Apple Grade B AirPods Pro 2nd Generation USB C
Quicklinx: J1YPWS00 Mfr#: 400020393
Type: Earbuds
Connectivity: Wireless
Colour: White
Hurry, only 1 left in stock!
£124.17 ex VAT
£149.00 inc VAT
Express delivery Order within the next hour for delivery tomorrow
Grade B returned device
Looking for AirPods, but want to make your money go further? Try one of our Grade B devices and you’ll find amazing deals on some of the latest and greatest devices.
  • 12 months warranty
  • Good condition, showing small signs of wear which includes, but not limited to, small/fine scratches and marks.
AirPods Pro feature up to 2x more Active Noise Cancellation,¹ Transparency mode, and now Adaptive Audio,² which automatically tailors the noise control for you to provide the best listening experience across different environments and interactions throughout the day.
  • Groundbreaking audio performance
    Apple-designed H2 chip, the force behind AirPods Pro, pushes advanced audio performance even further. From smarter noise cancellation to superior three-dimensional sound and battery life, it improves on the best features of AirPods Pro in a big way.Low-distortion, custom-built driver and amplifier deliver crisp, clear high notes and deep, rich bass in stunning definition. Every sound is more vivid than ever.
  • Unheard-of sound
    Adaptive Audio dynamically blends Transparency mode and Active Noise Cancellation to deliver the best listening experience for you in any environment.²Up to 2x more Active Noise Cancellation than the previous-generation AirPods Pro, so you’ll hear dramatically less noise during your commute and when you need to focus.¹Transparency mode lets outside sound in, so you can hear what’s going on around you.Conversation Awareness lowers media volume and enhances voices of people in front of you, all while reducing background noise to make it easier for you to engage with people nearby when wearing AirPods Pro.²Personalised Volume automatically fine-tunes the best media experience for you in the moment.²Personalised Spatial Audio surrounds you in sound tuned just for you. It works with dynamic head tracking to immerse you deeper in music and movies.³Four pairs of silicone tips are included to fit a wider range of ears, with an extra-small size. The tips create an acoustic seal to help keep out noise and secure AirPods Pro in place.
  • A higher level of control
    Touch control lets you swipe the stem to adjust volume. Press the stem once to answer, mute or unmute yourself on calls, press it twice to end a call, or hold it to switch between listening modes.
  • A leap in battery life and capability
    A more capable MagSafe Charging Case with Precision Finding,4 built-in speaker and lanyard loop. Charge with a USB-C connector or an Apple Watch, MagSafe or Qi-certified charger.Up to 6 hours of listening time with Active Noise Cancellation enabled — 33% more than AirPods Pro (1st generation).5IP54 dust, sweat and water resistant for AirPods Pro and MagSafe Charging Case.
  • A magical experience
    Siri now works when you just say “Siri” as well as “Hey Siri” to play music, make calls and get directions simply by using your voice.7Easy setup lets you pair with every device in your iCloud account.8In-ear detection and automatic switching between devices makes everything seamless.8Audio Sharing lets you share a song or a show between two sets of AirPods on your iPhone, iPad, iPod touch or Apple TV instantly.?Find My with Precision Finding lets you exactly locate the MagSafe Charging Case.4 And Find My with proximity view helps you keep track of your AirPods Pro.
  • Legal
    ¹As compared with AirPods Pro (1st generation).²Works with AirPods Pro (2nd generation) with the latest firmware when paired with a compatible Apple device running the latest operating system software.v ³Spatial Audio works with compatible content in supported apps. iPhone with TrueDepth camera required to create personalised profile.4Precision Finding requires a U1-equipped iPhone; availability varies by region.5Battery life depends on device settings, environment, usage and many other factors.6AirPods Pro (2nd generation) are dust, sweat and water resistant for non-water sports and exercise, and they are IP54 rated. Dust, sweat and water resistance are not permanent conditions.7Siri may not be available in all languages or in all areas, and features may vary by area. Internet access required. Mobile data charges may apply.8Requires an iCloud account and a compatible Apple device running the latest operating system software.?Requires a compatible Apple device running the latest operating system software.
Apple AirPods Pro 2nd generation - true wireless earphones with mic
True wireless earphones - Bluetooth
Compatibility
iPhone, iPad, iPod, Mac
Recommended Use
Portable electronics
Additional Functions
Wireless audio sharing, conversation awareness, personalised volume, adaptive audio, transparency mode
Headphones Form Factor
In-ear
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.3
Sound Output Mode
Stereo
Sound Effects
Adaptive EQ
Active Noise Canceling
Microphone Operation Mode
Dual beamforming
Controls
Play/pause, answer/end, mute, next/previous track, ANC/transparency, volume, voice assistant
Intelligent Assistant
Siri - indirect
1-year warranty
True wireless earphones - Bluetooth - wireless
Product Generation
2nd generation
Compatibility
Dimensions & Weight Details
Charging case: 6.06 cm x 2.17 cm x 4.52 cm / 50.8 g
2.18 cm
2.4 cm
3.09 cm
5.3 g
Recommended Use
Protection
Sweat-resistant, water-resistant, dust-resistant, IP54
Audio Output
In-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.3
Sound Output Mode
Stereo
Sound Effects
Adaptive EQ
Apple H2 chip, MagSafe charging case with Apple U1 chip, vent system for pressure equalisation, Personalised Spatial Audio with dynamic head tracking, high dynamic range amplifier, high-excursion Apple driver
Microphone
Built-in
Dual beamforming
Remote Control
Controls
Tracking
Sensors
Skin-detecting sensors, motion-detecting accelerometer, speech-detecting accelerometer, touch control
Internet of Things (IoT)
Communications Type
Product-to-product
Communications Technology
Bluetooth 5.3
Siri
Voice Controlled
Indirect
4 pairs of silicone ear tips (extra small, small, medium, large), MagSafe charging case with speaker and lanyard loop, USB-C charge cable
Cable Details
USB-C charge cable
BFR-free, PVC-free, Mercury-free, Beryllium-free
Auto On/Off
Headphone battery rechargeable - wireless charging
Wireless Charging Standards
Qi
Run Time (Up To)
6 hour(s)
Run Time Details
Continuous playback (active noise-cancelling on): up to 6 hours , Continuous playback (personalised spatial audio, head tracking on): up to 5.5 hours , Continuous talk: up to 4.5 hours , Continuous playback (active noise-cancelling on) (with included charging case): up to 30 hours , Continuous talk (with included charging case): up to 24 hours
Limited warranty - 1 year
Type: Earbuds
Colour: White
Brand: Apple
Stock Status: While stocks last
Stock Status: Clearance
