Apple iPad Air Wi-Fi 32GB Silver
CONTACT OUR IT SPECIALISTS TO ENQUIRE ABOUT EDUCATION PRICING!
Quicklinx: 92QYWS00 Mfr#: MD789B/B
You have to hold iPad Air to believe it. It's just 7.5 millimetres thin and weighs less than half a kilo. The stunning Retina display sits inside thinner bezels, so all you see is your content. And an incredible amount of power lies inside the sleek enclosure. So you can do so much more. With so much less.
  • All-better design, leaner, and definitely meaner
    iPad Air is impossibly thin but incredibly solid thanks to its aluminum unibody design. It dropped almost a quarter of the volume of the previous-generation iPad. So it weighs just one gravity-defying pound. But what makes iPad Air truly remarkable is that it packs so much more power and capability into its sleek enclosure. So you can do even more with it, while carrying even less with you.
  • Retina display, so much to see, so little to hold
    iPad has always been about the display. And that's even truer with iPad Air. Because Apple reduced the width of the device, along with the bezels on the sides of the display. But the size of the stunning Retina display is exactly the same. So your content fills your view more than ever.
  • Incredible performance, it's light on everything but power
    The Apple-designed A7 chip brings 64-bit desktop-class architecture to iPad. That means up to twice the CPU speed and graphics performance for everything you do. And still long hour of battery life to study, play, build, and create whatever you want, all you want.
  • A7 chip
    The A7 chip takes iPad to heights of power and speed. Thanks to the A7 chip, apps run faster. Games are more responsive. And everything you do with iPad Air feels quicker, because it is quicker. Up to twice as quick, in fact. And the A7 chip features 64-bit architecture, opening the door for even more robust and powerful apps. Which means even more possibilities for what you can do with iPad Air.
  • M7 coprocessor
    iPad Air was designed to be on the move. That's why the M7 coprocessor makes so much sense. It measures motion from your iPad Air by pulling data from the accelerometer, gyroscope, and compass. So your apps can give you a better experience based on the movement of your iPad Air. It's a task that would normally fall to the A7 chip. But M7 is more efficient at it, which saves on power.
  • Same great battery life
    iPad Air is powerful, but not power hungry. Even though it's 20 percent thinner and up to twice as fast as the previous-generation iPad, it still gives you the same incredible long-hour battery life. That's because the A7 chip isn't just more powerful, it's also more efficient. So no matter where you go with iPad Air, you'll have the battery power to go even further.
  • Ultrafast Wi-Fi
    iPad Air gives you up to twice the Wi-Fi performance thanks to two antennas and MIMO (multiple-input multiple-output) technology. With dual-band 802.11n Wi-Fi and MIMO, download speeds can reach up to 300 Mbps - double the data rate of the previous-generation iPad. So now when you want to download a movie, share photos or documents with AirDrop, or just browse the web, your connection is even faster than before.
Apple iPad Air Wi-Fi - 1st generation - tablet - 32 GB - 9.7"
Tablet
Display
9.7" IPS TFT - LED backlight - 2048 x 1536 (264 ppi) - Multi-Touch
Apple A7 - 64-bit
Storage
32 GB
Wireless Connectivity
802.11a/b/g/n, Bluetooth 4.0
Rear Camera
5 Megapixel focus: automatic
Front Camera
1.2 Megapixel
Battery Run Time
Up to 10 hours
16.95 cm x 0.75 cm x 24 cm
469 g
Silver
English / United Kingdom
SAR
0.53 W/kg (body)
1-year warranty
Tablet
Operating System
Apple iOS 7
Display
Resolution
Touchscreen
Multi-Touch
Anti-fingerprint, Retina display
Apple A7
64-bit Computing
Storage
32 GB
Communications
Rear Camera
Sensor Resolution
5 Megapixel
Focus Adjustment
Automatic
Geotagging
Front Camera
Sensor Resolution
1.2 Megapixel
FaceTime HD camera
Multimedia
Supported Digital Audio Standards
WAV, AAC, AIFF, Audible, MP3, Apple Lossless, protected AAC
Supported Digital Video Standards
MPEG-4 SP (up to 640x480), Motion JPEG (up to 1280x720), H.264 High Profile Level 4.2 (up to 1080p)
Audio
Two microphones, speaker
Software
Preloaded Software
Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, FaceTime, Photo Booth, Safari, Videos, Photos, App Store, Maps, Game Center, iBooks, Newsstand, Siri, iCloud, Reminders, Music, iTunes Store
System Requirements for PC Connection
Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP Professional SP3, Microsoft Windows XP Home Edition SP3, Apple MacOS X 10.6.8 or later, Windows 8
Expansion and Connectivity
1 x headphones , 1 x Lightning
Lithium polymer
32.4 Wh
Run Time
Up to 10 hours
Run Time Details
Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Audio playback: up to 10 hour(s)
Silver
Sensors
Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass
Charging via USB, VoiceOver screen reader, AirPrint, AirPlay, parental controls, Dictation, AssistiveTouch, MIMO technology, AirDrop, Apple M7 motion coprocessor
Power adapter
Lightning to USB cable
SAR Value
0.53 W/kg (body)
16.95 cm
0.75 cm
24 cm
469 g
Limited warranty - 1 year , Technical support - phone consulting - 90 days
35 °C
5 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
45 °C
