Apple HDMI to DVI Adapter Cable
Quicklinx: B5MDWS00 Mfr#: MJVU2ZM/A
The Apple HDMI to DVI Adapter allows you to connect your Mac with built-in HDMI to a DVI display or projector. You can use an external display as your primary display, extend your desktop to a second display, or work in mirroring mode with a projector so you can view what your audience sees. . Use the HDMI to DVI Adapter to connect a single-link DVI digital monitor, such as the 20-inch or 23-inch Apple Cinema Display, that includes a DVI connector.
  • Seamless connectivity
    This Apple video adapter offers a seamless bridge between devices with its HDMI Type-A male connector to a 24+1 pin digital DVI female connector, ensuring a reliable link for transmitting high-quality video signals.
  • High-quality construction
    Crafted with precision, the adapter features a single link TMDS configuration that supports high-speed transmission without compromising the integrity of the digital signal, making it suitable for professional and home environments.
Apple adapter
Cable
Adapter
TMDS Links
Single link
Connector
HDMI - male
Connector (Second End)
DVI-D - female
Cable Type
Adapter
TMDS Links
Single link
Connector
19 pin HDMI Type A - male
24+1 pin digital DVI - female
