations than ever. Using two antennas instead of one and MIMO technology, iPad mini delivers twice the Wi-Fi performance of its predecessor. -
Every little bit as amazing
Any way you look at it, iPad mini is just incredible. And the stunning Retina display is only the beginning. With an A7 chip, advanced wireless, and powerful apps - all beautifully integrated with iOS 7 - iPad mini with Retina display lets you do more than you ever imagined. -
7.9-inch Retina display
Now iPad mini looks even more brilliant in your hand. The Retina display has over 3.1 million pixels - a million more than an HDTV. That's a 2048-by-1536 resolution, four times the resolution of the previous-generation iPad mini. In fact, the pixels are so close together, your eyes can't distinguish them. So photos and videos show incredible detail and text is razor sharp. Because the best pixels are the ones you never see. -
Thin and light design
- Apple iPad mini 2 Wi-Fi - 2nd generation - tablet - 128 GB - 7.9"
- Product Type
- Tablet
- Display
- 7.9" IPS TFT - LED backlight - 2048 x 1536 (326 ppi) - Multi-Touch
- Processor
- Apple A7 - 64-bit
- Storage
- 128 GB
- Wireless Connectivity
- 802.11a/b/g/n, Bluetooth 4.0
- Rear Camera
- 5 Megapixel focus: automatic
- Front Camera
- 1.2 Megapixel
- Battery Run Time
- Up to 10 hours
- 13.47 cm x 0.75 cm x 20 cm
- 331 g
- Space grey
- Localisation
- English / United Kingdom
- SAR
- 0.6 W/kg (body)
- 1-year warranty
- Product Type
- Tablet
- Operating System
- Apple iOS 7
Display
- Resolution
- Touchscreen
- Multi-Touch
- Anti-fingerprint, Retina display
- Processor
- Apple A7
- 64-bit Computing
- Storage
- 128 GB
Communications
Rear Camera
- Sensor Resolution
- 5 Megapixel
- Focus Adjustment
- Automatic
- Geotagging
Front Camera
- Sensor Resolution
- 1.2 Megapixel
- FaceTime HD camera
Multimedia
- Supported Digital Audio Standards
- WAV, AAC, AIFF, Audible, MP3, Apple Lossless, protected AAC
- Supported Digital Video Standards
- MPEG-4 SP (up to 640x480), Motion JPEG (up to 1280x720), H.264 High Profile Level 4.2 (up to 1080p)
- Audio
- Two microphones, speaker
Software
- Preloaded Software
- Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, FaceTime, Photo Booth, Safari, Videos, Photos, App Store, Maps, Game Center, iBooks, Newsstand, Siri, iCloud, Reminders, Music, iTunes Store
System Requirements for PC Connection
- OS Required
- Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP Professional SP3 or later, Microsoft Windows XP Home Edition SP3 or later, Apple MacOS X 10.6.8 or later, Windows 8
Expansion and Connectivity
- 1 x headphones , 1 x Lightning
- Technology
- Lithium polymer
- Capacity
- 23.8 Wh
- Run Time
- Up to 10 hours
- Run Time Details
- Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Audio playback: up to 10 hour(s)
- Space grey
- Sensors
- Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass
- Charging via USB, aluminum enclosure, VoiceOver screen reader, AirPrint, AirPlay, parental controls, Dictation, AssistiveTouch, MIMO technology, AirDrop, Apple M7 motion coprocessor
- Included Accessories
- Power adapter
- Cables Included
- Lightning to USB cable
- SAR Value
- 0.6 W/kg (body)
- Localisation
- 13.47 cm
- 0.75 cm
- 20 cm
- 331 g
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- 0 °C
- 35 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 45 °C
