The iPad Air is unbelievably thin and light. And yet it's so much more powerful and capable. With the A7 chip, advanced wireless, and great apps for productivity and creativity iPad Air lets you do more than you ever imagined. In more places than you ever imagined.
iPad Air is impossibly thin but incredibly solid thanks to its aluminum unibody design. It dropped almost a quarter of the volume of the previous-generation iPad. But what makes iPad Air truly remarkable is that it packs so much more power and capability into its sleek enclosure. So you can do even more with it, while carrying even less with you.
Retina display
iPad has always been about the display. And that’s even more true with iPad Air. Because Apple reduced the width of the device, along with the bezels on the sides of the display. But the size of the stunning Retina display is exactly the same. So your content fills your view more than ever. With a 2048-by-1536 resolution and over 3.1 million pixels, photos and videos pop with detail and text looks razor sharp. Pixels are indiscernible. So all you see is what you want to see. -
Incredible performance
The Apple-designed A7 chip brings 64-bit desktop-class architecture to iPad. That means up to twice the CPU speed and graphics performance for everything you do. -
Advanced wireless
Your new favorite app, book, or movie,your next FaceTime call or iMessage, ultrafast wireless lets you access the things you love, right from iPad Air. So more than ever, you can stay in sync and in touch.
- Apple iPad Air Wi-Fi + Cellular - 1st generation - tablet - 16 GB - 9.7" - 3G, 4G
- Product Type
- Tablet
- Display
- 9.7" IPS TFT - LED backlight - 2048 x 1536 (264 ppi) - Multi-Touch
- Processor
- Apple A7 - 64-bit
- Storage
- 16 GB
- Cellular Technology
- 3G, 4G
- Cellular Protocols
- GSM, UMTS, EDGE, CDMA 2000 1X EV-DO Rev. A, HSPA, HSPA+, LTE, DC-HSDPA, CDMA 2000 1X EV-DO Rev. B
- Wireless Connectivity
- 802.11a/b/g/n, Bluetooth 4.0
- Rear Camera
- 5 Megapixel focus: automatic
- Front Camera
- 1.2 Megapixel
- Navigation System
- A-GPS
- Battery Run Time
- Up to 10 hours
- 16.95 cm x 0.75 cm x 24 cm
- 478 g
- Silver
- Localisation
- English / United Kingdom
- Specific Absorption Rate (SAR)
- 1 W/kg (body)
- 1-year warranty
- Product Type
- Tablet
- Operating System
- Apple iOS 8
Display
- Resolution
- Touchscreen
- Multi-Touch
- Anti-fingerprint, Retina display
- Processor
- Apple A7
- 64-bit Computing
- Storage
- 16 GB
Communications
- 3G, 4G
- Band
- GSM 850/900/1800/1900 / UMTS 850/900/1900/2100 / CDMA 2000 X1 800/1900 / LTE 700b/700c/800/800 DD/850/900/1800/1900/2100/2600 / AWS 1700/2100
Rear Camera
- Sensor Resolution
- 5 Megapixel
- Focus Adjustment
- Automatic
- Geotagging
Front Camera
- Sensor Resolution
- 1.2 Megapixel
- FaceTime HD camera
Navigation System
- Receiver
- A-GPS
Multimedia
- Supported Digital Audio Standards
- WAV, AAC, AIFF, Audible, MP3, Apple Lossless, protected AAC
- Supported Digital Video Standards
- MPEG-4 SP (up to 640x480), Motion JPEG (up to 1280x720), H.264 High Profile Level 4.2 (up to 1080p)
- Audio
- Two microphones, speaker
Software
- Preloaded Software
- Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, FaceTime, Photo Booth, Safari, Videos, Photos, App Store, Maps, Game Center, iBooks, Newsstand, Siri, iCloud, Reminders, Music, iTunes Store, Podcasts
System Requirements for PC Connection
- OS Required
- Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP Professional SP3, Microsoft Windows XP Home Edition SP3, Apple MacOS X 10.6.8 or later, Windows 8
Expansion and Connectivity
- Expansion Slots
- 1 x Nano-SIM card
- 1 x headphones , 1 x Lightning
- Technology
- Lithium polymer
- Capacity
- 32.4 Wh
- Run Time
- Up to 10 hours
- Run Time Details
- Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Audio playback: up to 10 hour(s) , Web browsing over cellular data network: up to 9 hour(s)
- Silver
- Sensors
- Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass
- Charging via USB, VoiceOver screen reader, AirPrint, AirPlay, parental controls, Dictation, AssistiveTouch, MIMO technology, AirDrop, Apple M7 motion coprocessor
- Included Accessories
- Power adapter
- Cables Included
- Lightning to USB cable
- 1 W/kg (body)
- Localisation
- 16.95 cm
- 0.75 cm
- 24 cm
- 478 g
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- 0 °C
- 35 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 45 °C
