Unlike traditional, circular earbuds, the design of the Apple EarPods is defined by the geometry of the ear, which makes them more comfortable for more people than any other earbud-style headphone.
The speakers inside Apple EarPods have been engineered to minimize sound loss and maximize sound output. So you get high-quality audio that's just as impressive as what you'd hear from more expensive headphones.
The Apple EarPods with remote and mic also include a built-in remote that lets you adjust the volume, control the playback of music and video, and answer or end calls with a pinch of the cord.
Grade B returned device
Looking for Earpods, but want to make your money go further? Try one of our Grade B devices and you’ll find amazing deals on some of the latest and greatest devices.
Good condition, showing small signs of wear which includes, but not limited to, small/fine scratches and marks.
- Apple EarPods - earphones with mic - USB-C
- Product Type
- Earphones - wired - USB-C
- Compatibility
- iPhone, iPad, Mac
- Recommended Use
- Portable electronics
- Headphones Form Factor
- Ear-bud
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Microphone
- On-cable
- Controls
- Volume, answer/end, play/pause
- 1-year warranty
- Product Type
- Compatibility
- iPhone, iPad, Mac
- Recommended Use
- Protection
- Waterproof, sweat-resistant
Audio Output
- Ear-bud
- Wired
- Sound Output Mode
- Stereo
- In-Cord Volume Control
Microphone
- On-cable
Remote Control
- Controls
- Connector Type
- Headphones (24 pin USB-C)
- Cable Details
- Headphones cable
- Supported Host Device OS
- iOS 17 or later, macOS 12.6 or later, iPadOS 16.4 or later
- Limited warranty - 1 year
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
J3JW 051320 Condition: Item has been opened and looks like been used but in good condition |
£4.51 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
